Question about Nintendo Wii Console
Error 51330 keeps coming up whenyrting to set wii to internet
  • 864 Answers
I can assist you with this. This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Posted on Aug 27, 2010
Can't get on netflix error code 51330 keeps coming up
This error message indicates that you are entering the incorrect router security key in your Wii network settings. This security key allows your Wii to gain access to and use the internet through your router. I wrote a tech article which goes over how to resolve 51330 errors. You can click here to read it.
-G33k
Aug 07, 2011 | Nintendo Wii Console
Tip
Nintendo Wii Error Code 51330 usually indicates that the WEP/WPA key you set on...
<span><span style="font-weight: bold;">Nintendo Wii Error Code 51330</span> usually indicates that the <span style="font-weight: bold;">WEP/WPA</span> key you set on your Wii is not the correct one to gain access to your <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>router</span></a>. <br /><br />When you setup a router for wireless internet, you usually set a WEP key or by default one is set. This is basically a <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>security</span></a> key(<span style="font-weight: bold;">password</span>) that you set so any device that wants to use your <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>internet</span></a> has to enter correctly in order to gain access.<br /><br />If you know your router security key, go into your <span style="font-weight: bold;">Wii network settings</span> and make sure it is entered correctly. Click <a href="/../support/r9198848-connect_nintendo_wii_internet">here</a> to read my tech article on how to configure your Wii's network settings. <br /><br />If you do not know the security key of your router, then read my other article by clicking <a href="/../support/r9359087-find_wep_key_router_router_security">here</a>. This article will go over <span style="font-weight: bold;">how to find the router security key</span> or if need be, set one.<br /><br />Be sure to check out my other <span style="font-weight: bold;">Tips</span> by clicking on my profile name and then clicking "<span style="font-weight: bold;">Tips</span>" at the top left. <br /><br />Regards,<br />G33k<br /><br /><br /><br /><br /><br /><br /><span>Keywords</span><br style="font-weight: bold;" /></span><span style="font-weight: bold;">Nintendo Wii Error Code 51330, error </span><span style="font-weight: bold;">51330, Wii </span><span style="font-weight: bold;">51330, Wii error </span><span style="font-weight: bold;">51330, Wii network settings, can't connect Wii to netflix, Wii netflix, Nintendo error code </span><span style="font-weight: bold;">51330, Wii code </span><span style="font-weight: bold;">51330</span>
on Jun 14, 2011 | Nintendo Wii Console
I am trying to connect Netflix to my Wii and I keep getting error code 51330 and 51331. I don't know what these errors are. I am trying to set up with wireless internet.
From Nintendo:
Error Code 51330, 51331, and 51332
    It appears that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console. Click here for more information about WEP and WPA security, including how to access the settings for your Access Point.
If your wireless network password isn't wrong, reply. Hope this helps somewhat.
Jul 21, 2011 | Nintendo Wii Console
I keep getting error code: 51330 when trying to connect wirelessly to the internet.
This was the information on error code 51330 on Nintendo.com
Error Code: 51330
Unable to connect to your wireless network
Likely cause: It appears that the password (also known as a WPA or WEP key) entered into the Wii console is not the same as what your wireless router is set to allow.
How to fix: Make sure the password is entered into the Wii exactly as it appears in your router's settings. Security keys are case sensitive.
Don't know how to find your router's password?
Look for a sticker on the bottom of your router. Many routers provided by Internet service providers have their default password located on a sticker on the bottom of the router.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Jul 20, 2011 | Nintendo Wii Console
I am trying to watch a movie on net flix, however everytime I tried to look for the internet service the following error comes up: Error code 51330 is unable to connect to the internet.
Hi there!
Error code 51330 on the Wii means that the password you entered into the Wii to set up your internet was entered incorrectly. You will need to go back into your internet connections settings menu on your Wii and enter the correct password/security key for your router. Please remember the security key is case sensitive.
Hope this helps!
Jul 05, 2011 | Nintendo Wii Console
I received an error code, 51330 when attempting to go online with the WII console for the first time.
Hi there!
Error code 51330 on the Wii means that the security key you entered into the Wii to set up your internet connection was entered incorrectly. You will need to go back into your internet connections settings menu on your Wii and enter the correct security key for your router. Please remember the security key is case sensitive.
Hope this helps!
My wii keeps giving me the 51330 message code when I try to connect to my netflix app or internet. was working just fine when I installed it yesterday its wireless. but now it won't connect. HELP
This problem is related to either your internet security key or your IP Address settings. Double check to verify these settings are correct.
I obtained this info from:
http://www.wiichat.com/nintendo-wii-online/59591-error-message-51330-a.html
Jan 16, 2011 | Nintendo Wii Console
Error message 51330 unable to connect to internet keeps appearing when i try to conect my nintendo wii to the internet.
go check your internet settings well and try reconnecting it also depends what kind of internet you have.
Aug 03, 2008 | Nintendo Wii Console
Nintendo wii
You have to go into wii settings console information write the mac address down then add it to your wireless router.
Mar 02, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
19 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
