Question about Coleman Roadtrip Grill LXE 9949-750
I can't hear the gas when I turn the knob and the tank(s) are brand new. Does the regulator need to be cleaned or do I need to buy a new one?
  • Coleman Master
  • 43,501 Answers
Never try to mess with a pressure regulator. if they fail very bad things can happen.
replace the regulator and be safe!
heatman101
Posted on Aug 20, 2010
No sound of gas
Tyrn off tank open conrtol knobs to burners , turn off burners turn tank on slowly see if gas comes out now , if not check burners are not blocked or injectors are not blocked
Jul 04, 2012 | Grilling
My brand new patio heater wont turn on
To get your patio heater to light first check the tank has plenty of LPG/gas and the regulator is turned to on. Next turn the gas control knob to pilot (on some heaters this is a red line on others it has a spark symbol) and press in - hold for at least 30 secs. Press the piezo ignitor several times and continue to hold for another 60 secs. Gently ease off the pilot to release and turn to full power. You should hear the gas jet come on. If there is air in the pipes you might have to repeat. Fould this site very useful patio heater top repair tips.
Apr 10, 2012 | Heating & Cooling
Brand new compressor...air builds in tank but turning the regulator result in no change in the regulated pressure. Tried turning the regulator to make sure it moves freely, and it seems to, but still no...
The regulator has a very strong spring inside causing knob to get harder to turn as you increase the pressure (increase clockwise). If the knob is easy to turn most likely stripped inside. If knob gets tight as you turn then plunger at rear of regulator is stuck. On the back side of the manafold directly opposite the adjustment knob is a small nut housing a plunger. Let out all the air from the tank and remove the nut. Seperate the nut and plunger, lube and re-install. If the regulator knob is stripped you will need to replace the manafold or as a temp fix remove the safety valve (let out air from tank first) and install a tee fitting. On one port of the tee reinstall the safety valve and on second port install quick fitting for full tank pressure (or install aftermarket pressure regulator ).
Oct 28, 2011 | Porter Cable C2002 150 Psi 6 Gal...
My psi is 150 and the tank turns off but my regulator pressure is at 0, this is a brand new tank and never been used before.
Hi scooterb88...
Sounds like your pressure regulator needs adjustment...
Turn the knob on the pressure regulator clockwise and you should start hearing air coming out of your hose...Once air is coming out, remove your hose and keep turning the regulator till you get to your desired working pressure normally around 90 psi...leave your pressure regulator at that setting and it will stay at that setting.
Please take time to rate me
Sep 17, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Plastic knob on regulator is cracked causing gas leak where it attaches to LP tank. Needs replacement. Can I get a regulator/hose?
Hi kimandjimm...
You can use any generic hose and regulator assembly for your grill.
You can buy it online at: http://www.appliancefactoryparts.com/gasgrillparts/brands/charbroil/charbroil-plumbing-valves.html
You can buy them at HomeDepot,Lowes,Ace Hardware,etc. Look in the grill section.
Sep 07, 2011 | Char-Broil Patio Caddie 4654870 (LP) Grill
Remote controlled gas log fire will not ignite,relaced batteries,cleaned logs etc,worked a couple of times then refused to ignite again ,can hear ignition ticking but cannot hear any gas coming through ,...
If you're using propane gas, the banging noise you hear is air in the gas line, which means either your tank is empty or the the tank regulator is frozen (if it's ,below freezing in your area). If the tank regulator is frozen, soak a bath towel in hot water and quickly place it around the regulator. It should thaw fairly quickly and the gas will start flowing again. However, you may need to purge the air out of the gas line to gas log burner. Rather than using the electronic ignitor, do it manually, until you smell gas, left off the control knob and wait 5 minutes and then try lighting the pilot electronically.
If you're using Natural Gas, it may still be a pressure problem to the burner. You'll need to have that professionally checked.
Hope this helped to solve your problem.
Feb 27, 2011 | Heating & Cooling
I have a full propane tank. I bbq'd about 3 weeks ago, same full bottle. Grill will not light. Good spark at ignitor. Used lighter and lit for a few seconds with low flame on high. No other burners will...
You may have turned the gas tank valve on too fast. Turn it back off, disconnect it and reconnect it. Then very slowly turn the valve back on. Light one burner at a time and turn to low before lighting the next. If you are hearing and smelling gas with the tank on but all grill knobs off, don't use the grill. You may have a leaking grill valve, regulator or hose. If you are only smelling gas with the knobs on, it's possible you have a clogged burner or orifice from bug nests, spiderwebs, etc and need to clean it out first. Hope this helps. Douglas
Jun 13, 2010 | Brinkmann Charmglow Stainless Steel LP...
I have a 5 burner grill that will only burn 2-3 burners. As soon as I turn on the 4th burner. They all go out. Is this a regulator problem?
You should not smell propane at any time when the tank is closed or the flame is lit. Make sure that the connection is tight between the grill gas line and the tank. You might want to take it off and reattach it to make sure there is no cross threading that is preventing a good seal.
The new tanks have a safety valve that can interrupt the flow if the knob is turned to on before the tank is opened. When that happens, the flame is low and sputtering. It will often go out if all of the jets are turned on at once.
You can actually hear the difference when you first turn the knob. If the valve is opened fully, you should hear a healthy hiss from the gas. You should use the ignition quickly after turning the knob and pay attention to whether one jet is assigned as the one to light.
It can be a regulator on the gas line as well, but this is actually less common. If you have not had this problem before hooking up this particular tank, try a new one. Those trade in tanks are often culprits because all tanks should have been updated to new standards a few years back. The trade ins are often older than they should be. There's a date on the top that will give you an idea.
Other than that, make sure that there is not a lot of debris, no loose connections, and the jets are clean. Thanks for using fixya.
May 09, 2010 | Grilling
My weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Mar 21, 2009 | Thermos Stainless Steel Gas Grill
No gas getting to bbq
I switched to the new style 20# tank with the new turn-on knob.  I couldn't get enough gas pressure to the BBQ burners for all three burners to light or to keep a strong flame on even one burner.  The new style tanks have a safety valve on the inside of the tank that shuts the gas off if you turn the knob on too fast because the safety valve thinks there is leak.  Shut everything off and then try turning the knob on real slow, especially at first, before turning it all the way on.  If that doesn't work (it didn't for me), then replace the large plastic connection valve knob (female end) that attaches the regulator to the tank.  Mine was for the old style tank and was black (low pressure).  I went to a propane company and had them replace it with a green knob (higher pressure).  Took it home and WALA!  Everything works fine now.  But it was very frustrating trying to figure why I couldn't get any gas to the burners after buying a brand new tank.  I hope this helps solve your problems.
Sep 15, 2008 | BBQ Guys BBQ400C/G42 Grill
Coleman Roadtrip Grill LXE 9949-750 Logo
245 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
paulcarew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
