Question about Kenmore 96213 Electric Kitchen Range
Unable to turn off One Burner
I am unable to turn off the main burner with the on/off control. I tried turning the power on and off by unplugging the AC. As soon as I plug in the AC the burner comes on.
    Genius:
  • 1,073 Answers
Either the control is shorted or the element is grounded
Posted on May 02, 2008
My right front burner wont turn off. My dad checked the control knob and it seems to be working. He unplugged it from the front burner and put it on the back to see if it did the same thing and it did. ...
with a model number to know exactly how power is supplied to the surface burners its going to be hard to let ya know anything definate...but do ya have knobs that ya turn to turn on the surface burners? if yes knobs..their will be terminals on the switch marked L1/L2 on those 240vac should be there all the time when turning the knob onto high on terminals marked H1&H2 should be 240vac to the burner
if it has the touch button to turn on the surface burners 240 vac into board all the time ..4 individual outbound power places (one for each burner) and the one for that burner also should have 240 vac when set to high
in either case if 240 vac out to burner the burner is bad
if 240vac into switch/board and not out..switch/board bad
Aug 26, 2011 | Kenmore 99123 Electric Kitchen Range
The gas burners are sparking and i am unable to turn off
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Aug 30, 2010 | Viking VGSC366-6B Gas Kitchen Range
Hi, I have a Gateway M-6755. Lately, I am unable to power up the laptop. When I press the power switch, the lights briefly turn on for 1 second and then go off. Tried he same thing repeatedly ending in...
You might try replacing the CMOS battery, if you haven't done that already. It will require some disassembly of the laptop, depending on your model; please refer to manual for specifics. Leave it out for half an hour or so, just to be sure everything is reset. And be sure the computer's (regular) battery is out as well.
Feb 22, 2010 | Gateway M-6755 Notebook
My Whirlpool electric range made a loud electrical popping/cracking noise followed by smoke. Now the indicator light for the left front element is always on. Also when we try to turn on any burner the eft...
Sounds like you have a short in one of your burner switches that may have also taken out your main control. Does your oven work normally? Those error codes are related to 1] control board and 2] oven over temp, so the burner issue is unrelated except in that it may have surged the control.
you can view the switches by removing the rear panel(if this is a freestanding range) and from the description you will likely see the shorted component with some black marks around it. Please unplug the range first,as these wires are live even when all burners are off
Sep 02, 2009 | Kitchen Ranges
When I turn on a burner, all the other burners click like they are trying to turn on as well. The clicking is continuous and really annoying! Thanks for your help! Tammie
Anytime you turn on a gas range all burners click for safety reasons. If a knob has been turned by mistake the gas lights to prevent gas from escaping into the room. If you turn the control knob past the LITE position after the burner lights you should be OK and stop the clicking. If the clicking continues regardless you have a defective ignitor switch that must be replaced.
Aug 26, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Main Burner Will only stay on with mid range temperature setting
Thermostat is bad. There is a micro switch behind the dial that reacts to the temp probe and you may try cleaning it out first but in my experience replacing the t-stat is usually required.
Jul 04, 2009 | Jandy Laars Lt 250,000 Btu Heater
Top burner is stuck on and F1 showed on the display
Hi Krista,
Unfortunately, F1 is a fault code for a failed electronic control... it'll have to be replaced. The reason the burner is on is that the relay controlling it has welded closed allowing power to the burner full time.
If you choose to repair this yourself, could you provide the model number? That way, I could pull up schematics and stuff I need to further help you.
SG
Apr 05, 2009 | Kenmore Ovens
Burner won't turn off
oven not correct tempators out of control
Dec 07, 2008 | Kitchen Ranges
Kenmore 96213 Electric Kitchen Range Logo
74 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
