Question about AOC Computers & Internet
How do i alter the setting that turns my monitor off after 5mins if i leave the room or have not pressed a key etc etc
  • 560 Answers
Hi. If you are using Windows XP (most common OS right now), right-click on any empty space on your desktop and select "Properties" then click "Screen Saver" tab, click "Power" button, "Power Schemes" will pop-up, on "Turn off monitor" option, increase the time or select "Never" from drop-down list to set your monitor to always on.
If you are not using XP, settings are the same for most Windows OS, just different ways to access display properties. So if you manage to open display properties, you can navigate to power options and change your power settings.
Posted on Aug 19, 2010
Control panel not responding
the controls are bad. get a new monitor
or order a new control set, from maker.
is it still in warranty?
some are 1year.
read your warranty car, and read the manual for authorized
LG service, its all in the box , new. read that.
or go to LG.com and read there. for service.
in my estimate the keys are shorting. this is common, if they are hit too hard. ship damage etc.
I remove the key pad , cable, if the pop ups stop, BINGO.
Sep 28, 2013 | LG Computers & Internet
Brand new lenovo g550 laptop when switched on for the first time didn't display anything on the screen. What's the solution to that? Please help. The processor is running but totally nothing is...
If you have a seperate monitor, turn the laptop off and plug in the monitor to the VGA out on the laptop (somewere on the side of the laptop will be this output). The reason for this is it will make the next steps easier.
Turn the laptop on, you will hopefully get a display from the other monitor. If not you can still proceed, but it will be in the "dark". On the laptop somewere around the Ctrl key, you should find an fn key. If you look at the laptop keyboard you will see small symbols in the same color as this key (usually blue or grey). Look for one with monitors on it, Levnovo's website says that it is the F7 key. Pressing and hold down the fn key, now press the F7 key that has the monitors on it. This should switch between onboard and external and both. release the key and see if either monitor displays. Since laptops alter in the way this key works, you may have to press the F7 key more than once to get the display to switch the display.
More information on this procedure can be found on Lenovo's website:
http://www-307.ibm.com/pc/support/site.wss/PFAN-3PVSCN.html
I hope this is of some help to you.
Jul 27, 2011 | Computers & Internet
I have a em350 but screen broke so have been using a monitor and it was fine but now it wont work on it so need to be able to restart it without access to start menu etc. maybe safe mode. once prob solved...
You might know this already, but here goes:
The auxiliary monitor settings are set by pressing the Fn key (usually at the bottom left of the keyboard) another (one of the F keys at the top of the keyboard). That F key may have a small icon of monitors with a slash between them. While booting try pressing the Fn key continuously while pressing the F key several times. It will cycle through different settingss of "only LCD" / "Only external monitor"/ both monitors/.... keep doing that it may restore your setting.
Jan 06, 2011 | Computers & Internet
How do I make screen adjustments - brightness, contrast, etc.?
Press the OSD (On Screen Display) button, to display the OSD menu. Use the LEFT/RIGHT and UP/DOWN buttons to cycle through the various settings. Press the OSD button to "select" one of the settings to be changed. Use the LEFT/RIGHT and UP/DOWN buttons to alter the setting. Press the OSD button to "accept" the new setting.
Oct 23, 2010 | AOC Monitor
I have a sharp PC-GP10 CM laptop but the screen has gone black after my daughter pressed a button. I dont know what she did. I have rebooted and the laptop comes on but the screen is still black. Any...
Look for the Fn Button bottom left of the keyboard. Hold this button down then press F5. You should see the screen flash up. Have an external monitor connected to the vga output on the back of the sharp while you try this. The Fn Key and F5 combination is used to swith modes between laptop and external monitor, Dual view etc. You should see some activity when you do this. Hope this helps you out. Ps... Using the Fn key with F6 and F7 will Alter the brightness of the screen on your laptop.
Oct 14, 2010 | Sharp Mebius PC-PJ2-S3 Notebook
How to adjust the toasting time on the preprogram
your better off going back to the factory setting. Call turbo chef but here you go this is how you re-program the thing. Remember i took the time to give you these directions. Please take the time to leave a review
PROGRAMMING
Edit Mode
The EDIT MODE enables the operator to manually alter
recipes and the cook cavity temperature (CCSP).
To access EDIT MODE:
1. Simultaneously press the UP and DOWN keys.
2. When prompted, enter the access code “9” and
then press the ENTER key.
Altering a Recipe
Most NGC (Tornado) oven models contain 128
unique recipes. The display shows two (2) pages each
with eight (8) recipe groups. Each recipe group contains
eight (8) recipes. See Figures 11 and 12.
To alter a recipe:
1. Enter the EDIT MODE (see page 16).
2. Enter the access code “9” and set the CCSP. The
screen displays the first set of eight (8) recipe
groups. To access the second set of eight (8)
recipe groups, press either the UP or DOWN key.
3. Select the recipe group that contains the individual
recipe you wish to alter. Select the recipe you
wish to alter by pressing the soft key corresponding
to the recipe item. Figures 11 and 12.
4. Use the UP and DOWN keys to navigate through
the recipe settings. Use the keypad and ENTER key
to alter any of the following three (3) parameters
(see Figure 13):
a. Cook time
Total duration of the cook cycle. Enter the
desired time and press ENTER.
b. IR element temperature (IRSP)
The temperature the lower radiant element
will maintain during the entire cook cycle.
Valid temperatures are between 500ºF (260ºC)
and 1150ºF (621ºC).
c. Events 1…6
Use the keypad and ENTER key to enter values
for % TIME, % AIR, and % WAV.
o Sum of % TIME for all events must = 100.
The operating system will not allow a
combination of events not equal to 100%.
o The % AIR parameter is valid between 10
and 100%.
o The % WAV (microwave) parameter is valid
between 0 and 100%.
5. After making changes, test the recipe by
pressing the TEST soft key. Once the oven has
warmed to the CC set point, press the TEST
soft key again to begin the test cook.
6. Once satisfied with the recipe, press SAVE to
permanently store changes.
7. Press the BACK key until exited from EDIT MODE.
Jan 14, 2010 | TurboChef TORNADO Electric Oven
LCD Monitors
first use screen saver every 5mins this will protect your lcd from burn .
never use wallpaper with very high contrast same reason keep away from burn
its better to turn off you lcd monitor if your not using it. saves energy =)
Nov 12, 2008 | Dell E152FP 15" Flat Panel LCD Monitor
Detecting array...
does any other monitor work? if not than the video card may be bad. or the settings in the bios may be altered. first try this...unplug the tower, open the case and remove the bios/real time clock (RTC) button cell battery, press the power button to dissipate any voltage that is stored. Re-install the battery, plug tower in and power up. If anything was changed in bios everything would go back to default settings and you would have to enter set up to update date/time etc.
Sep 10, 2008 | E-Machines eMachines Desktop PC
More Brightness
on the front of the monitor there are key buttons naming menu, ok button and left & right arrow marks buttons first press menu button then go to brightness then by using arrow keys you can increase & decrease the brightness once you are finished decreasing r increasing press ok button.& there are many other settings you can change like contrast etc....
Feb 07, 2008 | LG Flatron 775FT 17" CRT Monitor
Monitor Black, Green Power Light Flashes Monitor is 4 yrs. old
Assuming you've already checked your driver and system settings, tried a different monitor, and checked the cable and connector pins, this would almost certainly be a problem with the power or signal circuit board inside the monitor.
Jan 19, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Computers & Internet Logo
66 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
