Question about KitchenAid 24 in. KUDP02IRBS Stainless Steel Built-in Dishwasher
We have a Kitchen Aid model# KUDP02IRBS1 serial# FT1404764 The dishwasher will not work and the "Normal" light is flashing. We have had the control panel replaced once already with this similar problem and it worked for a while. Any suggestions? Thanks for you help!
  • 1314 Answers
SOURCE: Replacing detergent dispenser on Kitchen Aid Model KUDI24SEAL3 Dishwasher
send me an email at b4829@yahoo.com and ill send inst
Posted on Mar 19, 2008
huuum
  • 750 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
Hi 1cassie1,
Did you try to turn the power off at the breaker box?
This resets the whole system usually!
Let me know how it goes? Write me back!
Other wise you need a hands on tech.
ngafm
please give me a rating before you sign off!
Posted on Sep 11, 2008
mohammed387
  • 1952 Answers
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Posted on Sep 21, 2008
aborcass
  • 2651 Answers
SOURCE: Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Posted on Oct 19, 2008
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
My Kitchen Aid Dishwasher model # KUDS40FVSS0 has blinking cancel, sani-rinse and normal wash lights. It will not run at all. We replace the control board and still nothing. Please Help!!!
I have had this problem. Mine didn't work for over a week and by the time the repair man came over to 'replace the board' it suddenly worked. The guy told me that if you use ANY type of liquid dishwashing soap (for your sink) and any residue/bubble is on the dishes, it can cause your dishwasher to break. I have no idea why but I've been really careful to make sure I wasn't using dish soap prior to putting them in the washer.
I've had 3 service calls on this dishwasher since I purchased it 3 years ago. I'm having similar service issues with my Kitchen Aid Fridge. And of course no help from Kitchen Aid.
Sep 25, 2013 | KitchenAid Dishwashers
Sep 21, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
What is the reset sequence of a kitchen aid kudi01fl my dishwasher wont start the control lock button is on
Press and hold the heated dry button for 5 seconds to unlock the controls. If that doesn't work go to the link below and it will tell you how to reset the control board.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good luck
Mar 01, 2011 | Dishwashers
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
The clean light flashes clean, seven times. I can reset the machine, but the problem persists. How do I determine if it is the heating element?
Kitchen Aid models with the stainless steel tanks flashing clean light requires changing out both the heating element and the electronic control due to a change in voltage on the heating elements. By ordering the heating element, it comes with the electronic control. For your particular model it is a part #8194200. Just shop around to the different parts stores online, to get the best price. This will fix your problem.
Jul 30, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
"Normal" light flashes
You need a new control bd. #W10084141. If the diagnostic mode will not work then the board will have to be replaced.
Mar 06, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Sep 01, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchen Aid Dishwasher--model #KUDS01DJ
On mine the "normal" light was the one that was flashing; after a cycling of the breaker switch in the electrical main panel and closing the washer door, it went to a 2 minute rinse before shutdown.
May 17, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
KitchenAid 24 in. KUDP02IRBS Stainless Steel Built-in Dishwasher Logo
79 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
