I have a sharp ar-168d printer. It is displaying a code system error h4-00 refer to user guide. I cleared it with a clear code, but it didnt work. it is blinking a red triangle light.can you help me?
  • treemendous9 Aug 19, 2010
    I have a sharp ar-168D. it is displaying a code system error h4-00 refer to user guide.also a red triangle light is blinking
  • 4,737 Answers
The problem is related to fuser. It's possible that there's overheating problem with the fuser roller or insufficient temperature (low heat) to run the fuser. On many cases, this error also displays when there's something blocking on the fuser unit.
If there's no hardware defect, you can easily fix it. Remove the fuser, check for any foreign objects like pieces of paper, thread, hair, etc.. if so clear them. Clean the unit with brush or whatever you think of is good and suitable. Reinstall it. Reboot the machine and check if this helps or not.
If the problem persists, you need to reset the machine. I recommend a tech do it for you.
Good luck.
Thanks for using FixYa.
Posted on Aug 19, 2010
  • 2,973 Answers
Friend, Please un and re install the device as per the link below :-
Installing Devices on PCs and Laptops
How do you clear the error message on a AR-168D?
We inject the cartridge int he printer it gives the message on AR-168S
Apr 07, 2011 | Sharp AR-168D Black and White Copier
How do i reset the meter reading on a sharp ar 168 d?
Press # , Press * , Press Clear, Press *, the display come off Press 20, Press start press 1 press start the machine reset counter power off and power on.
Dec 29, 2010 | Sharp AR-168D Black and White Copier
I am using Sharp AR-M201 photo copier machine. I just came across a error message ` System Error F2-02 Refer to user guide' Can anyone guide me to solve this problem? Thanks K K Mendon
F2 -02 Toner supply failure
cause :-
- developer unit trouble
- Toner supply abnormality caused by
installation of unpacked toner cartridge
Dec 26, 2010 | Sharp AR-M205 Copier
Hi, Can someone help with resetting error H2-00 on sharp 168d
H2 00
[Content]
Thermistor open
[Detail]
The thermistor is open.
The fusing unit is not installed.
Cause Thermistor abnormality
Control PWB abnormality
Fusing section connector disconnection
[Check and remedy]
Check the harness and the connector between
the thermistor and the PWB.
Use TC 14 to clear the self diagnostic display.
To enter the serviceman test command mode, press the keys as
follows:
[#] key → [*] key → [C] key → [*] key
Enter 14 Start to clear the code.
Oct 26, 2009 | Sharp AR-168D Black and White Copier
I have a Sharp AR-M207 with an H4-00 error. We have installed a new fuser but still get the error the moment that we turn on the device. I have seen several responses telling which buttons to press to...
heat roller low temperture detection&check the thermistor abnormality,heatlamp abnormality,thermostat abnormality,clean the paerdust guide &use sim 5-02
check the heater lamp blinking operation
use sim 14 to clear the slf diagnostic display
Oct 19, 2009 | Sharp AR-M207 All-In-One Laser Printer
Error H3-00
Hello sir; This error code require a reset procedure ;
press "#", "*", "clear", "*",these four keys by order, then enter 14 press start. then turn power off and back on.
Aug 26, 2009 | Sharp AR-168D Copier
Sharp AR-168D H2-00 error code
Check
http://www.copier-help.com/copier-help/ecs/sharp/ecsar161.html
Thanks.
Jun 11, 2009 | Sharp AR-168D Black and White Copier
Network Error code CE-02
the ce-02 code is just a communication error it general in nature so you could have a couple different issues going on
Apr 09, 2009 | Sharp AR-168D Black and White Copier
H4-00 error on Sharp AR-168D
the code needs to be reset even if you replace the fuser.
Press clear, press *, press #, press * your display should go blank press 14 then press print,
I'm doing this from long term memory I may have the # and * symbols swapped
Error on Sharp AR-168D Copier
The manual says to turn off and unplug the machine and wait for 10 seconds. Then plug it back in and turn it on. If this doesn't get rid of the problem contact your sharp dealer/service man.
Jan 12, 2009 | Sharp AR-168D Copier
29 people viewed this question
k24674
jasbo
jasbo
