We have a Sharp AL-1661CS Copier. It is coming up with an H4-00 error message that will not clear. We even tried unplugging. Got any clues?
    President:
  • 2,072 Answers
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on May 03, 2008
  • astros610 Feb 14, 2011
    AL 1661CS from mid 90's I have a white w/ red C (clear button) and a Yellow CA (clear auto) button. Tried this sequence and nothing happens at all. Error code is H4-00- any other ideas?
    I powered down for a couple days - and restarted today to check this possible solution.
    I have unplugged it too. Nothing changes
System error [h4-00]
press. # * C * The machine will enter diagnostics. Then enter 14, and then I believe 1 and start. That will clear the fuser code. The machine will restart and should be fine.
Jul 30, 2010 | Sharp AL-1661CS Laser Digital Copier
I have a SHARP al-1661cs copier/printer. i keep getting a "replace TD cartridge" message. I have replaced the cartridge and it still come on every couple of days. i take the cartridge out, shake it and the...
Are you having your cartridges refilled?
By "replace TD cartridge" message do you mean the little stack of 6 red dots on the control panel?
The sensor for this condition is contained within the toner cartridge. The sensor reads the mixture of developer to toner ratio and tells the machine to add toner when needed. If you are having this problem with 3 different toner cartridges then I would suspect the toner add drive system. If you are having just the 1 cartridge refilled and have had the problem with the last 3 refills then the cartridge itself may be the problem.
I'll let you repond then we will see if further info is required.
Thank You for using Fixya.
Mar 29, 2010 | Sharp AL-1661CS Laser Digital Copier
Sharp al 1661 cs ..it shows System error(L1-00)
When your copier scanner is locked then show L1
Solve :Unlock position
clean all surface in scanner area
clean scanner sensor
Nov 05, 2009 | Sharp AL-1661CS All-In-One Laser Printer
Getting H3 error message Sharp AL 1631 copier
H3 is a heater/fuser problem. Try to reset it by SIM 14. Press Clear , auto exposure, Clear and auto exposure and press copy key. check if H3 has been reset and LED is back to "00".
Oct 29, 2009 | Sharp AL 1631 Copier
I have a Sharp AL-1661CS copier fax machine and the paper is getting stuck when we try faxing. Paper goes 3/4 of the way thru and then gets stuck. Help
If there is lead edge damage on the original, open up the feeder section and line up the damage with the paper path. look for foreign objects or damaged guides.
If there is no damage clean the rollers with alcohol. and the sensors with compressed air.(Computer Duster) Try it again.
Hope this is of some help.
ed
May 05, 2009 | Sharp AL-1661CS Laser Digital Copier
Printer has stopped printing copies even with a new toner and drum. Help!
Try the old one back in it? does that work if so Faulty unit take it back
Apr 23, 2009 | Sharp AL-1661CS All-In-One Laser Printer
Error message E 7
Try these steps to cancel the error, press the buttons continously
STEP1. Press CLEAR key then EXPOSURE key then CLEAR key then EXPOSURE key
STEP2. Then you are inside the simulation if the display turns OFF if not, do again step 1 until the display turns off.
STEP3.press 14 then press print button
Jan 29, 2009 | Sharp AL 800 Copier
H4-00 system error
Try very quickly # * C * then 14 and 1 for yes to reset, chances are it will come back, do not keep re entering code, it will need the fuser repaired.. job 4 a teco.
Jan 01, 2008 | Sharp AL-1661CS Laser Digital Copier
Drum cartridge - generic
Sharpe are correct there is no known button sequence I know about as the drum normally has a resistor that blows when installed resetting the drum count.
Thanks J
Dec 26, 2007 | Sharp AL-1661CS All-In-One Laser Printer
139 people viewed this question
jasbo
jasbo
