My Craig 13" Color TV CD+G Karaoke System model CG8235 won't turn on. I have made sure that it was plugged in but it still won't turn on
2 Suggested Answers
  • 27 Answers
SOURCE: I need a 5 digit code for a Craig 13
There is only one code for that tv. 10180
If that does not work try this:
1. Turn on the TV.
2. Slide the MODE switch to TV.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV and press CHAN+. Repeatedly press CHAN+ until the TV turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV.
Solution found at: http://2getdtv.com/directv/remote_codes.html
Hope this helps.
Posted on Mar 05, 2010
Testimonial: "I've tried all methods & the only codes that are for the this TV are 10180 & 10169 & they will not work. Thank you."
I need a manual for craig cg8235
That item seems to be really elusive online (though I avoid torrent sites and such that want too much info to purportedly see something). there seem to be a number of people looking for it. Best I can offer is the Craig Electronics Contact Us page
http://www.craigelectronicsstore.com/contact-us with the basics for phone or e-mail being:
Phone - 1-866-321-7191
Email - service@craigelectronics.com
Hours 8:30 AM-5:00 PM, Mon-Fri.
Address is in Miami FL, so I'll assume the times are Eastern.
Good Luck!
Nov 19, 2015 | Craig Audio Players & Recorders
I accidently put the rca wires in the wrong audio input/output on my craig cd graphics karaoke player.Could this be why i have no sound?
The RCA outs are designed to send a signal to an external amplifier. That amplifier, in turn, sends the music signal to speakers.
The RCA inputs are designed to take audio signals from another device (like an ipod, CD Player, or computer) and play it through the Craig System speakers. If you sing into the microphone, the vocals will be mixed with the incoming music. However, in these cases, there won't be lyrics on the screen. If you play a karaoke DVD in a DVD player, connect the red, white and yellow RCA cables from the DVD out to the Craig Inputs, the lyrics should appear on the Craig screen while the music plays.
If you mistakenly plug RCA cables into the Craig Inputs and plug the other end into an amplifier's inputs, neither will produce any sound.
Using RCA outs is only necessary if you want to have louder music than the on-board Craig speakers can handle. Of course, you can run the yellow video cable to a TV RCA input to get a bigger lyrics window and the RED and White RCA to the TV RCA Red and White inputs to hear the music through the TV's speakers.
Aug 30, 2014 | Audio Players & Recorders
No video on the tv. it shows on the computer monitor but not the tv. what do you think is the problem?
make sure u got the rite plugs 4 the unit 2 work check the inputs an out puts 2 c if u r color rite. audio is red white blue green black there r differnt ones make sure u rite
Mar 13, 2011 | Cavs JB199-160GB Karaoke jukebox & Digital...
My receiver is reading NO DISC it is a vocopro karaoke player/receiver model # DKP-10G
First, the player does not support DVDs or MP3 discs.
Try two things:
#1:
Unplug from outlet and Turn ON player (while unplugged).
Plug back in and try to use the CD.
#2:
Obtain a CD laser lens cleaner from Radio Shack ($13). It is an audio CD with a row of brushes and does not use chemicals
Oct 16, 2009 | Vocopro DKP-10G
Karaoke CD's will not play on Craig CD+G player
This is a problem with a simple answer. As newer disk technology comes out, newer electronics come out to work with them. Most likely your Kareoke machine is older and not compatible with burnt cds. As long as you are ok with buying regular CD+G disks, you should be fine. If you are interested in making or copying CD+G disks from others, you should consider investing in a new Kareoke machine. As per your question of it being correctable, to my knowlege, No. The electronics in older kareoke machines are not meant to handle CD-Rs or CD-RWs and in order to correct it you would have to somehow frankenstein a new circuit board in somewhere to allow it to handle CD-R/W Disks. As I don't know what is necessary, I am not sure if this is even possible. Like I said if you need this function, you are better of just getting a new Kareoke machine and selling your old one to offset the cost. Make sure the new one handles CD-R and CD-RW disks. Some more expensive ones will also handle Kareoke DVDs as well and have an A/V out so you can display the information on your TV(some of them will even handle DVD-Rs as well). Just look for that information on the box or ask a store representative for that information and they should be able to help you.
Mar 05, 2009 | The Singing Machine DVD/CDG Karaoke System...
My craig tv model ctv-41301 wont turn on
That means that there are solid state components on a printed circuit board that are soldered into place. If the set is a 13 inch it would not be feasable to drop any cash into it as there are 13 inch combo TV sets going for as little as 59 bucks. Good Luck
Mar 23, 2007 | Craig CTV-41331 13" TV
Greetings from Belize take your set to a tech your tv is having a power supply problem.thats what you call a dead set.good luck.
Words "roll" on Screen
sir, where did you purchase your player?i think theres a problem with your COLOR SYSTEM SETTING...the color system(REGION NUMBER) of your player must be mATCh with your tv monitor ...TRY TO set it using remote control of your dvd player...and try diff color system setting....post the result.ty eg:NTSC PAL =THESE ARE THE COLOR SYSTEM SECAM
Feb 22, 2007 | Cavs DVD-203G DVD/ SCDG/ CDG (CD+G)/...
Televison & Video Logo
398 people viewed this question
Top Televison & Video Experts
Electro Med Services...
