Cannot install driver for an ethernet card im trying to install in my windows computer. error message says code 39
  • Bill Jones May 11, 2010
    What is the exact error message you are receiving? Is it: "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)."
    Also, what Operating System are you using? XP, Vista, ME, etc...
    President:
  • 2,712 Answers
It looks like a corrupt driver.
Doing a "clean boot" may resolve the symptoms you are experiencing. Booting clean is a way to eliminate programs from conflicting with installation of software.
First, download the latest version of the driver for your OS from the manufacturer's website.
The following is the procedure for a 'clean boot'. I am assuming that you have XP. If you have a different OS, just let me know and I will send you the appropriate procedure to boot clean in that OS.
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
After restarting, install the downloaded driver. Next, do the following:
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. Replace checkmarks in the items that you previously removed them from.
3. On the General tab, choose Normal Startup
4. Click OK
5. Click YES, when asked to restart your computer
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 02, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    IrishDruid
Error message when trying to install driver for windows 7 32 bite on macbook for usb to ethernet.
Windows driver is for windows not for apple. So none of windows drivers will work on apple and viceversa.
Feb 03, 2015 | Computers & Internet
Ethernet dont work code28
Go out to Staples and buy an ethernet card. You can use this permanently or just to access the web to the drivers for the integrated port. That's what I had to do.
Apr 30, 2012 | Computers & Internet
Standard dvd/cdrom drivers. Acer Aspire 5542 notebook. Windows 7. Error message: Windows can not load the device driver for this hardware. The driver may be corrupted or missing. Code 39
That is right! The driver/installer maybe corrupted. Try to get a new driver/installer at the cnet.com. In search area, type the device brand name and the word driver or installer. It will show the kind of driver or installer that may suit to your device. Good luck!
Sep 20, 2011 | Computers & Internet
The drivers for this device are not installed. (Code 28) There is no driver selected for the device information set or element.
Cause of the Code 28 Error A Code 28 error is caused by a missing driver for that particular piece of hardware. There are any number of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Resolution
  1. Restart your computer if you haven't done so already.
    There is always the slim chance that the Code 28 error you're seeing in Device Manager was caused by a fluke with Device Manager or in your BIOS. If that's the case, a reboot might fix the Code 28.
  2. Did you install a device or make a change in Device Manager just before you noticed the Code 28? If so, it's very possible that the change you made caused the Code 28 error.
    Undo the change, restart your PC, and then check again for the Code 28 error.
    Depending on the changes you made, some solutions might include:
    • Remove or reconfigure the newly installed device.
    • Roll back the driver to the version prior to your update.
    • Use System Restore to undo recent Device Manager changes.
  3. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 28 error is the most likely solution to the problem.
    Important: Make sure you install the drivers for the correct operating system. For example, if you're using Windows 7 32-bit, install the drivers designed for that specific version of Windows. Many Code 28 errors are caused by attempting to install the wrong drivers for a device.
  4. Install the latest Windows service pack. Microsoft regularly releases service packs and other patches for their operating systems, one of which may contain a fix for the cause of the Code 28 error.
    Note: I do know that certain service packs for Windows Vista and Windows 2000 have contained specific fixes for some instances of the Code 28 error in Device Manager.
  5. Replace the hardware. As a last resort, you may need to replace the hardware that has the Code 28 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you still think there is still a software/operating system component to this Code 28 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those more drastic options before you try replacing the hardware, but you may have to if you're out of other options.
Please let me know if you've fixed a Code 28 error using a method that I don't have above. I'd like to keep this page as updated as possible.
Applies To The Code 28 error could apply to any hardware device in Device Manager but most Code 28 errors seem to affect USB devices and sound cards.
Any of Microsoft's operating systems could experience a Code 28 Device Manager error including Windows 7, Windows Vista, Windows XP, and more.
Still Having Code 28 Issues in Device Manager? Let a community of computer support enthusiasts help out! Post the details of your problem in the PC Support Forum. Be sure to let us know that the exact error you're receiving is the Code 28 error in Device Manager. Also, please let us know what steps, if any, you've already taken to try to fix the problem.
----------------------------------------------let me know if this helps--------------------------------------------
Jun 20, 2011 | Computers & Internet
Error message while tryinh to instal broadband says 'No NIC has been installed on this sytem'. working with rather old Compaq Presario S0000
You need to update your drivers for your ethernet card. You can try running Windows Update to find it, or you can search for it on Compaq's website.
To run Windows Update: Go to your start menu and find "Windows Update". Click on it and do everything it asks you to do. If it asks you if you want to run Windows Update Express or Custom, pick CUSTOM. This will take a while. When it is done it should show you many, many updates available. Make sure to click "Hardware" on the left side under optional updates. This will usually have the drivers for your Sound and many other items. Check them all then "Review and Install Updates". Good luck!
May 05, 2011 | Televison & Video
I reinstalled Windows XP to my computer and now i cant get the internet. There is a yellow question mark and exlmation point next to Ethernet Controller and it has a code 28 error.
You should have had 2 cds that came with your computer. The 2nd one has all the drivers on it. Install the drivers and your problem will go away.
Nov 19, 2009 | Microsoft Windows XP Professional
I'M TRYING TO RELOAD CABLE PROVIDER INTERNET SOFTWARE AND DRIVERS
Locate the chipset for Ethernet Card whether it is DLink or Relatek 8139xx series., or if any onboard chipset series, then trace for the drivers, for it, for Onboard you have Motherboard Cd, and can easily avlble on the net...
Mar 27, 2009 | Dell Dimension 2350 PC Desktop
Unable to connect to internet
Hi.
What do you mean by "reloading Windows"? Did you repair it? Maybe did reinstallation? If so, you may need to install drivers for your Ethernet adapter. You will need to specify Ethernet adapter manufacturer and model (if it is onboard adapter, then motherboard manufacturer and model), so I can provide you with the download link, in case you don't have the drivers.
Your responses are intended to improve the level of service provided. Please rate your experience.
Jan 17, 2009 | Dell Inspiron 1525 Laptop Jet Black
M2N-MX sound
Try reinstalling the drivers, which can be found here.
Apr 06, 2008 | Creative Labs Sound Blaster Live! 5.1...
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
