Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
My Laars Lite 2 , model #LG250N-C won't fire up. The pilot light is working, but when you turn the thermostat for the heat to kick in, nothing happens. It is not igniting the gas to heat the pool.
  • 107 Answers
Gas valve is either not getting signal from thermosts or the gas valve coil is bad. Can you check for proper voltage to gas valve ?
Posted on Aug 21, 2010
  • Kirt Steeves Jul 26, 2011
    I could check for the proper voltage if you could tell me where to check it and what the proper voltage is
Pilot lights but main burner dose not light when turned on
possibly a fowled thermocouple if the thermocouple doesn's sense the pilot flame then it will not send a signal to the gas valve telling it that its okay to open cause the pilot is lit.
Dec 28, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Electronic pilot lights but unit will not fire
Make sure the pipes are full of water. Check the thermostat to see if it is calling for heat. Make sure the thermostat is set to a temperature higher than the current temp of the water. If all those things are OK then the gas valve coils may have to be replaced.
Jul 19, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot lights but burner will not fire
what burner where on the oven or the cooktop, if its the oven it may need new gas valve w\ thermocoupler
Jul 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool Heater Light main burner then goes out
take millivolt reads while main burner is on.i suspect you will see a drop in voltage until you get to point where it will no longer operate burner(around 200mv).if this is the case you probably have poor pilot characteristics due to dirty pilot,pilot out of adjustment ,obstruction or insufficient gas pressure
Jun 21, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Will not ignite
First check thermostat is calling for heat or if gas valve fault get unit serviced
Dec 10, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars Lite 2 - Turns off after 5mins of being on!
This happened to me and the tech came out and change the pressure switch and it worked fine afterwards
Jun 15, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heater kicks on, but kicks right off
There is a small probe that is heated by the pilot flame. This is called a thermocouple & keeps the gas valve open by generating a small electric current. Most likely the pilot flame is too small, or not heating the thermocouple properly. Either turn the pilot up a bit, or gently bent the thermocouple bracket to put it in the flame a bit more. Do not try to bend the thermocouple itself. If this does not help, a new thermocouple may be needed.
Jun 20, 2007 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
638 people viewed this question
Top Lite On Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
