Question about Minolta PagePro 1250W Laser Printer
Paper won't feed through the printer - Minolta PagePro 1250W Laser Printer
  • 8 more comments
  • Anonymous May 21, 2008
    paper doesn't feed despite making all the noises of a feeder in motion. Steps taken to resolve the problem include head scratching and the use of inappropriate language.
  • Anonymous May 27, 2008
    paper won't feed through top feeder
    what can i do?
  • C62Edge Jun 14, 2008
    C62 paper won't feed. Paper never engaged.
  • simonewright Jul 03, 2008
    HP PSC 1610 will not feed paper through to printer. Gives "load paper" or "carriage jam" error msgs. Have rebooted, waited 24 hours, re-started computer. Printer connected to a Compaq V2030US w/ Windows XP. HELP-p-p-p-p-p-p-p-p!
  • Anonymous Jul 07, 2008
    paper suddenly won't feed and geting black ink on one corner
  • Anonymous Aug 23, 2008
    Tries to feed paper but only brings it part way or not at all.
  • Anonymous Sep 04, 2008
    Paper feeds part way and halts while printer continues to print on nothing.
  • ravenbeauty Sep 14, 2008
    Paper feeds but it stops halfway and gets stuck, the printer does nothing then i have to pull the paper out myself
  • tglass 1993 Oct 23, 2008
    Keep getting an error message "out of paper" when paper is, in fact, loaded and correct tray is selected. Help!
  • tklsharon May 11, 2010
    I had a paper jam - too many pages fed at once.
    I had to wiggle out the pages a few at a time.
    Now it won't feed at all and I can't see the rubber grooved roller in the back that catches the paper.
    It is high. Is that the problem?
I kept getting the 'out of paper' message too. It worked fine for the first 160 sheets and now it's not feeding. I opened the rear access door and pressed print to see if I could see what was happening and the paper fed fine. However, when I closed the door it didn't work again.
I contacted support and they said "Please download the firmware update from the following site then select printers and then your model number then go to downloads, drivers and firmware update if it does not work, the printer will have to be sent in for a thorough inspection to the problem. Please contact 1-800-421-6699 for further assistance with that."
I just installed the firmware to my printer, it made a really funny noise when it came back on and now it seems to be having a harder time feeding. I am taking it back to the store where I purchased it... luckily I bought the $20 replacement insurance so I'll get mine back today and won't have to deal with Kodak. Good Luck!
Posted on Nov 06, 2008
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Lexmark X85 won't feed paper. When trying to
There could be something in the paper feeder that's blocking the paper path. Please follow steps below to identify and fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 11, 2011 | Lexmark X85 All-In-One InkJet Printer
Paper won't feed properly and jams. the paper starts to feed then twists and jams.
There are a couple of possibilities. First is a little piece of paper could be stuck somewhere along the paper path and is causing one of the feed rollers to not grab the paper evenly, which will make the page twist on most of the models in this series, if you pull the paper out and take a flashlight and look up the feed path you will usually see anything in the feed path near/on the rollers at the top.
Another possibility is one of the feed rollers is old and worn out (If machine gets heavy use) and it will cause same issue.
Also light paper stock can sometimes be too thin for the rollers to grab properly and cause it to twist and slide around. This is usually more of an issue with gravity/drop feed printers but can also occur on front feed style too. Usually 20lb stock is good, but if thats doing it, you can try going to a 24lb.
May 06, 2011 | Epson WorkForce 600 All-In-One InkJet...
There is NO paper jam- and the paper won't feed. We have taken the printer apart- NOTHING hung up- gears are okay- still won' feed paper.
Most of our printers pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
try it out....
Apr 05, 2009 | Lexmark P4350 All-In-One InkJet Printer
Print head alignment +won't feed paper
Best solution is to clean the head with it in place,here's
the manual for your printer
Oct 09, 2008 | Epson Stylus Photo R2400 InkJet Printer
Minolta PagePro 1250W Laser Printer Logo
172 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
