Question about IBM ThinkPad T20 2647 Notebook
T-20 does not recognize cdrom. When I check device for the drive, it has an !, I have uninstalled and reinstalled the driver, and it still won't recognize the D drive..HELP
  • gsrphxaz Aug 19, 2010
    I forgot to add when I click on teac 224e in device and go to properties, it says device driver corrupted or not there (code39)
  • IBM Master
  • 4,737 Answers
Your problem seems the device it not detected properly or is not being assigned a drive letter. First try this, Right-click "My Computer" > "Manage" and then click on "Disk Management", you'll be able to see Cd/Dvd-Rom drive on the lists of available Disk Management snap-ins, right click on the Cd/Dvd-Rom and click "Change Drive Letter and Paths" or it could be "Assign Drive Letter and Paths", once you click it, another dialog box will open up, click "Change" and assign a drive letter from the lists (you'll see an option as a drop-down-list), click "Ok" and restart your computer. You will be able to see the Cd-Rom drive in the My Computer directory.
If this doesn't fix your problem, you need to check the connectors of the cd-rom, means you need to unmount it from the machine and clean the connectors on the cd-rom and on the computer.
It's also possible that the cd-rom itself is defective, in that case, your only solution is replacing with a new Drive.
Good Luck.
Thanks for using FixYa.
Posted on Aug 19, 2010
My laptop won`t recognize my sdcz36-016g
w7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for xp or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts if you need more help with this or if i have missed the problem post a reply Hope it helps.
Jan 01, 2013 | SanDisk 16GB Cruzer Blade - USB Flash...
Unable to detect cdrom after crash / reinstall Vista O/S
hpweb_1-2_minus.gifCheck the Windows Device ManagerDevice Manager is a Windows program that displays hardware devices installed on your computer that are currently recognized by Windows. If functioning properly, each piece of hardware has a corresponding entry in the Device Manager. If a piece of hardware is not listed, then there is a problem. There can be a variety of reasons, ranging from the easy-to-fix (such as missing or corrupted device drivers) to the more serious (such as broken or malfunctioning hardware).If your drive does not appear in Windows Explorer or there is no response from the operating system when you insert a disc, then you should check for an entry in Device Manager. This indicates whether there is a problem or not, and sets the stage for subsequent troubleshooting actions.To verify that the optical drive is listed in the Device Manager:
  1. Remove any discs that may be present from the disk drive.
  2. Click Start , type device into the search field, and then select Device Manager from the list.
  3. In the Device Manager window, expand the DVD/CD-ROM drives entry. There should be a name listed for each installed drive.If the drive is not listed or the DVD/CD-ROM drives entry does not exist and you have verified that it is listed in the BIOS , continue to the next troubleshooting item. reinstall the default device drivers Device drivers are software processes that allow Windows to use the computers hardware components. If the device driver fails or becomes corrupted, then Windows cannot properly communicate with the drive; in fact, it may not even recognize that the drive is connected at all.
Another common source of disk drive problems is that the correct device driver may have been inadvertently replaced with an incompatible one (for example, a generic driver for optical disk drives mistakenly installed by a third-party DVD burning program). In most cases, device driver problems like these can be resolved by reinstalling the default drivers and then installing any driver updates provided by HP. To reinstall the default device drivers:
  1. Click Start , right-click Computer , and then select Properties .
  2. In the System pane, click Device Manager link. If prompted, allow the computer to access the Device Manager.
  3. In Device Manager, click the plus sign c02993920.jpg (in Vista) or the arrow c02993921.jpg (in Windows 7) next to the type of driver you want to uninstall and reinstall (for example., Modems, DVD/CD-ROMs, and so on), unless a minus sign (-) is already showing.
  4. Right-click each listed driver one at a time and click Uninstall . When prompted, confirm that you want to uninstall the selected drivers. Do not restart the PC In the Device Manager pane, select any listed device and click the Scan for hardware changes button (near the top). Windows scans your system for hardware and installs default drivers for anything that requires drivers.
    1. Open Device Manager and verify that your device drivers are listed once again.
    2. After the device drivers have been reinstalled and appear in Device Manager, try running your program again.
      NOTE:Some devices may require your computer to restart. Windows will notify you when restarting is necessary. Save all open files and allow the computer to restart.
    If reinstalling the default drivers does not correct the problem, continue to the next troubleshooting item.
Oct 20, 2011 | HP Pavilion Dv6910us Notebook
My hp1040lightscribe won't recognize the drive for burning. Help. It keeps telling me to put a blank disc in and when I do, it still doesn't recognize it and won't burn it.
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps you
Aug 18, 2011 | HP LightScribe dvd640i (DVD640I)...
Hi, my name is victor. I have a HP Pavillion dv9225nr entertainment laptop, with amd turion dualcore x64, 4GB's RAM, and a Pioneer slimline dvdrw drive. the drive is a (pioneer dvr-kd08hb____1k09_...
Hi digitaldr445 !
This is one solution , maybe not the easiest one nor the best one but it will work .I understand you have the Win 7 install disc :
Back up your data , especially the drivers .
Extract the hdd out of your lap , put it in a external USB box or use a specific connector to connect the drive to a healthy pc . Format the drive . Place it back into your laptop and reinstall
Windows 7 .
Best regards .
fanaudi .
Feb 25, 2011 | Computers & Internet
Acer 5520 cdrom does not open if you open it and insert a cd it does not recognize it.
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
make sure that the cd-dvd is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
don
Feb 14, 2011 | Acer (99.B0311.002) Internal 50x CD-ROM...
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) Laptop Levono y530, device dvd rw optiarc AD-7580s I tried to uninstall & reinstall it, but...
Give this a whirl:
CD-Rom stops working. After checking device manager you find an exclamation mark on the drive. It doesn't mean the drive is dead. It could be an upperfilter or lowerfilter registry issue that is keeping you from accessing the cd drive.
This fix worked for my client:
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Also, try this fix from microsoft.
CD-ROM access is missing and messages cite error code 31, code 32, code 19, code 39, or code 41.
Try this before replacing the drive and remember that you may have to reinstall some burning software.
Oct 16, 2009 | Lenovo IdeaPad Y530-5243U
Lite on DVD Combo disk read failure
You could take the drive out of the encloser and hook it up. There could be a flaw in the enclouser ive had that happen before to me. I just took it out and put it in standard if this dosent work then there is a flaw in the dvd burner
May 20, 2009 | AMD Duron 1.3 GHz (cpu-amd-1.3g-o)...
Optical drive (slot) stuck
you could try to fix this by uninstalling your dvd drive in device manager and then rebooting. this might fix your problems. windows will automatically reinstall the drive when the pc restarts. if you have corrupted files you could try clicking on START, then clicking RUN, typing the command SFC /SCANNOW in the box and pressing ok. this should repair any problems.
to uninstall the drive in device manager, right click on my computer, click properties. you will find device manager on the tab or listed on the left in vista. right click on your dvd-cdrom drive in the manager and uninstall.
Apr 19, 2009 | Computers & Internet
CD Burner
try looking in control panel>system>harware>device manager and see if there is a yellow exclamtion mark next to your cdrom, if there is right click it and make sure it is enabled, if it is click on properties and select update driver. If the driver update works and your cdrom works then fine, if not try uninstalling the cdrom drive then rebooting, this will be picked up as new hardware again and reinstalled. To uninstall it follow the instructions above to get to it and this time when you right click choose uninstall.
Nov 25, 2008 | Acer Aspire 9300 Notebook
I don't seem to have my cd drive anywhere. It won't play cds anymore....
First see if your CDRom is loaded by the PC by Right clicking on My Computor.Left click on properties at the bottom of the dropdown.A window wil be opened for you-click on Hardware at the top ,double click on Device Manager.When Device Manager opens,check down the list for DVD/CDRom drives-click on the + button to the left of it.You will then see your drives description below DVD/CDRom.Double click on it-a window will be opened telling you whether your drive is working properly or what the problem is.Usually it will be a matter of reloading the driver software or reinstalling the drive.Some times it is advisable to uninstall the first one before you reinstall and remember to restart your PC after the installation.If you dont find your DVD or CDRom in device manager it has 'nt been installed or the driver software corrupted.Happy landing.Georgeo.
Jun 03, 2008 | Toshiba Computers & Internet
IBM ThinkPad T20 2647 Notebook Logo
187 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
