I need to find a code that will work with my Jumbo Universal remote and my Symphonic TV model # st4819. I have tried the ones in the book that came with the remote and also did the auto code finder too. Nothing worked. What is is there to get it to work with my TV? Thanks
    President:
  • 2,712 Answers
You can find the remote control codes for difrent brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 02, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    IrishDruid
My remote for for my Symphonic TV (ST4819) does not work. Is there a Universal remote that I can get?
Definitely there is a universal remote for your tv. That's why it is called universal.
Jan 06, 2010 | Symphonic ST4819 19" TV
I need the code for innvage jumbo universal remote for a tv brand name symphonic
it has five diffrent codes 033,053,155,189,198 make sure tv is on press tv then code search till it stays red then enter a code the light will blink then u have thirty seconds to press tv again then press power if it turns off thats the code
Sep 08, 2009 | Innovage Jumbo Remote Control
I need the codes for a symphonic tv
The codes for your Jumbo Universal Remote to control a Symphonic television are 033, 053, 155, 189, and 198.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
Aug 10, 2009 | Innovage Jumbo Remote Control
My phillips universal remote code book is missing and i need to reprogram it work my symphonic tv flat screen
I own a One-for-All universal remote, and my booklet says the setup code for a Symphonic TV (without a built-in DVD or VCR) is either 0171 or 0180. I can not guarantee these numbers will work with your remote, but it is worth a try.
Jul 05, 2008 | Televison & Video
Rca rcr4258 universal remote code for symphonic st4819
Try the code settings for Funai; they build a lot of store-brand items.
You may not have all functions but normally you can find a code that will give you control of Power on/off, channels and volume.
Apr 09, 2008 | RCA Universal Remote Control
Living solutions remote control codes
I have a Universal Remote Control Model ATC-1311 Giant remote. I have lost the codes to and instuction book to. Can you tell me where to get at least the code for my T>V> Thank you
Mar 29, 2008 | Televison & Video
Universal remote codes
i need the code for sonwa tv i have a nse urc22c-6a universal remote
Mar 08, 2008 | Televison & Video
Tv remote code for a Symphonic TV using the Innovage jumbo remote
try this site for most universal remotes
http://www.remotecodelist.com/remotes/
Mar 03, 2008 | Televison & Video
Jumbo Universal Remote Control
DIRECTV all models 00001, 00002
also use 200-217 from the jumbo hand book good luck
please rate
Dec 24, 2007 | RCA DIRECTV Satellite Remote Control
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
