Xerox xc280 paper keeps jamming in exit chute
This may seem odd but double check for any minute scraps of paper that may be in there. If that doeasnt work try using a very lightly dampened paper towel or even your finger to wipe off each of the little white rollers you can find often these get crud from paper on them and won't grab. If doesn't work please explain more specifically where it jams or any sounds it may be making.
Posted on Aug 19, 2010
I can't wake my Xerox Phaser 6280 from sleep mode.
The Electronics Module may be faulty but first, unplug the unit from the wall for 30 minutes. Plug it into the wall and see if it completes posting and messages display on screen. Console Panel ZNN (Control Panel) 848K19391
Control Panel (PL1.2.16)
1. Remove the Exit Out Chute (listed below)
Note
Be careful not to drop the Control Panel.
2. Disconnect the Control Panel connector P/J220.
3. Release the 6 hooks securing the Control Panel to the Front Cover
(PL1.2.9).
4. Remove the Control Panel.
P/J220
s6280-181
Exit Chute
Exit Out Chute (PL6.1.1)
1. Remove 2 screws (10 mm, flanged) securing the Exit Out Chute to the
Front Cover.
2. Remove the Exit Out Chute from the Front Cover.
s6280-217
Mar 17, 2014 | Xerox Phaser Office Equipment & Supplies
Xerox Workcentre 4150. Paper keeps jamming in print engine area. We clear the jam and it jams again.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Engine" or constantly jams as paper exits the machine you should check and possibly replace the fuser actuator (part# 120N00534) This is the most likely cause, if however this does not fix the printer the next step may be to replace the sensor or fuser.
Here is a video that shows you how to check and replace the actuator. ItemInc.com has this part in stock and ships same day. Good luck, and thanks for using FixYa!
Jun 23, 2011 | Xerox WorkCentre 4150 Black and White...
We had a paper jam in the print engine area. Once the paper path has been cleared we are still receiving clear misfed paper in print engine. I have fed paper through the path and cannot find any paper jam.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Area" you should check and possibly replace the fuser exit actuator (part# 120N00534). Iteminc.com has this part in stock and ships same day. Here is a video the shows you how to check and replace the fuser exit actuator. Good luck, and thanks for using FixYa!
Jun 17, 2011 | Xerox WorkCentre 4150 Black and White...
Paper tray doesn't raise on my brothers hl5250dn printer. Says papertray empty
I have had the same exact problem; make absolutely sure that the exit chute is seating properly. With the exit chute open (as if to clear a paper jam) actuate the white spring loaded clips that hold the exit chute, mine were not traveling to their full extension and by moving them a few times this resolved and the exit chute was held more firmly and the rollers spin the right direction.
Jan 30, 2011 | Brother Lower Paper Tray Feeder / Tray for...
Paper jam in a Xerox Comy Centre C20
A couple of things.
There is a bushing at the front of the exit transport that fall out of the frame. That requires removing the scanner and looking in the exit transport that way.
You may also have something stuck in that transport. Take the fuser back out and then take a minella folder and push it through from above the fuser to the output area and see if it disloges anything. If not, then you have to pull the scanner off and look in that exit transport area for problems.
Jun 26, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox Phaser 7700DN jam at fuser
Those rollers are necessary to feed paper from the fuser. Order PN 116-1759-00 which is the 15 inch long shaft w/ 4 rollers
Whit
Item, Inc.
Nov 10, 2009 | Xerox Phaser 7700DN Laser Printer
Paper Jam - Xerox 8200 Phaser Printer
I was same problem and I repaired. In to machine, look of preheat switch ( behind of black roller ). I found piece of paper under the switch. Good luck :)
Jun 02, 2008 | Xerox Phaser 8200 Laser Printer
Paper jam
I had the same problem kept getting an error something like Jam at Exit Door Open Door A. When I looked at the top of the where paper normally comes from and flipped it open I found a super crinkled piece of paper, which once removed cleared the jam.
May 03, 2008 | Xerox Phaser 6180N Laser Printer
Phaser 7300N paper jam
What code is comming up with the jam? That would help me narrow it down for you.
Apr 05, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox 416 Fuser
Is it getting thru the "pinch of the fuser and catching on the stripper fingers? If so clean the fingers, ensure they are not worn or tips broken.(Running sheets with dark lead edge can cause sheets to stick to rollers,try running blank sheets to clean up, if they get thru then try normal copies)
If the sheet stops before entering the rolls more likely to be dirty entry chute, drive problem or sensor problem....need more detail
Jan 25, 2008 | Office Equipment & Supplies
32 people viewed this question
k24674
jasbo
jasbo
