Question about Indesit 24 in. D63 Free-standing Dishwasher
My Indesit D63 dishwasher is not cleaning things in the upper tray. There are no blockages in the spray arm but the rubber seal at the water inlet to the spray arm seems to be damaged. What should I do?
  • Indesit Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
34fes
Posted on Sep 29, 2010
My dishwasher isnt cleaning the top shelf properly. not sure what has happened. cant find any probs. was working a couple of weeks ago. ive lost my user manual.
Most likely a blockage in the spray arm / nozzles or the draw is not fully sealing the water inlet allowing the water to bypass the spray arm /nozzles and go directly into the machine.
Mar 28, 2015 | AEG Dishwashers
Neither the upper or lower wash arms spin.
Circulation pump might be faulty. or spray arms are blocked. remove spray arms and clean them and try it again.
Mar 15, 2014 | KitchenAid 24 in. KUDP01DL Built-in...
Middle spray arm clogged
no it cant to clean a dishwasher good the best thing you can do is run lemeshine often found at a publix or wallmart in the dishwasher detergant isles . if you try to sepperate the arms ther is a very good chance you will break the water tight seal and it cannot be fixed without replacement.
Jun 02, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Gritty film left on almost all dishes, rinse aid level seems to always remain at full, but apparently not rinsing well.
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Mar 11, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Top rack dishes not getting clean
Hey- Two things could be wrong.- clog, or bad motor. Sump screen needs to be cleaned of debris. Removal of sump cover to access screen requires torx bits and some patience. Replacement of pump requires pulling out dishwasher to access bottom. Motors fail when seal between motor and pump fails. Will still operate, but become weaker over time. Parts available- motor about 100$ at appliance parts pros.appliancepartspros. Hopes this helps- Thanks- ED
Feb 26, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
THE UPPER TRY DOES NOT GET CLEAN, THE SPRAY ARM ON THE BOTTOM OF THE UPPER TRY AND THE SPRAYER AT THE TOP DO NOT TURN?THE WATER THAT COME SOUT AT THE BOTTOM IS WEAK ? WHY?
It could be that your dishwasher is not getting enough water. Let the water fill the dishwasher, set the spray arms in the same direction. Add a large pot of hot water and run the dishwasher. Open the door and check to see if the spray arms have moved. If they have moved, replace the water inlet valve.
Remove the 4 screws holding the lower kick panel. Remove kick panel. Locate the water inlet valve. This is the electrical valve where the water pipe hooks into the dishwasher. Shut off the water to the Dishwasher and electrical to the dishwasher. Disconect the 2 wire plug at the water inlet valve. Disconect the water supply to the dishwasher at the valve and disconect the rubber hose attached to the valve. Install new valve and test machine.
I hope this helps.
Jan 05, 2010 | Dishwashers
Dishes on the lower rack are not cleaning properly
heatman101
xnbbh
Jul 08, 2009 | Indesit 24 in. D63 Free-standing...
The top tray of our Indesit DI620 isn't washing properly. I suspect that the spray arm isn't squirting water, it isn't impeded by badly stacked crockery. I can't work out how to detach it so that I can...
If you want to see if water is getting to the upper spray arm you can open the door while it's washing for a quick look before it stops or if you can manually press in the door latch with the door open you'll get a good look. You'll also get water in your face. It's probably a pump problem. The vanes in the pump can get damaged which means the pump can't push the water to the upper arm.
Nov 29, 2008 | Dishwashers
Indesit D63 stops mid cycle
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Jul 21, 2008 | Indesit 24 in. D63 Free-standing...
Dishwasher
LITTLE BIT CONFUSING, BUT WITH BASICS, CHECK FOR RUBBER WASHER THEN USE PLUMBERS TAPE TO SEAL THREAD OFF PROPERLY WHEN YOU REASSEMBLE.ALSO MAKE SURE IT ISNT THE TAP THATS CAUSING THE LEAK.
Aug 22, 2007 | Indesit 24 in. D63 Free-standing...
Indesit 24 in. D63 Free-standing Dishwasher Logo
158 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Level 1 Expert
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
