Question about Garden
I have a 2005 MTD 42" riding lawn mower. Transmission feels like it is surging, all speeds. It is similar to what you would feel if you were pushing the "clutch" in and out quickly. Have changed both the engine drive and transmission belts along with the variable speed pulley assembly. I can hear a belt slap sound when it does it which is over 50% of the time. The only other issue with this 5 year old lawnmower is that the Clutch pedal no longer contacts the parking brake switch with the parking brake set, could this be related?
  • 857 Answers
This Problem is Usually caused by one of the Following:
1- The Shifter Linkage is Binding or Bent and Requires Lubricating and Straightening. 2- The Shift Keys are Worn and Require Replacing.
To do that You have to Remove the Transaxle from the Mower and Remove the Top Half of the Transaxle Housing and Disassemble Part of the Transaxle to Replace the Shift Keys.
Before you do that try these steps and see if it helps you:
1.Park the mower on a flat level surface with the engine off. Locate the self-propel cable on the left side of the mower handle. Loosen with a metric socket the cable clamp that secures the cable housing. Do not remove the hex nut, just loosen it. Wipe away any dirt and debris with a clean rag.
2.Adjust the self-propel cable by pulling the cable downward (toward the engine) to remove all the slack from the cable. Once all the slack is gone from the cable, push the cable jacket up an eighth of an inch away from the engine. Hold the cable jacket in this position, then tighten the hex nut that secures the cable housing. Apply one drop of machine oil to the top of the cable where the cable housing and cable meet. This will lubricate the inside of the cable the entire length.
3.Test the mower for normal operation. If the transmission still does not engage, the traction control cable must be adjusted. The place of adjustment for this cable is the transmission knob, which uses two jam nuts and the clamp assembly on the handlebars.
4.Loosen on the handlebars the two jam nuts (metric hex nuts) that secure the transmission knob and cable together. Wipe away any dirt and debris with a clean rag. An adjustment must be made so the transmission begins to engage when the bail (control knob) is one inch below the upper handle bail stop; pushing the transmission knob forward one inch should engage the transmission.
5.Slide the transmission cable jacket up or down (toward or away from the engine) until slight resistance is felt in the cable jacket with the control knob one inch below the upper bail stop. Tighten the hex nuts once the correct adjustment has been made. Apply one drop of machine oil to the top of the cable where the cable housing and cable meet. This will lubricate the inside of the cable the entire length.
6.Test the mower for normal operation of the transmission in all forward gears. If the transmission still does not engage, there is an internal problem with the transmission.
Posted on Aug 19, 2010
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
Belt diagram for 46" mtd yard machine riding mower
You can find the belt diagram for the MTD Yard Machine mower in the MTD Owner Manual. The diagram is on page 21.
Feb 02, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
I just replaced the drive belt on my Troy built auto transmission Bronco 42" riding mower, and now it goes a lot slower. The belt seems to be routed correctly
The bronco is a variable speed mower from what I remember. There is a belt that goes from the crankshaft to a variable speed pulley and another belt from the variable to the transmission. If your 1st belt is too long it will never get up to speed. Do you have to push the pedal down further now than before to get it to move. ? If so your main belt is too long.
Jun 05, 2011 | Mtd Drive Belt 42"
Riding mower surges in forward and not reverse. It
Ok first of all is not an automatic.Its a pedal operated transmission. The motion is accomplished by tightening a belt with a moveable idler and it is only shifted with a lever to forward and reverse. The belt probabley has a burnt spot in it and it hits that spot and it feels like a surge. Replace the motion belt
Mike
Oct 19, 2009 | Garden
What size drive belt goes on mtd mastercut riding lawn mower
Visit mtd.com for an exact answer.
If you have the belt, take it to a auto parts or farm supply place for an exact replacement without shipping.
I hope this helps you
a
Oct 10, 2009 | Mtd Arnold Corp 38" /42" Mulch Kits
Riding mower will barely move
Sounds like it time for a tuneup. Air filter changed, Spark plugs replace and oil changed, plus sharpen the blades while you are at it.
Sep 26, 2009 | Mtd 22" Yard Machine Push Mower
Nooo parts
Find a local MTD dealer, lawn mower repair shop, they should be able to get you one. The Cub Cadet is made by MTD.
Sep 15, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Engine on riding lawn mower surging
Dirty air cleaner.
Clogged fuel filter.
Replace or clean both...
May 29, 2009 | Garden
Garden Logo
143 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
