Question about Krups Small Appliances Espresso Machine
Krups xp 7240 cofee machine says error code 09
3 Suggested Answers
SOURCE: krups xp 7240 cofee machine
for the error code 06. (this is what I got from a guy on a tech support line)
The issue is with the waterfilter. If you haven't changed it for a long time - change it. If you recently got a new one follow these steps:
- take the filter out
- unplug the machine from electricity
- plug it back in
- install filter (go into prog- service- install new filter)
It should remove the error. Haven't tested that yet, but that's what I got :)
Good luck
Posted on Apr 27, 2009
  • 14 Answers
6
Pump in actuator down phase
The flow has not dropped (> 50ml/min)
after the actuator has been filled to the
maximum (80ml); there is a water
leakage and the actuator does not fill
Look for the leakage source:
hoses, actuator, priming valve?
Switch or distributor switch
control fault: incorrect detection
of cams  error in distributor
position in cylinder descent
phase.
Flowmeter hoses changed over
Distributor problem (leakage at
drain ..)
Faulty connection between the
2 picto boards
If no leak detected, replace
power board V26 with V29
Posted on Jul 07, 2009
Error code 06 on Krups xpt 7240
Look for and remedy any internal leaks. If error 6 remains then expect to replace the distributor assembly.
Aug 20, 2014 | Krups XP Coffee Makers & Espresso Machines
Hello.place for information for KRUPS XP 7240 -ERROR CODE 5
http://www.getvn.com/333/link/Krups+Xp+7240+Service+Manual.html
Nov 10, 2010 | Heating & Cooling
Error code 07 on my Krups XP 7220 coffee machine
Error code 07 on my Krups XP 7220 coffee machine what to do? Nick
Oct 26, 2009 | Krups Small Appliances Espresso Machine
Error Code 9 on a Krups XP7240 Expresso machine
After I changed piston sealing I get the same error 09. It was caused by missing connection to the thermoblock temperature sensor. In my case both connectors for thermocouple were cracked. They are located directly on the body of thermoblock, below two fuses, covered by rubber housing. After I solder them again on the position error 09 disappeared. Unfortunately it is necessary to open at least front panel of the machine. Moreover I tink that there is also important to save polarity of those two cables.
Jun 06, 2009 | Krups XP4030 Espresso Machine
Error code 06
The error 06 happens because one of the services – Rinsing, Cleaning, Descaling or Replace Water Filter is out of date.
Start in a sequence and go through ALL services. Go to “Machine Information” in “Programme” Mode to ensure that “Last” reads zero or a maximum of something below 10 and your machine will NO longer give start up problem. Please report it if this still occurs, because a computer reset can be done.
Mar 13, 2009 | Krups Small Appliances Espresso Machine
I need a manual for krups xp 7240, krups xp 7200, krups xp 7230
I have the manual, send an email to me at inouside@hotmail.com and I will reply to you with the manual in pdf format.
Mar 04, 2009 | Krups XP7230 Compact Super Automatic...
Krups XP-7220 Error code 01
Go to krupsusa.com and click on "instructions" they should have the manual to download.
Jan 02, 2009 | Krups Orchestro Dialog FNF2 Espresso...
Krups xp 7240 cofee machine says error code 06
- plug it back in
Good luck
Nov 01, 2008 | Krups Small Appliances Espresso Machine
Krups xp7420 espresseria automatic
am o proare 01 la un espesor krups 7220/7240
May 11, 2008 | Krups Coffee Makers & Espresso Machines
Krups Small Appliances Espresso Machine Logo
316 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
