Question about Canon imageCLASS D480 Black and White Copier
Where can i find a software for this printer - Canon imageCLASS D480 Black and White Copier
  • 1,219 Answers
Http://software.canon-europe.com/
Posted on Aug 20, 2010
It print all color blue
use the printer utilities
Using the Printer Utilities
how to
Accessing the printer software You can access the printer software from most Windows applications, or from the Windows Start menu.
When you access the printer software from a Windows application, the settings that you make apply only to the application you are using.
When you access the printer software from the Start menu, the settings that you make apply to all of your Windows applications.
Refer to the appropriate section below.
From Windows applications
Follow the steps below to access the printer software.
Click Print or Print Setup on the File menu. In the dialog box that appears, click Printer, Setup, Options, or Properties. (Depending on your application, you may need to click a combination of these buttons.) The printer software opens.
From the Start menu
For Windows Me, 2000, NT 4.0, 98 and 95 users, click Start, point to Settings, then click Printers.
For Windows XP users, click Start, then click Control Panel, then click Printers and other hardware, then click Printers and Faxes.
For Windows Me, 98, and 95 users, select your printer, then click Properties on the File menu.
For Windows XP and 2000 users, select your printer, then click Printing Preferences on the File menu.
For Windows NT 4.0 users, select your printer, then click Document Defaults on the File menu.
May 13, 2015 | Epson L210 - multifunction printer /...
Where do i get the printer software to load on my laptop to have access to the printer. the printer has no disk drive to load the software.
Go to the website of your printers brand. Click on support section - printers. Click on software. Select your printer model and then download the software.
OR
In the google search type the make brand and model no of your printer and add software in the end. You will be taken to various sites and you can select which you think is appropriate
Oct 25, 2011 | Office Equipment & Supplies
Setting up a new printer
Hi.
Before connecting the printer install the driver software provided with the printer.
If you have misplaced the printer disk, download the software from manufacturer website. Most links available clicking here.
Using the link above you can also locate user manuals.
Connect printer cable only when prompted by printer software setup wizard.
If printer is a network printer follow run time instructions provided by software after choosing network printer option.
Aug 09, 2010 | Office Equipment & Supplies
My computer doesn't recognize my printer even several attempt of software installation is performed.
Before you made several attempts to install you Epson Printer Software.Did you Uninstall the software first? To reinstall your Printer Software . The old program that did not work properly has to be uninstalled. Go to your Add and Remove Programs In your Contol Panel and uninstall your Epson Printer Program Software .Then restart your computer.Then try Re-installing your Epson Printer Software.
Jul 30, 2010 | Epson Office Equipment & Supplies
Lexmark z45 not working with windows xp. i installed a lexmark z45 on my laptop that has windows xp and it will not print
Check the printer status:
1 Click Start > Control Panel > Printers and Other Hardware > Printers and Faxes.
2 From the Printers folder, double-click the Lexmark Z45 printer icon.
3 From the Printer menu, make sure:
– Default Printer is selected.
– Pause Printing is not selected.
Check the printer port:
2 Click the Ports tab.
3 From the list of ports, select the USB printer port. If the USB port is not listed, uninstall and then reinstall the printer software.
4 Click Apply.
5 Click OK.
Make sure you have not installed multiple copies of the printer software:
Windows XP: From the Start menu, click Control Panel Printers and Other Hardware > Printers and Faxes.
In the Printers folder, make sure there is only one Lexmark Z45 printer icon. If you have installed multiple copies of the printer software, uninstall each copy. Then restart the computer and reinstall the printer software.
If the printer port is incorrect or you have installed multiple copies of the printer software, uninstall and then reinstall the printer software:
1 From the Start menu, click Programs or All Programs Lexmark Z45 Uninstall.
2 Follow the instructions on your screen to uninstall the printer software.
3 Restart your computer.
4 Reinstall the printer software
Oct 27, 2009 | Lexmark Color Z45 InkJet
Message about software not in effect
First - did you have the printer turned on before installing the software? Printer MUST be ON!
Second - did you install the software before plugging in the usb cable? Printer must be on when cable is plugged in, and should not be plugged in until installation software says to plug it in.
Third - you must completely uninstall any previous printer installations you've done for that printer before attempting another installation. If the printer doesn't work after an install, you must delete the printer under "Printers" in the control panel, and check to see if you need to uninstall the software through the Add/Remove programs portion of the Control Panel. If you do a new install over a bad install, the printer still will NOT work. You must meet ALL these conditions to make the printer work.
Last, but not least, download the printer software from the manufacturer and not from a third part vendor, and make sure you select the correct operating system when you select the software to download.
Apr 20, 2009 | Compaq A1500 All-In-One InkJet Printer
Hp printer f 380 all in one
Hai
I have provided the links where you can download the software depending on the Computer Operating System.
Windows 2000 ----> Download software
Windows XP ----> Download software
Windows Vista ----> Download software
Please let me know if you have any difficulties.The software link i provided are genuine HP Software Drivers.
Thanks
Riz
Jul 27, 2008 | HP DeskJet F380 All-In-One Printer
Canon imageCLASS D480 Black and White Copier Logo
old marine
old marine
