Question about Health-O-Meter Health & Beauty
Health o meter HM7539, Massager, circut Diagram, internal Fuses, The product opperates at a 2.8 v capasity. I the red light indicates it is recieving power ,however themassage and heater unit dose not work.Therefore I suspect an internal fuse is blowen. That's why I seek a scamatic as well as repair options.Ps. I'm an electrical enginer and a UAW brotherhood of electrical workers of America.
MicrowaveSvc
  • 9086 Answers
SOURCE: GE JVM1350WW
That listing is confusing, but they show two fuses but both with the same reference number of 1626.
There are also two thermostats (aka "switch, t-stat") at refs 1430 & 1431 which may be open. They should be normally closed.
One is on the magnetron (the one I suspect) and the other monitors the cooking cavity.
The one on the floor of the chassis should be normally closed. It is the flame sensor.
There should be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting & testing parts.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
  • 50 Answers
SOURCE: power windows
sounds like you have a problem with the gem module, (generic electronics module). This is a common problem with most ford trucks and suv's. you can find it behind the knee bolster on the drivers side under the dash.... hope this info helps.
Posted on Aug 18, 2008
  • 132 Answers
SOURCE: Indicators keep blowing fuses Hazards ok
THE WIRES ARE NORMALLY PUSH ON LIKE SPEAKER WIRES BUT IF IT IS MELTED THERE IS A SHORT IN THE WIRE SOMEWHERE IT COMES OUT OF FUSE BOX THEN TO RELAY UNIT THEN FROM RELAY TO SWITCH THE RELAY MIGHT BE FAULTY CAUSING WIRES TO HEAT UP RELAYS ARE LOCATED IN FUSE BOX THERE IS ALWAYS MORE THAN ONE SO SWAP FOR ANOTHER RELAY REPLACE FUSE AND TRY LIGHTS AGAIN TO SEE IF THE RELAY IS THE PROBLEM HOPE THIS HELPS GLENN
Posted on Nov 15, 2008
  • 12 Answers
SOURCE: meter fuses keep blowing out on 1996 nissan altima
you have a short to ground somewhere. Look for worn wires, loose connections, any work recently done.
Posted on Dec 09, 2008
tripletauto
  • 1450 Answers
SOURCE: 2005 silverado aldl no 12v power
glad you got it fixed
How o fix a my homemedics massager
Heyy..!!
I have used inada massage chair .Thsi is the best massager. Going to spa daily is more costly so foot massager at home is a best option to take benefits related to the health gives you more comfort and relaxation.
http://massagechair.me/
Jun 23, 2017 | Health & Beauty
I need a replacement cord (power adapter)for the Brookstone Max 2 cordless massager. Can anyone help me?
We do not sell parts nor do we have resources to find them for products like this.
Feb 09, 2017 | Brookstone Health & Beauty
I need a replacement cord for the Brookstone Max 2 cordless massager
i am looking for a cordless charger for MAX 2 Dual-Node Percussion. if any one has please let me know i will buy from them. or let me know where I can buy them.
Sep 06, 2014 | Brookstone MAX 2 Dual Node Percussion...
Proliant ML350 g4 internal health led: red and green alternate
Open the case and turn it on. There should be corresponding red light indicator inside or possibly the back.
Dec 03, 2012 | HP ProLiant ML350 G4 Server
On one of our HP DL360 G5 systems every time after soft reboot the server cannot be booted back. This is 100% reproducible also with Cold boot. Can someone help us find what internal component is...
The simplest way is to check Insight Manager. Type localhost:2301 on a web browser locally. Or, servername:2301 for remote access. You need local Administrator password.
Insight is only available if it was set up with a Smart Start disk. It's that pack that comes with all HP servers, but can be downloaded as well. Best practice is always install.
Don' know what IML is, and ILO has no baring to problems.
There is Insight Manager link on specs.
http://h18004.www1.hp.com/products/quickspecs/12476_na/12476_na.html
Nov 12, 2012 | HP ProLiant DL360 G5 Server
Rci 2950 no audio period rx or tx
Check TR38 I have seen caps in the circut
go bad more then once if you have a schematic you should be able to find it if one
is bad,a capasator meter would help but you
can check them with a ohm meter.
Good luck.
Nov 21, 2008 | Radio Communications
Body ECU
The problem is not 100% solved. I have figured out that the problem is in the ground circut for the "Body ECU" system. The only circut effectfed is the door, ignition switch ilumination. If a ground is forced to the circut it works oK.
What I need is a diagram of the internal workings of the "body ECU". I have not yet removed it but it can be much more than a bunch of relays. By the way tell the guy with SD22 Nissan to search SD22. The sole distributor for that product is located in SanFran.
Jul 05, 2008 | 2003 Toyota 4Runner
Health & Beauty Logo
95 people viewed this question
Top Health-O-Meter Health & Beauty Experts
creative_lac
Level 1 Expert
Shehu Pro
Shehu Pro
NOEL
NOEL
Are you a Health-O-Meter Health and Beauty Expert? Answer questions, earn points and help others
