Question about Arrow CHROME STAPLE GUN ARROW IND. STAPLERS
Cant get staples into it!!! - Arrow CHROME STAPLE GUN ARROW IND. STAPLERS
  • 843 Answers
Sue, First, confirm that you have the right size staples. They are sized in two dimensions - width and length. The most common width sizes are T50 and T35. Your stapler and your pack of staples should have a number such as this. Your stapler will accept staples only of the correct width but of various lengths. The lengths are given in fractional inches - 3/8 inch and 1/2 inch are common.
But perhaps your problem is how to open the stapler. It does not swing open like a stapler you would use for papers. Instead, it has a sort of spring piston that has to be removed from the back-end of the stapler. If you lay the stapler down flat on the table so that the hinge of the handle is at the upper left corner, then what I am calling the back-end of the stapler is the lower right corner. Pick up the stapler so that you are looked directly at this back-end. There is a small metal square at this corner that is spring-loaded and is held in place by a little hook. Push in on this metal square as you move it up (or is it down?) to disengage the hook. Now the piston will pull out easily. Put your staples in the hole (they will only go in one way) and replace the piston. I hope you found this helpful Good luck!
Posted on Aug 19, 2010
Cant open jt27 staple gun to load staples
Hi Maria, I'm sorry you are not having luck with your JT27 stapler. Unfortunately you did not purchase the correct staples for this tool. The JT27 Stapler uses the JT21 staples in a green box. The staples come in 3 different sizes (1/4", 5/16", 3/8"). You can purchase these staples online or at your local Home Depot or Lowe's Store.
As for opening the tool - please see the attached picture for assistance.
May 07, 2015 | Arrow Tools & Hardware - Others
A staple jammed in the moving part (driver?) when using to staple. How do I clear the jam?
first remove the the spring loaded rod that keeps the staples in place and tight, if you can see any part of the jammed staple , grab it with pliers or vice grips and pull it out any way you can , might be more than one staple jammed too, turn stapler upside down to dump out any loose staples and debris , keep working until she frees up , if you still cant get it out might have to loosen screws up that hold it together, a little light lubricant will be good for it too . then load it back up with staples and put tension rod back in, i always try to keep it full of staples at all times ,like when it gets 2/3 empty , fill it up, this will ensure good tension on the business end of the staples!!
Feb 05, 2011 | Heavy Duty Arrow Ht30 Light Wire Hammer...
After shooting a staple the driver does not return up into the stapler.
obvious answers are 1. a burr on the striker, 2. a bent striker. 3. a trapped staple 4. a broken return spring. other than that I cant help you without seeing it.
Feb 02, 2011 | Senco 300120n Sksl Medium Wire Staple Gun...
Cant staple from driver but can staple directly from the machines panel ... particularly 8x14
Most Likely the issue is resolved by configuring the driver properly. If you right click the printer under Printers and faxes in your start menu you need to go to properties, then to the configuration tab and then to Auto Configuration. it will then communicate with the printer and find out what options are installed and then enable you to use stapling from your computer. Make sure to select where the hands are pointing also. thanks. you will understand.
May 15, 2009 | Sharp MX-3501N All-In-One Printer
Cant find replacement brads for swingline
the problem was not with a stapler it was with an electric brad nail gun made by swingline , after researching this, my swingline (printed right on the gun) turned into a "powerfast electric nailgun model 32003" which will take arrow replacement 1" brads .
May 04, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Surebonder 4.8 v cordless stapler
with mine there is a fine spring on the plunger which holds the staples in which i restretch every now and then you could also try checking for jammed staples and putting one or two drops of oil on the shaft that pushes the staples down after the oil operate afew times empty of staples see if this helps bestaluck glenn
Oct 26, 2008 | Tools & Hardware - Others
Arrow CHROME STAPLE GUN ARROW IND. STAPLERS Logo
465 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Mike
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
