Question about LG PREMIER - RD-JT50 RD-JT52 - AJ-LT50 DLP Projector
How do I reset the lamp counter - LG PREMIER - RD-JT50 RD-JT52 - AJ-LT50 DLP Projector
You CAN reset the lamp hours. It is surprisingly easy.
Hold UP on the projector until the lamp hours appear. Then press left or right to reset.
This took me a while to find! But it's in the service manual.
Posted on Oct 18, 2011
  • 229 Answers
Problem
lamp hours reset
Solution :
you can not reset the hours of use in the lamp do that information is stored in a micro chip on the lamp.
sorry
Rate me please
Posted on Aug 19, 2010
2 Suggested Answers
SOURCE: cannot reset lamp counter on
Hi, I don't know if this is to late but oh well, hold down the exit button on the projector panel for 5 secs, and then press auto on the same panel after, this should reset the hours back to a lovely zero
Posted on Sep 08, 2011
How to change lamp timer on sanyo plvz4
Hello
* Turn the projector ON, and press the MENU button to display the on-screen Menu. Select the 'setting' menu with point UP/DN button. Press '>' button to acess sub menu items.
* Select the Lamp Counter reset and press the OK or '>' button. "Lamp replacement counter reset?" will appear. Select "Yes" and then press OK or ">" button
8 Another confirmation dialogue box appears, and select "Yes" to reset lamp replacement counte.
** Do not reset the lamp replacement counter without implementing lamp replacement. Be sure to reset the lamp replacement counter only after replacing the lamp.
Dec 17, 2011 | Sanyo PLV-Z4 Multimedia Projectors
Cannot reset lamp counter on benq mp620 projector, projector bulb has been replaced but lamp counter warning is displayed on startup and requests buld change and reset of counter. So I'm stuck in a...
May 26, 2011 | BenQ MP620p DLP Projector
How to find out lamphour in PLC-XT11
hi
do the follwing setting on your projector to reset the lamp hour
1.Turn projector on, press MENU button and ON-SCREEN MENU will appear. Press POINT LEFT/RIGHT button to move a red frame pointer to SETTING Menu icon
2 Press POINT DOWN button to move a red frame pointer to "Lamp counter reset" and then press SELECT button. The message "Lamp replace counter reset?" is displayed. Move
the pointer to [Yes] and then press SELECT button.
3.Another confirmation dialog box appears and select [Yes] to reset Lamp Replace Counter.
ok
Feb 02, 2011 | Sanyo PLC-XT11 Multimedia Projector
Canon LV-S3 how to check hours on the lamp? do I have to have unit hooked up to an input source?
Be sure to reset the lamp replace counter after Lamp Assembly is replaced. When the lamp replace counter is reset, the LAMP REPLACE Indicator stops lighting.
Note : Do not reset the Lamp Replace Counter until after the projection lamp is replaced.
1. Turn projector on, press MENU button to display the On-Screen Menu. Press Point left or right button(s) to move the red frame pointer to the Setting Menu icon.
2. Press Point down button to move the red frame pointer to "Lamp counter reset" and then press SET button. The message " Lamp replace counter reset? " is displayed.
Move the pointer to [Yes] and then press SET button.
3. Another confirmation dialog box appears and select [Yes] to
reset the lamp replace counter.
This projector uses a high-pressure lamp which must be handled carefully and properly. Improper handling may result in accidents, injury, or create a fire hazard.
 Lamp life may differ from lamp to lamp and according to the environment of use. There is no guarantee of the same lifetime for each lamp. Some lamps may fail or terminate their life in a shorter period of time than other similar lamps.
 If the projector indicates that the lamp should be replaced, i.e., if the LAMP REPLACE INDICATOR lights up, replace the lamp with a new one IMMEDIATELY after the projector has cooled down.
( Follow carefully the instructions in the LAMP REPLACEMENT section of this manual. ) Continuous use of the lamp with the LAMP REPLACE INDICATOR lighted may increase the risk of lamp explosion.
 A Lamp may explode as a result of vibration, shock or degradation as a result of hours of use as its lifetime draws to an end. Risk of explosion may differ according to the environment or conditions in which the projector and
lamp are being used.
IF A LAMP EXPLODES, THE FOLLOWING SAFETY PRECAUTIONS SHOULD BE TAKEN.
If a lamp explodes, disconnect the projector's AC plug from the AC outlet immediately. Contact an authorized service station for a checkup of the unit and replacement of the lamp. Additionally, check carefully to ensure that
there are no broken shards or pieces of glass around the projector or coming out from the cooling air circulation holes. Any broken shards found should be cleaned up carefully. No one should check the inside of the projector
except those who are authorized trained technicians and who are familiar with projector service. Inappropriate attempts to service the unit by anyone, especially those who are not appropriately trained to do so, may result in an
accident or injury caused by pieces of broken glass.
Dec 24, 2010 | Canon LV S3 Lamp
Replaced bulb but still getting "lamp will fail soon replace" warning
When you replace the lamp, you need to reset the lamp counter as well. The procedure for this should be in the owner's manual. This counter is a guide only. Lamps have an expected lifetime and the message indicates that the lamp is nearing that lifetime. Once reset, the counter will again trigger the message once this new lamp reaches that usage time.
Dan
May 06, 2010 | Optoma H30 Multimedia Projector
How do I change the light bulb in the Sanyo pro traX multiverse projector
unscrew the lamp door on the bottom of the projector, unscrew the lamp, remove the lamp, replace with new lamp, screw in, replace door, turn on, and reset lamp counter (menu-settings-lamp counter reset-yes)..
Nov 03, 2009 | Sanyo PLC XU30 Multimedia Projector
How to reset the DLP TV Lamp Counter
Press and HOLD the ENTER (or OK) button on the TV
Press and HOLD the MUTE button on the REMOTE
(hold both until the LAMP LIFE HOURS appears on the screen)
Let go of the REMOTE button first, then release the button on the TV
We suggest writing your lamp hours on a peice of masking tape and taping it to the back the TV for future reference.
To reset the lamp counter, press SELECT (or the button in the middle of the direction arrove buttons). Hit SELECT a second time to confirm clearing the lamp counter For certain models, you might have to tweak these steps slightly…offer your inputs!
May 16, 2009 | Zenith Z44SZ80 Television
Lamp life indicator reset
Click Sanyo Support to download Instruction Manual copy and check page 39 for details about Lamp Reset procedure.
Apr 30, 2009 | Sanyo PLC-XT16 Multimedia Projector
Reset lamp life counter pt-50dl54j
To reset the lamp timer, turn the TV on first. Now hold VOL DOWN on the TV and MUTE on the remote until a message appears on the screen about the lamp timer being reset. Make sure the remote is pointed toward the TV to receive the signal.
Feb 19, 2009 | Panasonic Televison & Video
LG PREMIER - RD-JT50 RD-JT52 - AJ-LT50 DLP Projector Logo
3,480 people viewed this question
Top LG Office Equipment & Supplies Experts
jasbo
jasbo
Jaime Hernandez
J.D. Browning
J.D. Browning
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
