Question about Malibu ML88TL 88Watt Low Voltage Power Pack with Timer
THIS IS THE SECOND TIME THAT I HAVE COME ACCROS THIS PROBLEM..........TIMER SEEMS TO WORK BUT WHEN THE TRIP GETS TO THE SETTING IT DOSEN'T SEEM TO HAVE ENOUGH POWER TO OVERCOME THE TENSION OF THE CONTACT SPRING
The clock motor has gotten weak, and is overheating and will stop working.
Buy cheap plug-in timer, set power pack to override, then plug power pack into cheap timer.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Posted on Mar 24, 2011
My malibu timer seems to get stuck before turning itself on. It take 1 hour to trip the timer to come on?
1) Clock motor is worn out, or gears are dirty:
2) Take apart clock motor and add white grease to gears
Set override to ON, and plug timer into cheap wall timer.
Take advantage of 5-year warranty.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 10, 2013 | Malibu ML300RTW - Low Voltage Power Pack...
Even though timer starts the microwave doesn't start cooking
read this post
Parts:
magnetron: W10131681
HV capacitor: 815124
HV diode: W10201950
HV transformer: 8171873
Of note: generic parts are cheaper and will work as well.
Oct 20, 2009 | Whirlpool GH7155XHS Microwave Oven
T101 Intermatic Timer will not turn lights on or off
You have a weak timer motor. The T101 is notorious for it. I have 6 on my property and have had that problem numerous times. You need to replace the guts of the timer.
Jul 05, 2009 | Hardware & Accessories
Timer doesn't come on after being set. Operates landscape lights
Check your circuit breaker that feeds the timer circuit in your main electric panel. It may have tripped. Sometimes when a breaker trips it's hard to tell visually, so turn the breaker off, then back on.
Also, the circuit that feeds the timer may be on the load side of a GFCI receptacle. Look for one that has tripped. Sometimes they are found in obscure places.
Apr 26, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Washer trips circuit while filling tub
Sound like the inlet valve coil may be shorted. Remove console and check wires from water valve to control. If wires look ok, the inlet valve has a problem
Mar 18, 2009 | Maytag PAV2300 Top Load Washer
Sleep mode
There is an On Display Menu (ODM). You can access it by pushing the button located on the monitor. Use +- buttons to navigate in the menu. Here you can switch off the sleep mode or change the sleep settings. I have a simular problem... I try to turn off the power save function but it seems like it dosen´t want to understand this...
Oct 08, 2007 | Compaq TFT5015 15" LCD Monitor
Malibu ML88TL 88Watt Low Voltage Power Pack with Timer Logo
116 people viewed this question
Top Malibu Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
