Question about Dell E773C 17" CRT Monitor
When you push the power button on the monitor the green light comes on for a few seconds then goes to yellow. Any ideas? It is a Dell e773c connected to a HP Pavillon 700
    Sergeant:
  • 179 Answers
Please check the vga connection cable. It may not connected to the computer. If you have dual monitor support (2 monitor connection on the PC) try other vga port.
Posted on Aug 19, 2010
I have a Dell e173pfb monitor. i push the power button and green light comes on screen comes on for a second with no problem then the backlight goes off. I can still see an image with a flashlight though....
You need a new backlight inverter board. If you dissasemble the monitor you will see a circuit board with 4 2-wire connectors connected to it. This is the board you need to replace. Typically they run from $15 to $40. Usually just easier to replace the monitor. Another idea is to reduce brightness levels on the monitor in the menu while looking at it with your flashlight. Then power off then power on the monitor and it might stay on longer.
Aug 16, 2010 | Dell E173FPf 17" TFT LCD Flat Panel...
Mitsubishi VS-70707 rear projection TV
DOES THE LIGHT BLINK IN A PARTICULAR PATTERN?
Jan 31, 2008 | Mitsubishi WS-55807 TV
No picture on monitor (monitor turns itself off)
You will need to take it for repairs.
Sorry
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 23, 2010 | Dell E773C 17" CRT Monitor
Monitor comes on for a split second , and then off
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Dell monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor goes black after a few seconds of being turned on. what can i do?
Dell monitors have a power button in the bottom right corner. Be sure this light is green, and not yellow or off. If it is yellow, your PC is not on. If you are sure it is, shake your mouse to see if it lights up. If not, make sure it is plugged in in the back of your PC.
Cheers
dmklunk122
Dec 27, 2009 | Dell Computers & Internet
Xbox 360 wont turn on
try a new power cord to see if thats the problem, then buy a new one.
May 30, 2009 | Microsoft Xbox 360 Arcade
Dell monitor blank. nothing appears on screen. light is blinking by minitor power button, but nothing at all on screen. I hooked up to my laptop, still nothing. Checked power/ tried new power cable. No...
Make sure you set up your laptop to display to a second screen. Depending on your Operating system, go to your display properties and go to the settings tab. Then click on the second monitor and enable it.
Apr 08, 2009 | Dell E773C 17" CRT Monitor
Vusys hd19a monitor is always on standby
Cut and paste from another site:
I was called to repair similar incident last week. A Compaq box (don't remember the model) with a 'smart' usb keyboard. By this I mean that the keyboard had a row of what I'll call hot buttons. The client had pushed a button with a moon on it causing the monitor to go into sleep mode. I suspect that whatever key you pushed had the same effect.
After plugging a known good monitor into the faulty box I verified that the box was OK. This left me to think the monitor itself had a problem. Plugged the suspect monitor into a known good machine.. and it worked fine!!!
Set machine and monitor to original configuration and still had no video. Decided that the monitor was too smart for its own good and maybe there was something in the monitors menu. Pushed and held the 'menu' button on the monitor for a few seconds and menu comes forward. Green power led also comes on (surprising me) so I powered up the computer and lo and behold the problem is fixed!
Dec 11, 2008 | Microsoft Likom HD19A 19" LCD Monitor
Viewsonic VA903b Flashing green light (slow)
Hi..there,
It's seems you got a busted backlight inverter problems... Need replaced with a new one. Happy Holidays!
Dec 03, 2008 | ViewSonic VA903B Monitor
Monitor won't turn on without help.
Do you have a second monitor or can you borrow one to check if the fault lies with the monitor or the PC?
If the monitor is at fault then there is not much you can do yourself. I suggest you contact Dell and get them to replace it under warranty. Most LCD monitors have a 3 year warrantly, at least they do in the UK.
cheers
Aug 04, 2008 | Dell E177FP LCD Monitor
Dell E773C 17" CRT Monitor Logo
116 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
