Question about Refrigerators
My fridge is leaking on the inside. I took off the back to find the drain tube and drip pan but I can't find it. Am I overlooking it or is it located somewhere else? K Mefford
  • 1 more comment
  • Robert DeStevens
    Robert DeStevens Aug 19, 2010
    CAN YOU post the model and serial number please?
  • stameff Aug 19, 2010
    Fridgidaire 125A
    Fridgidaire125A. P/N 240508000A
  • 905 Answers
You are likely overlooking it, assuming this is a residential style of refrigerator.
Find the compressor and the condenser coil. The pan will be located in the air path that is created by the fan. It may be at the bottom edge of the condenser, it may also be part of the condenser itself.
Though unlikely, your fridge may not have a pan / hose installed, removed at some previous time.
Posted on Aug 19, 2010
    I still can't find it. Could it be in the front?
I have water dripping down the back panel inside the fridge-it is constant. I wipe down the inside back wall, but hours later the water is back. The fridge appears to have a "channel" for this water
with out knowing name brand an model# i would say it sounds like there is a drain tube missing from the upper patr or freezwr area to the drain hole at the rear bottom . there is a drain pan under the refridge which catches this water then it evarperates. it also cab that the proper drain is pluged or blocked with algie which is comon try a little bleach to clean out the drain area
Nov 15, 2012 | Liebherr Refrigerators
Tip
Water Leaking Inside Refrigerator
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself. My 26 year old fridge was leaking
and I fixed it completely. It is a Kenmore
top freezer, bottom refrigerator model.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assembly, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
With lot of patience (I mean lots of it) you should be saving hundreds
of dollars. Attached are some pictures I took. Call me before you dig !
on Mar 01, 2010 | Refrigerators
During the defrost cycle our refrigerator leaks water from the freezer side out the front into the floor of the kitchen. Where could it be coming out and what will fix it?
The water from the melting ice during defrost should be guthered from the drip drain pan which is under the evaporator pipe coil and is passing though the drain tube which is conected to the dip pan and should end out on the back of the fridge to the compressor to evaporate. The problem posibly is that the drain tube is goggle either from ice or from dirt or both and the water since it can not end to compressor it overfrow from drip pan inside the freezer. So you can clean the drip pan and drain tube using a wire rod and problem will be solved.
Sep 13, 2011 | Refrigerators
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
it yourself.
To get to the connector assemble, you need to unscrew and
the light bulb fixture. Once you take the take the cover off (you will
Good luck and hope this helps
Aug 01, 2010 | Kenmore 65212 Bottom Freezer Refrigerator
Hi, I have a 2003 Kenmore Coldspot refrigerator. It has started leaking water on the inside from the top(where cold air blows) into the bottom of the fridge. the model # is 106. 73192302. The serial # is...
Hope this helpout.......
Jul 29, 2010 | Refrigerators
Fridge is dripping directly onto top shelf. It is
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you have any other question. Mike
Oct 22, 2009 | Frigidaire FRT18FS6C Top Freezer...
Kenmore fridge is leaking inside from light switch
The drip pan is underneath on the floor. You don't really need to see it. Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 18, 2009 | Refrigerators
Fridge constantly dripping wet
water inside, too much condensation from humid air entering fridge from bad seals. replace the seals. could also be that the condensate drain is clogged. if it's leaking from the bottom of the fridge, make sure the tubing is still inside the condensate pan underneath the fridge.
Aug 24, 2009 | Whirlpool Freezers
Freezer leaking into refrig compartment how do i
need to know the brand or call me at 813-270-4029
Aug 22, 2009 | Refrigerators
2005 Chrysler Pacifica-Air conditioning leak
The 05/04 Pacifica did not come with an elbow tube on the drain line for the AC drip pan. As you drive, the air flow into the tube pushes the condensate water back into the pan which is inside above the passenger floor board, the drain line is under the hood on the firewall. I spoke with the parts guy at the local Chrysler dealer, he sold me a drain tube for the 06 (~$10) and I installed it, wasn't too hard to do from the top if the engine is cold. The elbow slips on over the drain tube. Make sure to point the tube down. It only took one trip to start seeing water drip out of the tube and the floorboard started to dry up and almost three years later, the floorboard is still dry.
Apr 09, 2009 | 2005 Chrysler Pacifica
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
