Question about Cell Phones
I turned the iphone on. it asked for a passcode... i only ever use one passcode so i assumed it was that... but it wasnt.so i have just bought an iphone for nothing because i cant sort this code out. there has been no previous codes on it either
    Sergeant:
  • 226 Answers
Bypass passcode on iPhone 5s without SIM card, Siri or iTunes.
You must call the person you have bought the cell phone from and ask passcode. Apart from this, there are not many options left. In case, you cannot contact the previous owner, you need to go to service-center and they will unlock your phone for some payment.
May 03, 2016 | Apple iPhone 5S
Bought a iphone off the street,need to reset passcode
Hello
You need to restore the device in recovery mode, one moment I will get you instructions.
May 18, 2008 | Computers & Internet
How do I remove my passcode?
(Assuming you're working from iOS 9.2 or recent versions)
From the home screen, swipe the screen down to start spotlight search.
Type "Settings" in to the search field.
Once settings opens swipe down slightly to reveal a search bar at the top of settings menu.
Type "Passcode" and select the third option down which is "turn passcode off".
Enter your passcode (re-enter if necessary).
Towards the bottom of the page select "Turn Passcode Off" and enter your passcode twice again.
Jan 05, 2016 | Apple iPhone 5c
How do i unlock my iphone 4 when its disabled
Does this copied and pasted advice help you?
iOS: Forgot passcode or device disabled If you set up a passcode on your iPhone, iPad, or iPod touch, and you or someone else then enters the wrong passcode too many times, your device will disable itself temporarily. Learn what to do if you have forgotten your passcode, or if your device displays a message saying it's disabled.If you enter the wrong passcode six times in a row, you'll be locked out and you'll see this message:
  • iPhone is disabled
  • iPad is disabled
  • iPod touch is disabled
If you can't remember your passcode, you'll need to erase your device using iTunes, Find My iPhone, or recovery mode. Then use a backup to put your data and settings back on your device. Here's how. Use iTunes If you have synced your device with iTunes, you can restore your device.
  1. Connect the device to the computer you normally sync with.
  2. Open iTunes. If iTunes asks you to enter the passcode, try another computer that you've synced with. Or try the steps below to use recovery mode.
  3. iTunes will automatically sync your device and create a backup. If it doesn't, sync the device with iTunes.
  4. After the sync is complete, restore your device.
  5. When iOS Setup Assistant asks to set up your device, choose "Restore from iTunes backup."
  6. Select your device in iTunes and choose the most recent backup.
Use Find My iPhone If you enabled Find My iPhone, you can use it to erase your device.
  1. Go to icloud.com/#find to see if you enabled Find My iPhone.
  2. Click All Devices at the top of your browser window.
  3. Select your device and click "Erase [device]" to erase your device and its passcode.
  4. Use the Setup Assistant on your device to restore the most recent backup of your device.
Use restore your device as new or from a backup.
  1. Disconnect all cables from your device.
  2. Turn off your device.
  3. Press and hold the Home button. While holding the Home button, connect your device to iTunes. If your device doesn't turn on automatically, turn it on.
  4. Continue holding the Home button until you see the Connect to iTunes screen.
  5. iTunes will alert you that it has detected a device in recovery mode.
  6. Click OK, then restore the device.
Last Modified: Jul 8, 2014
Aug 04, 2014 | Apple iPhone 4 Black Smartphone
How do you get past a 4 digit code on iphone
Either you ask the seller for the passcode or take it to an apple store for a hard reset.
Mar 02, 2012 | Apple iPhone4 4G iPhone 4
I forgot my iPhone Passcode. What can I do to unlock it?
iPhone setting:*
- Auto-Lock: 1 Minute;*
- Passcode Lock: On, require passcode immediately, after 15 min or 4 hours etc;*
- Network: Turn 3G Off
Scenario 1: Home screen is active with screen on*
1. Press power button for seconds until asked to '"slide to power off"
2. Slide to power off
3. press power button to turn on iPhone
4.*When asked to enter passcode, touch the "Cancel" key, then slide to unlock
5. bypassed passcode
Scenario 2:*
1. On the screen of being asked to enter passcode, press power button for seconds until asked to '"slide to power off"
2.*Slide to power off
4.*When asked to enter passcode, DO NOT touch any key on the screen, press power button for seconds until asked to '"slide to power off"
5. Slide to power off
6. press power button to turn on iPhone
7.*When asked to enter passcode, touch the "Cancel" key on the right bottom corner, then slide to unlock
8. bypassed passcode
Notes:
1. When Network setting changes to Enable 3G: ON, "3G" signal shows up, passcode CANNOT be passed through
Go to a underground parking lot or a lift where 3G signal is weak, when 3G signal switches to "E" (Edge), passcode CAN be passed through following above steps
2. When no 3G or Edge signal, above steps don't work
Conclusion:
Seems passcode security is related to network status
Possible security hole under Edge
Jan 15, 2011 | Apple iPhone 3G
I have bought a iphone 3gs from a friend i do not have the original computer to restore factory settings on itunes. Is there any other way that i can bypass the pass code as my friend has forgotton the...
Forgotten his passcode? Odd... on a Mac, the passcode he needed was the computer's passcode, you know, the same one he needed to update anything on the Mac computer or to load any new software. Assuming that was the same as his iTunes password, he also needed that when he made itunes purchases or updated the OS on the phone. Kind of sounds like this wasn't your friend's phone after all! Sure it isn't stolen? Might want to take this one to your local Boys in Blue!
Go to an Apple store and they should be able to do it for you, unless the thing is reported as HOT! Good Luck!
Jul 08, 2010 | Apple iPhone 3G
I forgot the password for my iphone
If you have forgotten your iPhone’s Passcode you will need to restore your phone via iTunes.
1. First you have to put your phone into the restore mode which is a slightly fiddly process.
2. Plug your iPhone into your PC or Mac with the USB cable
3. Press and hold the power button at the top and then slide to power off the iPhone
4. Press the power button to power the iPhone on and keep it held while simultaneously pressing the home button
5. After a few seconds a yellow alert triangle will appear and the iPhone will say it is iPhone Restore Mode.
6. Open up iTunes and click on the Summary tab
7. Click on Restore to restore your iPhone. This will reset all your iPhone’s setting to the factory defaults, including the Passcode.
You should then follow these steps below to activate the passcode again.
  1. Click the Home button to bring up the main menu
  2. Click on Settings
  3. In the Settings screen click on General
  4. In the General screen click on Passcode Lock
  5. This will open the Set Passcode screen. Enter a memorable 4-figure code and re-enter it when prompted
  6. You will now be at the Passcode Lock screen. You can change when you are prompted to enter the Passcode. The default setting – Immediately – means you will be asked to enter it as soon as your start using the iPhone. But you can change the setting so that the prompt appears after a certain period of use
  7. Press the Home button to return to the main menu.
Dec 11, 2009 | Apple iPhone 3G
Forgot my passcode
Bad News... you may have to Restore from iTunes. Here is some info from the users manual:
Passcode Lock By default, iPhone doesn’t require you to enter a passcode to unlock it. Set a passcode: Choose General > Passcode Lock and enter a 4-digit passcode, then enter the passcode again to verify it. iPhone then requires you to enter the passcode to unlock it or to display the passcode lock settings.
Turn passcode lock off: Choose General > Passcode Lock, enter your passcode, and tap Turn Passcode Off, then enter your passcode again. Change the passcode: Choose General > Passcode Lock, enter your passcode, and tap Change Passcode. Enter your passcode again, then enter and reenter your new passcode.
If you forget your passcode, you must restore the iPhone software. See “Updating and Restoring iPhone Software” on page 204.
Set how long before your passcode is required: Choose General > Passcode Lock and enter your passcode. Tap Require Passcode, then select how long iPhone can be idle before you need to enter a passcode to unlock it.
Nov 10, 2009 | Apple iPhone 3G
Cell Phones Logo
47 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
