Question about Hayward 1.5 Hp Northstar High Performance Pump
I have a NorthStar pump. The motor went out so I have it replaced with a different manufactured motor (WEG). Same HP and even a higher SF factor than the original. The new motor draws 10 amps (rated is 8.85) and gets very hot. Any ideas.
  • Hayward Master
  • 1,363 Answers
THATS WHAT YA GOT 2 DO ..SOUNDS LIKE YOU HAVE THE WRONG MOTOR .9.6amps IS A 1 1/2 HP ... A 1HP IS 7.6amps.. SO A QUICK FIX WOULD TO GET A 3/4 HP IMPELLER , THAT WILL GET YOU BACK IN THE NEEDED HP RANGE .. welcome to the HAYWARD NORTHSTAR .. HEY IF'N I WAS ANY HELP COMMENT OR VOTE ..JAY
Posted on Aug 19, 2010
Overheating
YOU MIGHT HAVE SET THE VOLTAGE WRONG.. IS THE MAIN BREAKER WIDE OR NARROW ? IF THE BREAKER THAT RUNS THIS PUMP MOTOR IS NARROW YOU NEED TO SET THE MOTOR FOR LOW VOLTAGE 115V ON THE MOTOR LABEL THERE IS A DIAGRAM ON HOW TO SET IT.. YOU NEED TO GIVE MORE INFO LIKE PUMP MANUFACTURE, TYPE AND MOTOR SIZE HP AND SF SERVICE FACTOR..WELCOME TO MY WORLD !
.JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA.. REMEMBER TO VOTE FOR YOUR FAVORITE FIXYA GUY
May 06, 2012 | Pool & Spa
Motor shuts down after running for about half hr,after cooling down about one hr it will restart.
BAD RUN CAPACITOR . HAVE IT CHECKED, OR JUST REPLACE IT. TEST IS BEST, IT COULD BE THE MOTOR IS SHORTED, OR YOU HAVE INSTALLED TO SMALL OF A MOTOR ON YOUR IMPELLER, MOTOR HP + SERVICE FACTOR = TOTAL HP ! A COMMON PROBLEM WITH HAYWARD NORTHSTAR.. SAY THE MOTOR SAYS 1 hp AND HAS A 1.65 SF . thats a 1.65 hp MOTOR .. WELCOME TO MY WORLD.. JAY THE POOL PULP REPAIR GUY IN LONGWOOD FL.. VOTE YES IF I WAS OF HELP.. OH AND ONE MORE THING RESTRICTED FLOW, TAKE OUT THE FILTER AND RUN IT WITHOUT. YOU MUST HAVE A WORKING PRESSURE GAUGE ! BE "WELL UNDER" 30 PSI WEN CLEAN
Jun 08, 2011 | Hayward Pool & Spa
Just replaced motor overheating and shutting off.
service factor must match old motor ! motor must match impeller hp rating ! .. get the numbers off the impeller and search it on the web.. bet your motor is too small.. the easy fix ? buy the right impeller for your motor.. the things you need when buying a impeller are as fallows.. your motors hp and SF .. thats the service factor ! if the voltage is 120 v the motor set on 240 it will jump back and forth between start and run.. it will make a click ..click ..click noise .USE A VOLT METER. I smell a northstar a real pain of a pump.. REMEMBER TO BUY AMERICAN PRODUCTS (PLEASE) AND SUPPORT YOUR LOCAL POOL PUMP REPAIR GUY.. AND GIVE ME A THUMB OR TWO ,IF;N YA FEEL I WAS OF HELP ..JAY FLORIDA
Sep 10, 2010 | AO Smith 1.5 hp 3450rpm 56J Frame 115/230...
Pump gets very hot when it runs
WARNING when replacing a motor on a northstar you must match the hp and service factor.. say its a 1.1/2 hp motor and the service factor 1.47 you will need a 2hp with a 1.15 service factor to replace that original motor .if you replace it with a 1 1/5 motor it WILL BURN UP THE MOTOR !!. welcome to the hayward northstar .
only the 2 speed motors have a start switch the CAPACITOR would be my first check it may be a 30 or a 35uf at 370 cap LOOK IN YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING USE YOUR ZIP CODE IN YOUR SEARCH
Aug 05, 2010 | Hayward 1.5 Hp Northstar High Performance...
My pump is issung a burnt smell and ended up stopping al together
SOUND LIKE YOUR MOTOR IS TOAST ! DO TO THE COST OF MOTORS FOR THESE , REPLACE THE COMPLETE PUMP WITH A 1.5 HP STA-RITE DURA GLASS ! OR YOU MIGHT NEED A 2HP.. LOOK ON YOUR MOTOR LABEL FOR THE HP AND THE SF . TAKE A PICTURE OF IT AND PRINT IT OUT. BRING THIS INFO TO YOUR LOCAL POOL PUMP REPAIR GUY AND ASK WHATS THE BEST PUMP. THE ONE HE WOULD USE ON HIS POOL.. ANSWER ..STA-RITE.. WELCOME TO THE HAYWARD NORTHSTAR .. REMEMBER TO VOTE OR COMMENT .. IT IS THE FUEL TO KEEP ME TRYING TO HELP U GUYS .. JAY
Jul 09, 2010 | Hayward 1.5 Hp Northstar High Performance...
Have 2hp northstar pump and its humming and flipping the breaker and then stops. How do we get the pump apart to see if we need to replace motor or propellor?
THIS IS A HARD PUMP TO WORK ON ! TAKE THE QUICK FITTINGS OFF AT THE TANK AND DISCONECT THE POWER LOOK TO SEE HOW TO PUT THE WIRES BACK UP (PICTURE) AND SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY .. WARNING THE HP IS MISLEADING ON THESE PUMPS , YOU MIGHT HAVE A A 2.60 HP MOTOR.. LOOK FOR THE SF ON THE MOTOR LABEL .. HAVE THIS READY WHEN YOU CALL TO FIND A MOTOR ! REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
Jun 29, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
POOL PUMP MOTOR MAKES HUMMING NOISE BUT WILL NOT START where can I get a diagram of the motor if I need to take it apart to fix, what could the problem be?
Thank you for posting your question here on Fixya.com.
It could be the pump is bound up but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage. Otherwise please reply with specific questions about what you find for more direction.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jun 14, 2010 | Hayward 1.5 Hp Northstar High Performance...
My Hayward pool pump was humming, but I got it running. Now it is not pulling water into the filter. Does anyone know what the problem could be?
WELCOME TO THE DREADED NORTHSTAR..THEY FAILED TO PUT A LOCKING SCREW ON THE IMPELLERS ON THESE WITH A MOTOR THAT CAN RUN IN REVERSE ON A WHIM . SO WHAT ITS DONE IS MUCKED UP THE THREADS ON THE IMPELLER.. YOU WILL FIND THAT THIS IS THE HARDEST PUMP TO WORK ON ! PARTS $$$ CRAZY .. I SEE A NEW PUMP IN YOUR FUTURE ,, A STA-RITE DURA GLASS !....; WHEN GETTING A NEW PUMP TELL THE THE HP AND SF SERVICE FACTOR OF THE HAYWARD YOU HAVE SO YOU GET THE RIGHT SIZE PUMP FOR YOUR NEEDS ..GOOD LUCK AND VOTE FOR ME...JAY
Jun 13, 2010 | Hayward Northstar Pool Pump 2 Hp Sp4020ns
Northstar 1.5 hp pump motor is always hot and shuts off for ten minutes aned comes back on. The voltage and amperage is good. What's the problem
It has an internal thermal overload protection device that is turning it off. Once it cools enough it will automatically turn back on as long as whatever switch or timer you have controlling the pump is in the on position. If you are certain it is not due to a voltage or load condition then it would seem the only other problem is mechanical.
In any case try a local electric motor repair shop.
Aug 08, 2009 | Hayward 1.5 Hp Northstar High Performance...
What does SF mean on pool and spa pumps?
SF stands for Service Factor. It has to do with how much overload your motor can handle without damage. Here is some information about it:
http://www.engineeringtoolbox.com/service-factor-d_735.html
You should not be feeling any "trickle" of electricity. You are correct...it is NOT SAFE! I would definitely have another qualified electrician check your wiring out.
Thanks for using Fixya.
May 16, 2009 | Speck Pumps Impeller. 3/4 Hp, S.F. 1.0,...
Hayward 1.5 Hp Northstar High Performance Pump Logo
102 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
