Question about HP Photosmart C6100 All-In-One Printer
Photosmart c6100 all-in-one printer no power to the printer / powerswitch doesn't work - powercord is connected, outlet is operating.
  • 905 Answers
Your power supply is likely at fault here.
You can try to 'reset' the supply by unplugging it from the printer, and then unplug the AC line cord. Plug line cord back in, then plug back into the printer.
If you are still having issues, then use a multimeter to measure the DC voltage at the connector's outside contacts (middle contact is not used). You should have approx. 32 volts. If not, then replace your power supply. There are many sources on the internet. Otherwise, your printer may be at fault, consult your user manual for instructions on a master reset.
Posted on Aug 19, 2010
Photosmart C6100 .... I had Vista (which wasn't compatible with this printer even 3 years ago (without patches)..... Anyway, I just installed Windows 7 and Office 2010 on my pc today. I loaded the HP...
Hello and Welcome to FixYa!
C6100 series is compatible with nearly all the Operating Systems, have you checked the Vendor's support site?
Click here to navigate to the page, and select the exact OS, then proceed to download.
Do tell me the results.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
Feb 18, 2011 | HP Photosmart C6100 All-In-One Printer
Hi. I have a HP all in one printer (C6100). It keeps turning off then immediately back on. Can the printer be reset?
The below are the resetting steps for this printer model. Try next reset if the first one did not help. Do not try all resets together
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
NVM Reset
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards
Riztech.
Aug 18, 2010 | HP Photosmart C6100 All-In-One Printer
Continues to cycle on and off
Disconnect the power cord from back of printer ( while printer is on )
While holding the Power button connect the Cord back
Release the button after 3-5 seconds..
The issue should resolve.
Jun 25, 2010 | HP Photosmart C6100 All-In-One Printer
Error msg says scanner failure.
ensure the printer was correctly enstalled, check all connections ensure a tight fit. if it is connected to a network make sure the network cable is plugged in and blinking green
Nov 03, 2009 | HP Photosmart C6100 All-In-One Printer
HP C6100 printer won't go on -- or off. Plug it in and the blue screen with the HP logo appears on the console (without pressing the "on" button) and that is as far as it gets. The "on" button light goes...
Try This
First unplug the computer from the printer
Connect the printer directly to the wall outlet (there should be no surge protactor in between)
Unplug the power cable from the back of the printer and keep on tapping the power button for next 30 sec and then plug in back the power cable and
check if the same thing happens
Unplug the power cable from the back of the computer
(with one hand) press and hold down the (#) and the (6) button at the same time and plug in back the power cable
Release the (#) and (6) button (the printer may shut down) on the screen it will display SEMI NVM reset
If none of them happens try it once more
if still the issue remains
Do the same by press (#) and (9) button
If still it doesn't work you may change the wall outlet and check if still the issue remains in that case the printer has gone bad and cannot be repaired
Can call HP to return the printer and get an upgrade at low price for replacing the damage printer.
Regards Soumajit
Oct 11, 2009 | HP Photosmart C6100 All-In-One Printer
HP C6100 Printer does not like yellow cartridges
Hello sir; replace cartridge whichever it necessary, better buy oem.
Mar 17, 2009 | HP Photosmart C6100 All-In-One Printer
I have an HP C6100 printer and it keeps telling me to power down
Your scanner unit has failed. It will cost the same as a new printer to have it replaced.
Mar 05, 2009 | HP Photosmart C6100 All-In-One Printer
Printer failed
Unplug the power cord from the All-In-One as well as the power outlet leave it unpluged for atleast 1Min time..
Plug the power cord directly to a wall outlet without surg protector. (if possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Then check and see if you are able to make a color/Black copy
Good Luck
Sep 30, 2008 | HP Photosmart C6100 All-In-One Printer
Vista
Go out to hp.com support and check under updates and downloads, you should find the updated software and drivers you need. I just went through this with my photosmart 8750,.
Aug 17, 2008 | HP Photosmart C6100 All-In-One Printer
HP Photosmart C6100 All-In-One Printer Logo
99 people viewed this question
Seeker5211
Seeker5211
