Question about Casio Office Equipment & Supplies
I recently got a casio FR-2550 2nd hand, especially for the paper. i cannot get the paper to feed. I'm not sure if a part is missing. The feed button works.
  • blasting784 Aug 19, 2010
    SOLVED IT MYSELF. THE RUBBER ON THE FEEDING ROLLER WAS PERISHED AND HAD TO PRY IT OUT WITH A TWEEZER. SO I CUT DUCT TAPE INT0 A STRIP AND ROLLED IT ONTO THE MASTER FEEDER TILL IT WAS THICK ENOUGH TO ROLL THE FEEDER WHICH FEEDS THE PAPER. THANKS TO GOD FOR THIS GIFT!
3 Suggested Answers
SOURCE: Paper feed
Lost Insturctions Does someone know where I can get a copy of them for a Victor 930-2 Scientific Calculator - VCT9302
Posted on Nov 17, 2008
SOURCE: I have a borrowed Casio FR 105S printing
Make sure the paper has a straight clean edge. Feed the paper into the slot in the back - make sure the paper is straight. Paper will go in about 1/4 inch. Push the feed button and the paper should feed through the printer.
Posted on Feb 14, 2010
How do i feed the paper of the casio fr 2500 printing calculator
Hello Michel Dekock,
Could not find your FR2500 (but close)...
Has worked every time for me...
Mount the paper roll on the wire bracket... feeding
over the top of the ROLL (TOWARD THE MACHINE).
With the keyboard FACING away from yourself
Fold the FRONT EDGE of the PAPER on to the
side to form a chisel point... and insert the point
(folded side up) in the rear roller slot (paper feed)...
As shown on FR2650
http://www.ebay.com/itm/Casio-FR2650TM-Printing-Calculator-FR2650TM-/122298781152?hash=item1c79934de0:g:bwEAAOSw44BYbWjv
With the PRINT feature turned on the roll should be
advancing while holding down the TOTAL key...
Hold the key until the edge of the paper roll emerges from the machine.
Hope that helps.
(now you only have to freshen up the ink).
https://en.wikipedia.org/wiki/Carnac_the_Magnificent%E2%80%8B
Mar 27, 2017 | Casio Office Equipment & Supplies
How do I load paper?
I have a casion hr-100tm calculator and found the easy way to load a new roll of paper. Take a 3x5 index card and cut it on 45 degree angle, then with angle on the right of the machine feet it into the machine pushing it as you go. Once it begins to feed so you can pull on it, then take other end of card, scotch tape to new roll of adding machine tape. As you feed the card through the roll of paper foillows. Once it has fed into machine cut off 3 x5 card. Easy.
The problem is that all rolls of machine paper are not equal and the thinner paper doesn't want to feed. This way it works for any type. Hope it hellps.
Oct 02, 2015 | Casio FR-2650A Calculator
When I push the feed button, an E shows up in the left hand corner of the display.
The E is an indicator that the Paper Spool is EMPTY so either the paper sensor is defective or You have forgotten about a "bar" that the Paper must go through to be sensed. Or Your Feed motor has fed it's last. Best of Luck!
Sep 28, 2014 | Casio HR 100TM Portable Printing...
Casio FR-2650A Not Pulling Paper Through
See if the roller gear is jammed or rusted. A little wipe with WD40 may help.
Jan 27, 2012 | Casio FR-2650A Calculator
Casio fr-2650 plus is showing an E on the screen and not allowing me to input data. Ideas?
Follow theses steps (from Casio Support) :
First, check the batteries, and ensure there is not a paper jam in the printer.
If both are fine, then while the calculator is in the "Print" mode, press the [CA] (or [AC]) button 20 times consecutively to clear out memory buffers. Try some numerical calculations, and if the problem persists, repeat pressing the [CA] button 20 times.
If the problem still persists, then the calculator may require service
Sep 28, 2010 | Casio FR-2650Plus Calculator
I have a borrowed Casio FR 105S printing calculator. How do I load the paper?
Feb 05, 2010 | Casio HR-8TMPlus Calculator
HOW TO INSTALL PAPER ROLL IN CASIO HR-8TM
There is a slot just in front of the printer
1. turn the power on
2. turn the switch to "PRINT" position
3. slot the paper in & press "FEED"
4. the paper should be able to feed up
Jul 18, 2009 | Casio FR-2650A Calculator
Loading Paper into a Casio Calculator
This isn't too complicated. And for the lazy guy that just put a phone number for the fix, what the heck do we need FixYa for anyway? :\ For cryin' out loud! :) )
1. Slide the clear plastic cover toward the back to remove and flip of the metal spool holder up. Place the roll of paper on the holder. (Make sure the paper drops off the "back" of the spool for proper feed.)
2. Feed the paper into the bottom slot at the **** end of the calculator.
3. Feed the paper through that bottom slot along the inside case under the black guide inside. If you tilt the calculator correctly, you can look inside and see there is a way to slide the paper under the guide.
4. Making sure the paper slides as far as it can, press the FEED button until the paper starts feeding.
5. Feed enough paper to slide through the clear plastic cover and you're all set.
This isn't factory, it's just what I figured out playing with the thing. If you can think of a better way of explaining the procedure, by all means edit this and post!
God bless!!
Maridian
Apr 04, 2008 | Office Equipment & Supplies
Casio FR-2650A
the tape goes into a small slot on the backside of the machine, not in the clear plastic cover. Install the roll so the paper rolls off the bottom, not over the top. Folding the paper back about 2" does help you get it through.
Aug 30, 2007 | Sharp CS-2850 Calculator
Load paper
You must feed it through the back of the machine while depressing the feed key. make sure it is the right size paper and hopefully there is not a jam in the machine. If so you can try sliding a business card through the slot where the paper goes and force any jammed paper out of the path.
Jun 01, 2007 | Casio FR-2650A Calculator
83 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
