My brake lights do not come on when i press the brakes. I have changed the brake switch. The fuses are good. The bulbs are good.
  • 905 Answers
Look for a bad ground at the vehicle's rear wiring harness, namely where it begins to branch off to the lights. The ground may also be created by the bulb sockets as well.
Do you have any lights in back? Parking / Turn signals / Hazards?
Posted on Aug 19, 2010
I have a 2000 grand Cherokee Laredo v8 all my brake lights went out checked the bulbs fuse and brake switch all are good the tail and signal lights are good. what should I do nextto fix the problem
Have you checked the brake light fuse to see if there is power at the fuse and out of the fuse, also check the brake light switch for power in and out when the pedal is pressed, do that and get back to me.?
Oct 26, 2016 | 2000 Jeep Grand Cherokee Laredo
Dodge ram 1500 wiring diagram
Three places to look. 1) Brake lamp fuse, 2) Turn signal switch and 3) the brake pedal switch. Brake light power comes from the fuse up to the turn signal switch down to the brake lite switch on the brake pedal and then on to the light bulbs. Start by putting the 4 way flasher on. If the brake lites flash, then the bulbs are good. That eliminated the fuse too. so the problem is the other two.
Jan 24, 2014 | Cars & Trucks
I have a 99 ford f250 5.4 super duty and dash lights and running lights come on when I press the brakes. I have changed multi function switch. Light Switch and brake switch. Checked all the bulbs and...
It could be if you tail light bulb and brake light bulb are the same bulb. You might have put the bulb in the wrong way round so the two silver bits on the bottom of the bulb joins the 2 wires together so when you brake the side lights come on and dashboard lights up or the other thing it might be is a broken wire hope this helps
Nov 15, 2013 | Cars & Trucks
Brake light dont work, change bulbs, fuse, bake switch, and has power still dont work
You have a failed brake lamp relay,this is located at the back right hand in the trunk at the quater panel.
Mar 12, 2012 | 2003 Honda Civic
1997 olds cutless brake lights will not work. bulbs, fuse and switch are good
Its a faulty turn signal switch.Try this,push down and hold brake pedal while pushing on the hazard switch and if the brake lights come on then replace the signal switch.
Jan 29, 2012 | 1997 Oldsmobile Cutlass Supreme
My additional brake light is not working i have tested the brake unit and that works is there a seperate fuse for this or is it all on one fuse for all the brake lights
The third or High Mounted Brake Light runs straight off the brake light switch on the brake pedal arm. You say you tested the "brake unit"? I assume you mean the third brake light assembly, and if you get power there when someone steps on the brake pedal, then the bulbs are bad.
The power flow for the brake lights goes like this: Fuse ->Brake switch -> Turn signal switch -> Rear lights. The only difference is, if you have a 3rd brake light in your rear window, that gets its power directly from the brake switch. It does not go thru the signal switch first. So, if you are having a brake light problem, and your fuses are good, check the 3rd light in the rear window, if it lights up (assuming the bulbs are good, no one ever changes them), then the problem is most likely in the turn signal switch, hope this helps!
Aug 28, 2011 | 2002 Ford SVT Focus
'99 Expedition brake lights aren't turning on when pressing brake
It could be a number of things, the good news is that none of them are serious or expensive to fix.
The normal components that make up your brake circut are:
1. The brake light fuse (In the fuse box and labeled as such)
2. The brake light switch/relay - also called a stop light switch. It's under the dash, right behind the brake pedal arm. When you push the brake, it sends a signal to the lights which turns them on. Think of the dome light switch in the door jam of your truck. When you open the door, it releases the switch and your dome light pops on. Same thing with the brake light switch.
3. The bulbs in the tail lights and the 3rd brake light.
If none of them are working, it's most likely a fuse or the switch/relay under the dash. If it's the switch, it's a $12 part. Obviously fuses are only a couple bucks.
Jan 18, 2010 | 1999 Ford Expedition
94 toyota previa brake lights not illuminating
CHECK THE BRAKE LIGHT SWITCH UNDER THE BRAKE PEDAL
Jan 08, 2009 | 1994 Toyota Previa
Brake lights don't work. Fuse is good, bulb is good, but brakes still won't come on. GMC Sonoma 1994.
please check your brake light switch located near the brake pedal. it could be faulty.
tnx 4 using fixya,
drcool
Sep 24, 2008 | 1999 GMC Yukon
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
