Question about Pride Mobility Products Health & Beauty
I have a Pride go-go ultra which is working fine, with new batteries except that on occasions when I insert the key I get a Bleeping signal and the scooter will not start, after repeatedly removing key it eventually starts and is ok for days. It is kept fully charged.
  • 692 Answers
Alan, this could be that the switch is getting worn. If you can take the console off and get access to the switch try jumping across the switch and check that the scooter turns on and doesn't beep. If it works properly then the switch is worn and you can replace the switch with a plain old on/off toggle switch. If you want to buy a toggle switch and use it to jump the switch and see if the scooter works correctly. If it does then replace the old switch with the toggle switch. Hope this helps
Posted on Aug 20, 2010
What batteries do I need for a jazzy select6 pride
information and batteries for sale.
info
Jazzy Select 6 - Specifications, Owner's Manual, Features & Benefits
www.pridemobility.com > Jazzy Power Chairs > Models
  1. Cached
  2. Similar
In-line motor technology for increased efficiency, torque and range. Built with ease of service in mind. Easy side access batteries. Tool-less front panel access to ...
[PDF]Jazzy Select Series - Pride Mobility
www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_select_series_om.pdf
  1. Cached
  2. Similar
6 www.pridemobility.com. Jazzy Select Series. II. SAFETY. Do not connect an extension cord to the AC/DC converter or the battery charger. Removal of ... Batteries for Sale
Pride Mobility Jazzy Select 6 Ultra Wheelchair and Mobility Batteries at ...
https://www.batteriesplus.com > Batteries > Wheelchair and Mobility > Pride Mobility
  1. Cached
  2. Similar
If you rely on a Pride Mobility Jazzy Select 6 Ultra powered wheelchair or personal mobility scooter to get around, Batteries Plus Bulbs can help you find the ...
Pride Jazzy Select 6 Power Chair from Pride Mobility ' 1800wheelchair ...
www.1800wheelchair.ca > Brand Showcase > Pride Mobility > Pride Powerchairs
  1. Cached
The Jazzy Select 6 Power Wheelchair from Pride Mobility is the ultimate ... Easy side access batteries; Full-length, flip-up armrests; Solid flat-free tires; Foot ...
24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger: Amazon.ca ...
https://www.amazon.ca/Jazzy-Select-Scooter-Battery-Charger/dp/B00CIZ1GW6
  1. Cached
24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger: Amazon.ca: Sports & Outdoors.
Pride Mobility Jazzy Select 6 12V 35Ah Wheelchair Battery
https://www.amazon.com/Mobility-Jazzy-Select-Wheelchair-Battery/dp/B009DKGCC8
  1. Cached
Rating: 5 - ‎1 review Buy Pride Mobility Jazzy Select 6 12V 35Ah Wheelchair Battery - This is an AJC Brand® Replacement on Amazon.com ? FREE SHIPPING on qualified orders.
ALL THE INFO HERE BELOW
Google
Nov 24, 2016 | Pride Health & Beauty
Hello, my Pride Victory 9 scooter turns on and has the seat piston and lights working fine but it does not move. Can you please help?
Hi If U left the KEY IN.... When installing the batteries this can cause the controller to shut down remove key for a short time then try to turn on :::::::: also check to ? that the freewheel lever is in drive .good luck...
Sep 24, 2016 | Pride Health & Beauty
Green ready light on Pride Sonic three wheel scooter wont turn on. What turns it on?
Hi if it is similar to pride x the circuit will shut down if key is left on for 20 minutes u will still have lights. Remove key for a short time then replace it & turn on ..goood luck
Jan 21, 2016 | Pride Sonic 3 Wheel Portable Scooter
I have a Pride 4 wheel Go Go Elite Traveller Scooter. It generally works fine, but I will frequently get an 8 beep error code and it won't go after a stop. I merely turn the key off and then
BEEP CODE CONDITION SOLUTION
2 Battery voltage is too low to operate Charge the batteries fully until charger and
the scooter. any meters indicate completion.
3 Battery voltage is too high to operate Contact your authorized Pride Provider for
the scooter. assistance.
5 Solenoid brake trip. The manual freewheel Remove the key, then push the manual
lever may be in the freewheel position. freewheel lever to the drive position and
restart the scooter.
6 Throttle trip. The throttle control lever Release the throttle control lever completely,
may have been depressed while inserting then reinsert the key.
the key.
7 Throttle trip. Throttle potentiometer Contact your authorized Pride Provider for
fault or speed potentiometer fault. assistance.
8 The motor is disconnected. Contact your authorized Pride Provider for
assistance.
9 Possible controller trip. You may be Shut down your scooter for a minimum of
attempting to install the battery pack while several minutes to allow the controller to
the key is inserted or the motor controller cool. Or, try reinserting the key into the key
may be in overheat protective mode. switch.
What you may be doing is mis-counting the beeps and it may be 9 beeps or its 8 and you have a bad connection between the motor and the switch? Good luck!
Jan 19, 2015 | Pride Health & Beauty
My pride 9 colt is 2 years old with new battery's as I turn my key it starts bleeping 8 times and wont move has been left in rain for a day
You can download the service manual from Pride's website. That will tell you what the flashes mean and how to fix it.
May 28, 2014 | Pride Health & Beauty
Random stop then beeping
Hi, when it stops and starts bleeping , Do you turn it off and start again or does it just go again ?,,,
Regards
Rob
www.gewizrepairs.co.uk
Feb 19, 2014 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Ultra go go worked 3 weeks ago. left key on, batteries dead and now, charger lite will not come Help
Your charger will not pick up the dead batteries because they were'nt made to pick up the low charge ,In this case buy new batteries and your problem should be solved.
Jan 24, 2011 | Pride Health & Beauty
Scooter is dead
Are you sure your charger is working? Is the free-wheel lever engaged? Also the charger has an inhibit line, it will not run when the charger is plugged in.
Nov 16, 2008 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Health & Beauty Logo
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
