Question about Whirlpool AD25BBK Dehumidifier
It is not producing water, it runs but no water is collecting in pan.
  • 6,993 Answers
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again.
Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue.
This situation will have to be addressed by a qualified technician.
Take care.
Posted on Aug 19, 2010
Spitting water out side?
ooh my this might seem a terrible thing but is actually quite comon to happen on a unit that has a clogged drain tube , you see theres a system (pan) inside that collects water from the condenser coils , and if this pan for what ever reason cant drain the pan backs up and finnaly the water level reaches the fan and yup ^$^ Hits the fan !!!! and out it goes with the air !! this pan is seperate from the bucket that collects the water so your not likely to see it from outside , to resolve it this units needs to be completly cleaned in/out
Jul 04, 2014 | Whirlpool Dehumidifiers
The Machine turns on and runs fine but produces no water after running for 12 - 24 hour period.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 13, 2011 | Maytag M7DH45B2A Dehumidifier
When I turn on dehumidifier I can hear the fan and compressor running but there is no collection of water in my pan
heatman101
Jun 06, 2011 | Winix WDH751 Dehumidifier
Dehumidifier runs but does not produce any water.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Jul 01, 2010 | Fedders A7DH65B2A Dehumidifier
I have 2 kenmore 70 pint dehumidifiers. Neither one is collecting water in the pan when running (therefore neither is running). Is there a reset button?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Feb 17, 2010 | Kenmore 54701 Dehumidifier
Continuous drainage
Take out the drain pan and look in left hand top of the compartment and you will see a drain hole for the pan.Plug the drain hole with a small rubber plug, I used an electrical wire nut wrapped with tape and it worked fine.replace the pan and the water will run out the back. A 3/4" garden hose should work for the drain hole.
Jul 27, 2009 | Haier HDN655E Dehumidifier
Kenmore dehumidifier runs good but does not collect water.
most likely the compressor is not producing pressures that are needed probably not low on freon .
May 31, 2009 | Eva-Dry EDV300 Dehumidifier
Kenmore dehumidifier runs but won't collect water
If you haven't done so already, try removing and cleaning the inlet filter screen which is almost certainly just behing the inlet grille. It may slide upwards out of the casing or downwards unto the bucket area. If this is blocked with fluff then no moist air will get to the cold pipes, so little or no water will be extracted. There's also a chance that the humidity sensor is clogged with fluff, so fooling the system into thinking the room is pretty dry, in which case the compressor will probably not run.
A running compressor can usually be detected as a deep throbbing from the machine. If it is running, but not cooling the pipes behind the intake grille, then you may have lost the refrigerant from the system via a leak. If the air coming out of the machine is warm (caused by the compressor running) but there is no water produced this may be the cause.
Explore along these lines and let me know what you find.
Cheers, D
Jul 31, 2008 | Dehumidifiers
Not collecting water
If everything is running and no water is being produced the system may have lost its refrigerant. There are two motors in dehumidifiers. One is the fan and the other is the compressor. Make sure they are both running.
Jun 18, 2008 | Goldstar DH304 Dehumidifier
Whirlpool AD25BBK Dehumidifier Logo
170 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike Squire
Mike
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
