Question about GE GSH25JFR Side by Side Refrigerator
I have a GE side-by-side refridge Model BB TPX 24BRY. Water is dripping on the floor on underneath the right side of the unit. Manual says the freezer drain is clogged, but doesn't locate the drain. The freezer is on the left side of the unit. I pulled the unit out from the wall but no apparent leaks in ice maker lines or anything viewable behind the access panel on rear of unit. Any ideas? Thank You, Herbert Mayer
    Top Expert:
  • GE Master
  • 43,031 Answers
Look for the freezer drain at the rear inside the freezer compartment.
Posted on Jul 14, 2017
  • 833 Answers
SOURCE: Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
Posted on Dec 22, 2007
tborn6
  • 700 Answers
SOURCE: water coming from ice maker freezing down back wall of freezer
check for levelness of the ice maker also make sure that the fill tube is inserted all the way into the unit
Posted on Apr 25, 2009
Maytag317
  • 1136 Answers
SOURCE: water from GE Profile Refrig/freezer drips down
Hi, Is it bypassing the drain or is the drain plugged? The most common is that the drain hole gets iced up and them overflows onto the floor.
Just wanting clarifcation.
Posted on Jul 12, 2009
SOURCE: Ice build up bottom of freezer and water on floor GE Monogram
I had the same problem. The drain tube is located below the pan below the fins at the rear of your freezer. The drain tube has a trap (s-shaped curve) to prevent air flow out of the freezer. The problem is that water gets in this tube and freezes. I took the sheet metal cover off the back, got a turkey baster and flexible tube, and continuously flushed hot water (after the freezer had been turned off around an hour to thaw). Eventually the plug gave way.
Posted on Jul 16, 2009
SOURCE: GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Posted on Jun 03, 2010
I have a GE Artica PSF26PGSA BB side by side refrigerator. Water collects in the bottom and runs out on to the floor. Any suggested solutions?
Clean it. You probably have a large dust collection in, under and on your units underbelly.
You should have a collection pan, underneith, that collects the runoff water and the heat from the componits will evaporate it before it fills too much.
You could also have a leak in the plumbing system that supplys your ice maker. When your valve opens, you should be ready with a flash light inorder to watch for any drips underneith the unit.
Could be a simple fix of just tightening up a bolt, or could be a repairman issue.
Good luck.
Mar 11, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
GE SIDE BY SIDE FRIDGE HAS WATER LEAKING ON FLOOR FROM FREEZER SIDE
There is hole behind the freezer panel that the water should drain thru . Use a small hose in the hole and blow thru to cleam drain .
Aug 14, 2012 | GE Refrigerators
Need to replace water filter on ge side by side gss25jeta bb model and need to know what type of filter to replace it with.
Pull the old one out and see what it is. Check you owners manual for proper replacement instructions. If you do not have and owners manual copy and paste the below URL into your address bar.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60514-2.pdf
May 31, 2011 | Refrigerators
This is my second attempt. I have a GE Profile
After you set it, the display goes back to showing the current temp. Just wait awhile and current temp displayed should change to the temp you set once it has had a chance to adjust. Give it a few hours.
Feb 19, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Good luck! :)
Vlad
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
I have a GE model TPX 24BPBA WW and have a water leak on my floor. I disconnected the icemaker water feed and leak stopped. What's wrong
do you live in an area where there are rodents such as mice ? if yes there is a possibility that they have eaten the plastic water line that feeds from the ice maker water valve to the ice maker itself . when they get thirsty you would be surprised what they will actually chew through to get water. regardless the cause, you probably have a broken water line between the ice maker water valve and ice maker unit .
Mar 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Why does water occasionally leak from bottom of
There is a pan at the bottom of the unit. It catches the defrost cycle water and the heat from the comp. and condensor helps it evaporate. But, it's plastic. Mice have probably chewed holes in it trying to get at the water...They must have water to survive, right? Remove it and you'll see the holes....Then, replace it or epoxy the holes in it with plastic layering from old butter containers etc.
Aug 04, 2009 | GE Profile PCF25PGW Side by Side...
GE Profile Side By Side leaking water on to floor
there must be a hole in the lower back of the freezer compartment that carries the water to the drip pan when the fridge goes through the defrost cycle. Water on the floor means that hole is plugged and the water seeps through the doors. See the owner's manual - it will describe this issue. The fix is to have the blockage removed by squirting a solution of hot water and baking sode with a turkey baster or a similar injector.
Mar 13, 2009 | GE Profile PSI23NCR Side by Side...
Drips at water dispenser GE PSC23MGSA BB
If it's a constant drip then you need a new water valve.
Jan 03, 2009 | GE Profile Energy Star PSC25MGS Side by...
GE Profile Refrigerator - Small Leak & Loud Noise
Does water come out of the water dispenser?
I is more likely that the tube that drains the water down from the self defrost mechanism is clogged. Look in the very back of the reefer cabinet, you will see a trough back there, if it is full of ice and water the drain tube is clogged up. If so, a little blast of air from a can of air (like the ones you use to blow off computer key boards will blow it out. Then the water can drain down to the evaporator pan and you will no longer get water on the floor.
Nov 06, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE GSH25JFR Side by Side Refrigerator Logo
47 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
