Question about Dishwashers
What is a meiko 111 error on a dv125.2 - Dishwashers
2 Suggested Answers
Kitcheneer
  • 11 Answers
SOURCE: dishwasher fix
111
Floor pan Leakage
Leak inside machine activating ground float switch
302
At pumping out during rinse cycle level does not fall below level 1
Drain pump faulty, blocked, aqua stop not closing completely, no signal from circuit board (connection number 6 on XA1 connection plug)
Posted on May 10, 2008
Meiko 80.2 code 111 is there a quick fix to this problem
this code is usually an indication of water leaking internally where the motors are located. Needs to be found and stopped.
Jul 14, 2017 | Meiko Dishwashers
What does error 111 mean in MEIKO FV 40.2 Glass washer?
In most cases, there is a water leak inside the machine and water is dripping in the lower level where the motors are located.
Mar 30, 2017 | Meiko Dishwashers
I have a Meiko Fv40.2 with two codes coming up, 302 and 325. Can you tell me what the codes mean.
Error 302: Drain pump output low/defective/unplugged, drain hose kinked, no signal from I/O board, wash tank level sensor malfunction.
Error 325: Tank has overfilled, drain pump active to decrease level. Allow machine to drain.
These are straight out of their tech manual.
Mar 01, 2017 | Meiko Dishwashers
Error 305 on meiko dv200.2 what does it mean?
Could be a faulty booster level / pressure switch. Do you hear the air gap cup filling in the back? Could be a faulty fill solenoid (aqua stop hose with solenoid at water inlet.)
Aug 31, 2013 | Meiko DV200.2 Door-Type Dish Machine
MEIKO DV 80.2 ERROR CODE 305
305 Booster content is insufficient for rinsing
See error code 301, booster tank level sensor defective/disconnected, water inlet strainer is soiled, booster tank vent is clogged, anti siphen flap.
301 Level 1 not reached when filling (number of cycles exceeded)
Booster pump output low/defective, rinse nozzles clogged, wash tank level sensor soiled, moisture in sensor tube, hose kinked or not water tight.
Mar 23, 2012 | Meiko DV 80.2 Dishwasher
Meiko dv80.2 message: info 124 we don't know what
you have opned the hood close the hood the error will disapear
Jun 13, 2011 | Meiko DV 80.2 Dishwasher
What does error code 205 mean on the Meiko FV40.2
This error code means your booster heater is not getting up to the proper temperature. You can check your amp draw across your booster heating element to verify it is in fact heating and not blown. Also, check your temp sensor for resistance. At room temperature, you should read about 1000 Ohms. At 180 degrees, you will read about 1500 Ohms.
Mar 15, 2010 | Meiko FV 40.2 Dishwasher
Error 111 meiko dr80.2
it's water leakage inside the machine(or)water leakage switch defective.
Jun 20, 2009 | Meiko DV 80.2 Dishwasher
Meiko FV40.2 Error codes
212
Boiler temperature too high
Contactor faulty, probe faulty, check connection on XA5
The code 312 is the same as a code 212 as stated above.
There are dozens of error codes and you should be able to get them from your local meiko dealer, hope this helps, colin
Mar 10, 2008 | Meiko FV 40.2 Dishwasher
Dishwasher fix
111
Floor pan Leakage
302
Feb 28, 2008 | Meiko FV 40.2 Dishwasher
Dishwashers Logo
51 people viewed this question
Top Dishwashers Experts
