Question about Ford Tractor 8n Front Emblem
Ford 8n governor not working properly. how to set it up?
What is the point gap ford 8n
.015 for 2N, 8N & 9N
The 8N also had problems with ignition switch causing several troubles, cheap and easy to replace....Below link is an excellent site.
http://www.yesterdaystractors.com/atrp/specs/ford.htm
May 14, 2014 | Ford 8N Tractor
Wiring a selonoid
http://www.ntractorclub.com/
The link above is just one of a dozen or more very helpful websites for Ford 8n tractors.
The original 8n tractor had a six volt battery with positive ground (this is different than most automobiles that have a negative ground). The starter solenoid is energized via the ignition switch and the large starter button in front of the gear shift, the small wires going to the solenoid energize a coil which "pulls in" and completes a circuit that then provides 6 volts directly to the starter motor through a large, heavy gauge wire. The smaller wires connect to the two terminals on the top of the solenoid and the heavy wire goes to the larger post on the solenoid and originates from the negative post of the battery... Hope this helps. There are many, many schematics and pictures available on the "net" The Ford 8n community is very large and extremely helpful....Good Luck
Apr 11, 2014 | Ford 8N Tractor
Set timing on 8n ford tractor!!
Does it have points?
Use a 12V. test light on the dirstibutor terminal to + side of coil. When the test light goes ON,that is the timing at the crackshaft.
Just like the old VW.
Aug 21, 2013 | Ford 8N Tractor
Overheated
yes head gasket sounds bad.
Jul 03, 2013 | Ford 8N Tractor
Points gap for 1953 8 n ford tractor
Here's how to do it:
http://www.ehow.com/how_7368031_set-points-ford-8n.html
set the point gap a .025
Jan 13, 2013 | Ford 8N Tractor
Water pump leaks through right side stud on 8n ford tractor
gasket not sealing properly you could try to put silicone on the bolt itself let it dry at least 24 hours then try it. you may need a new gasket make sure you tighten them in sequence usually middle right left top bottom to get a flat tightened match
Nov 11, 2012 | Ford 8N Tractor
I'm rebuilding a ford 2N Governor. I see that the Drive shaft and ball fin or divider are separate. Should the divider be a tight fit on shaft to rotate the four balls during operation?
Yes. The balls move outward by centrifugal force. The faster the governor shaft rotates the farther out the balls move until it actuates to limit the fuel flow.
If really helpful, please rate.
Jul 13, 2011 | Ford 2n, 9n, 8n Tractor Left Taillight...
The steering column shaft in my 1954 Ford 8N tractor broke and I need info on howe to fix it.
Not sure, but if it's a 1954 model, it's not an 8N. 8N was only built thru 1952.
But sounds like you will need a new steering shaft.
www.Ford8N.com
Sep 19, 2009 | Ford 8N Tractor
41 9n ford motor not powering up enough
This one sounds like it may still be out of time.
Aug 27, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
No fire on new parts 8n ford
16 to 20 thou should do it.
A clean nongreasy feeler gauge or a match book cover will do.
Jul 04, 2009 | Ford 8N Tractor
Ford Tractor 8n Front Emblem Logo
1,242 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
fordexpert
donald boissonneault
Are you a Ford Garden Expert? Answer questions, earn points and help others
