Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
Pullstart cord replacement - Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
  • 843 Answers
If this is like most simple mowers (using briggs & stratton engines and some others) the recoil starter is in an assembly which is spot welded onto a metal cover. You may have to first remove a plastic shroud (which might include the gas tank - which should have a shut-off valve). Then you should be able to remove the metal cover that includes the recoil starter. When you get that off you will see a plastic spool that holds the cord. This spool is probably held in place by a couple of metal tabs that are bent down. Bend those tabs up with pliers. Underneath the spool is a spiral spring that provides the recoil. Take careful note of how this all goes together. Buy a new cord (available by the foot at a hardware store) and wrap it around the plastic spool. Use a piece of tape to hold the end of the new cord above the spool so you can thread it through the hole in the metal housing later. Put the spring and the spool in place, then wind the spool to put tension on the spring - about 3 to 5 turns in the direction that would push the string out through the hole. Once you have the spring "wound up" remove the tape and thread the end of the cord through the hole. Now bend those metal tabs back down. Put the handle on the cord end (or tie a knot) to keep the spring from pulling the end of the cord back through the hole. Reassemble the rest and you are in business.
Posted on Aug 19, 2010
I am looking for pullstart for Tivoli 60 hedge trimmer
Fixya does not sell replacement pullstarts.
Oct 27, 2016 | Garden
How do you fix a pull start
-Take the handle off the rope. You want to only have one knot in one end of the rope. (Of course, if the rope's already broken, you can skip this step ....)
-Get the reel and lay it facedown.
-Get the coil, and begin carefully winding it up so that it fits inside the grooved edge on the reel. BE PATIENT - this will take time.
-On the inside of the coil, there should be a little hook on the end of the coil. That hook matches one inside the pullstart cover when you put the two pieces together. The trick is to get the hook on the reel to catch the hook on the pullstart cover. CAREFULLY put the reel and coil inside the cover, and ***** the bolt in for a moment to hold it in place.
-Turn the pullstart reel clockwise until you feel the hooks catch each other. Feel some resistance? Good, that's what you want.
-Take the bolt back out, and reassemble the starter pawl assembly inside the pullstart, then put the bolt back in and tighten it.
You should now have a complete assembly, minus the pull rope. -Now, looking down into the pullstart, notice there is a hole in the reel off to one side. This is where your rope threads through. Grab the reel, and crank it around about .... four or five times, and try to get the hole in the reel lined up as close as possible with the outer hole in the pullstart cover. -Take your rope (you DID take the handle off first, right? Oh yeah, it broke off ...), and thread it through the reel, then through the outer hole in the cover. This will be a little tricky, as you need to be holding the reel so it doesn't unwind ...
-SLOWLY let the reel start to retract, but don't let it go all the way. Does it look like it's drawing the rope all the way back in? If so, great! If not, pull the rope back out, crank the reel around another turn, and try again.
-Once you have the reel set to where it will retract the rope all the way, thread on your handle and tie it off. You're done!
Apr 16, 2016 | Motorcycles
2000 Sportsman 500. How do I reinstall spring on rewind start cord?
An easy way to fix a pull start recoil spring . - YouTube
? 8:48
https://www.youtube.com/watch?v=d4r8wbejHXY
Feb 19, 2013 - Uploaded by chaseme81871
Thank you so much! I was able to find the pull cord at a local home depot store and when when my husband ...
How to rewind a pullstart spring - YouTube
? 5:05
https://www.youtube.com/watch?v=qTcL3_3leTk
Mar 13, 2010 - Uploaded by lenniepincher
If you ever need to rewind a un coiled pullstart spring. ... ( NEW VERSION ) How to Rewind and Replace Recoil Starter Spring - Duration: 3:53.
Nov 24, 2015 | Polaris ATV
Pullstart won't pull 2 levers are stoping it
Hi Neil:
Looks like a chainsaw!
- I'd start by removing the starter assembly and then trying to turn the flywheel by hand to make sure it's not seized.
- Then pull the start cord to make sure the starter assembly is functioning properly.
- Re- install and make sure the levers (engaging dogs) are in the right position.
Should be OK.
Jul 25, 2015 | Garden
Ryobi chainsaw rcs4640n pullstart slips frequently
sounds like the gears on the pullstart mechanism is starting to get stripped there generally not expensive a small engine parts store can get it for you
Jul 28, 2014 | Ryobi Garden
Why is my pull starter frozen
Most likely cause is either engine seized or cable twisted in recoil spool.Try turning flywheel and see if engine turns if so remove pullstart and check pull cord.
Jun 30, 2014 | DHK Maximus GP 1/8th RTR Nitro 4WD Truck
How do I replace the starter pull rope on TB70SS?
You must first remove the shaft assembly by removing the Torx/Flathead screws that hold on the trigger. Then you remove 3 screws that hold the engine to the shaft. Next you can remove the shaft assembly and you will see 4 or so screws holding the black surround around the clutch. You need to remove this to get to the pullstarter. Once you get to the pullstarter make sure not to release the coiled spring or you'll have a hell of a time putting it back in. Typically that are behind the pullstarter assembly.
Aug 15, 2010 | Troy Bilt Tb70ss Gas Trimmer
Pullstart jamed removed putstart rope no problem
If after removing the starter the starter pulls easily but you can not turn the flywheel the engine is probably seized. Could be a piston failure or a bearing failure. check to be sure nothing is caught under the flywheel binding it up.
Jan 14, 2010 | Echo Garden
How do i fix the pullstart, including attaching to inner coil
You can remove the cover and you will then be able to view the pulley and crank as well. You can pry up tabs on pullstart, rewind and replace.
Sep 23, 2009 | Poulan Featherlite Gas Blower, with Low...
Pullstart wont pull
sometimes the float in the carb can stick causing the gas to fill the engine, this will prevent the engine from moving and therefore locking the pull cord. check the oil, is there gas in the oil? remove the spark plug and try to pull the cord again. gas may come out of the plug hole . if this is the problem you must change the oil and fix the carb. the other cause could be that the engine is seized. ouch.
I hope this helps
Sep 01, 2009 | Garden
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
258 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
