Question about Polaroid Portable DVD Player PDM-0822BD
Right rear hinge for dvd door has broken and dvd will not play. can this be fixed?
    Sergeant:
  • 252 Answers
Yes it can. You will have to order the whole lid assembly. The DVD will not play untill you get a new lid bcause when its engages a switch.
Posted on Aug 19, 2010
Oven door hinge
Could you take a photo of the oven, the door and the hinges and show us?
Feb 14, 2014 | GE Microwave Ovens
Oven door keeps open ay ideas about the fault cheers
make this test and fix it. GOD BLESS YOU
Door Hinge
An oven door repair may be needed if the door hinge breaks or is bent out of shape. Oven doors have two door hinges, a left and right. On some ovens the same hinge is used, on other ovens the right hinge and left hinge have different part numbers. The door hinge sometimes is sold with all necessary parts and springs, other times the parts need to be ordered separately. An oven door repair for a door hinge is a relatively easy repair for a do-it-yourselfer.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Outer Door Glass
If the outer door glass is broken, it can be replaced. This oven door repair requires that the oven door be removed from the oven and layed down on a sturdy flat surface. The outer door glass is made of tempered glass. Use eye and hand protection when performing this oven door repair.
Nov 04, 2013 | Kitchen Ranges
Can anyone tell me how to make my left door speaker play plz only right side is playin 2001 maxima gle
open door and look in hinge area you will see a round rubber tube open tube and inspect for broken wires if you find broken wires repair
Jan 19, 2013 | Nissan Maxima Cars & Trucks
RIGHT REAR HINGE ON CARTRIDGE BAY SEEMS TO HAVE POPPED OUT, RENDERING THE PRINTER UNABLE TO PRINT (LID WILL NOT CLOSE ALL THE WAY ON RIGHT SIDE).
find the switch where the door presses to tell the printer its closed.
find something to press that when you want to print then remove it when you have to swap cartridges
May 05, 2011 | Computers & Internet
2002 honda odyssey power sliding door roller replacement. Is this a hard job to do?
Not very difficult if like my '99. Be sure to purchase the correct hinge for "power" door. Here are the steps:
  • Remove rear tail light (2 screws and pull from socket)
  • Remove two screws from rear of hinge cover panel
  • Remove bolt from front of hinge cover panel
  • Open door around one foot and rest the back end on something about the same height
  • Remove the three bolts from the hinge connecting it to the door
  • Loosen slack on cable by unbolting pulley under inside rear panel (tire tool storage on driver side)
  • Slide broken hinge out back of rail
  • Replace new hinge and put all back together
I don't know if there is a simpler way to loosen the slack on the cable, but this is how I did mine.
Hope this helps.
Jul 20, 2010 | 2001 Honda Odyssey
Broken disk lid
Not sure if you can find a replacement lid but you may be able to play DVD's if you manually depress the small switch that the lid would engage if it were closed. The switch is located where the lid hinges at the right side, you should see a small rectangular hole. The switch can be depressed through that hole. Of cousre, your DVD will be spinning with no lid to protect it but just don't touch it while the disc is playing. When done playing, you can just turn the unit off or remove whatever you used to engage the small lid switch.
Greg
Nov 06, 2008 | Spectroniq PDV-808
94 jeep cherokee door troubles
from the late 80's to the 90's jeep cherokees have a known problem with there front door hinges. the first time i seen this on a jeep i thought it was a fluke but now owning a 93 cherokee i am goin through the same problem... most of the time its not the door pins (i am not saying this is not what is wrong with yours, but for the most part it is not the pins). on the inside of the sheet metal, where the door hinges are welded onto, tend to rust/wear out and cause up and down play in the top door hinge. the only way to fix it is to take the door off and reweld a new brace or support underneath the sheet metal, and the weld the door back into place... my jeep is goin threw this process right now... but if you dont fix the door soon it will acually rip the top door hinge out of place, allowing the door to almost touch the ground when opened.
Sep 27, 2008 | 1995 Jeep Cherokee
Door handle broken (rear left)
broken right rear door handle on 2002 chev impala
Sep 09, 2008 | 2002 Chevrolet Impala
Door hinges broken and door fell off
yeah very easy and it should only cost at most about £10 undue the old hinge with the 2screws now the door will have two little covers that held the old hinge in place take these out and make sure u get the broken pieces out of them once u have the new 1 put it on the washer and screw down first and then place the covers on the ends of the hinges and put the door in place now redue the screws on the door
Jun 01, 2008 | Candy CN146 Front Load Washer
Polaroid Portable DVD Player PDM-0822BD Logo
181 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
