Question about RTO Ho Herpa Freightliner Truck Tractor
I have two codes on a freightliner one is sys137 icu 128
Code icu 140 columbia detroid engine
I googled: icu 140 columbia detroit engine
There are a number of answers. They should help.
May 07, 2015 | Freightliner Columbia Dash Panel: 2002...
I have a frightliner 2007 century classic with c15 cat eng its throwing inatmitting eng open 128s290 05 please advise
Are you sure that is the code? Its engine "128", but the rest isnt adding up.
Here are the all the C15 engine codes.http://world-engine-blog.blogspot.com/2013/09/c13-c15-and-c18-engines-diagnostic_23.html ENGINES AND MORE
Apr 29, 2015 | RTO Ho Herpa Freightliner Truck Tractor
We have a 2009 Freightliner Columbia that keeps giving fault code "ecu 128 51d 153". Any ideas on what this is?
not in my range of expertise as commercial vehicle but there should also be a FMI code number to go with the fault code , follow link to the freightliner web site where you can download owner manuals etc that may give you more info on your problem also a freightliner forum would be a good source of info , keep me posted if you wish
Driver Operator and Maintenance Manuals
Jun 08, 2014 | Cars & Trucks
Error codes
Content - ICU communication trouble (PCU
detection)
Detail - Communication setup
error/framing/parity/protocol error
Cause - Slave unit PWB connector improper
connection
Slave unit PWB - ICU PWB harness
trouble
Slave unit PWB mother board connector
pin breakage
Check and remedy
Check the slave unit PWB and the ICU
PWB connector connection.
Check the copier earth
Jul 25, 2013 | Sharp AR-M450N Copier
Freightliner code 128 s254 07
on 2006 freightliner century with 12.7 detroit 60 Error code
eng contreller no resp. 128s254 07.
Apr 26, 2012 | RTO Ho Herpa Freightliner Truck Tractor
Active faults 1 at startup screen
if you press and hold the mode button it should beep then you will get the component location. ecu 128 for example is in the engine- mid 136 is the abs. once you see that, press the mode button again and you will get the code. sid 123 for example- press mode button again and you will get the failure code. FL 02, could indicate when it is reading a high or low reading, short or open... etc. once you have the three parts of this code then you should be able to contact your local dealer to find out what the code means. Truck diagnostics are not always easy... active codes really just give technicians a place to start... hope this helps
Dec 16, 2009 | RTO Ho Herpa Freightliner Truck Tractor
RTO Ho Herpa Freightliner Truck Tractor Logo
243 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
