Question about Radio Shack Pro-97 Handheld Scanner
Trunking frequencies I have programmed the frequencies and the Talk group id's per the manual. The scanner is not scanning the ID's just the raw frequencies. I get noise...
Did you initialize your scanner? If you did, then you also deleted your trunking banks (1-9). These are the banks that store the channels that were inputted by you. The scanner will display "All channels locked out," when all of these banks are empty. You may have to put the frequencies in again. I suggest using win97. There is a 30day trial. This is the only program that I know of that will work with this scanner.
The pre-programmed channels should still be there. If you press and hold the scan button for a couple of seconds you should see the signal stalker running.
Good luck.
Posted on Oct 21, 2008
  • brandy337 Oct 21, 2008
    *Check that, the banks are numbered 0-9. Sorry about that. :)
How do I get the pro-2055 scanner to only hear the Trunking channels I want and by-pass the agencies I don't want to hear. I've programed the talk groups in but can't get it into an ID scan mode.
Hi, my name is John. Just L/O the ones you don't want, then SCAN..hope this was helpful Please rats this solution on the thumbs four thanks John
Sep 04, 2010 | Radio Shack Pro-2055 Base Scanner
How to program a radio shack pro 163 police scanner
The 163 is a trunking scanner, so programming instructions are long and detailed, and they vary for each type of trunking system. Programming instructions are best explained in the factory operating manual. If you don't already have it, you can download/print the manual here:
http://www.scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/PRO-163-164-OWNERS%20MANUAL_2000164_PM_EN.pdf
You may also want to join a users group for the 163. Check Yahoo or just Google PRO-163.
For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
The site also has information that explains the workings of trunking systems, links to users groups, and a lot of other useful scanning information.
Bill B
Jul 04, 2010 | Radio Shack Pro-97 Handheld Scanner
800 MHz frequency Mode problem
You have to program it TRUNKING mode when you enter the control channel frequencies. It is decoding okay as the MO shows motorola control channel and +DG means digital decoded and an OPEN group. You need to press the 'trunk' button everytime a talkgroup comes up that you want it to remember for future 'closed' group (-DG) talk groups. I suggest you go to 'RadioReference DOT com" and there are many forums there for your radio, as well as one or two YAHOO GROUPS specifically for your scanner. 73's
Jul 03, 2010 | Radio Shack Pro-2096 Base Scanner
I am looking into getting the Uniden Bearcat BC60XLT1 scanner Is this scanner capable of trunking? I guess my local police dept uses trunking freq.s
This scanner does not do the 800 Mhz trunk tracking that you are looking for. A synopsis and link to the manual can be found below:
http://www.usascan.com/files/bc60.html
Typically, a trunk tracking capable radio will cost in excess of a couple hundred dollars - significantly more depending on digital capabilities.
Your first step should be determining which services (public safety, public works, ambulance, taxi, military, ham, etc.) you're interested in monitoring. Next, list the communities in your area and search for the frequencies they use. You can find this by googling the Town,State Scanner Frequency like this:
Boston, MA scanner frequencies
Broaden your scope by substituting your county for the Town or simply search on your state. You should find links to entire directories of listings, and groups of people interested in scanner monitoring. Talk with those people or store sales personnel about a particular scanner's suitability to monitoring a certain type of service, frequency, mode, etc.
Once you've collected this info, do some research on equipment and see what fits in your budget. Ask questions in user groups for scanning and radios, too.
I hope this helps - good luck!
Mar 26, 2010 | Audio Players & Recorders
Trunking no longer works on my BCD996T scanner, Conventional work
Hi Mike,
Try updating the firmware and see if this solves the problem. While I understand that it "worked before", some of the programming software has been updated to work only with the newer firmware. Also, the newer versions of programming software are required when importing systems directly from radio database sites (such as radioreference.com).
If this does not work, try to enter system data by hand rather than importing. If trunking works then, it sounds like a software problem with your programming software versus the radio itself.
Hope this helps!
Feb 13, 2010 | Uniden BCD996T Base Scanner
Unable to program trunking after uniden download was completed
I would try redownloading and reflashing the firmware on the scanner. If this doesn't work, you may want to try downgrading to the previous version of the firmware. If you are unable to redownload the firmware from Uniden, there is a Yahoogroup dedicated to this radio.
http://groups.yahoo.com/group/BCD996T/join
Also in the files section, there are older versions of the firmware.
Hope this helps!
Feb 10, 2010 | Uniden BCD996T Base Scanner
How do you program (add) frequencies
Go to Unidens web site http://www.uniden.com/pdf/BC246Tom.pdf that's the manual. sub section "Basic Operation" drop down to "quick storing channels or talk group id's". Hope this helps.
May 21, 2009 | Uniden BC246T Handheld Scanner
Scanning Frqs but not IDs
Hi - You can download the manual from the link underlined in blue below:
Pro-95
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 13, 2008 | Radio Shack Pro-95 Handheld Scanner
Unintelliginle
Radio reference guide on the internet will be your path. You will choose your state, county, city, PD or Fire and there you will find The talkgroup ID's.
Mar 12, 2008 | Uniden TRUNKTRACKER III
Edacs frequencies
Are you getting talkgroup ID's? If not, you're probably monitoring the EDACS system in conventional mode rather than trunking. When the scanner hears those beeps, it's supposed to go back to monitoring the control channel if you're in either trunking mode (search or scan). This also happens if the CC isn't coming in very well. If you're not in trunking mode, read the manual to find out more about programming and monitoring trunked systems. If you are in trunking mode and receiving ID's, the unit is probably malfunctioning.
Sep 23, 2007 | Radio Shack Pro-94 Scanner
Radio Shack Pro-97 Handheld Scanner Logo
171 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
