Question about Intel Motherboard
What processors are compatible wit a Gateway 910GML Motherboard ?
  • 2 more comments
  • michaeljashu Aug 19, 2010
    does it have to be a gateway processor or can i use any intel processor. does 735 or 750
    represent socket type
    does it have to be a gateway processor or can i use any intel processor. does 735 or 750 represent socket type
    rying to find out if i can upgrade the processor on a laptop im thinking of getting before i get it. it is a gateway mx6121 notebook with a celeron m 1.5 ghz. i would like to put in a faster processor.
    i am trying to find out if i can upgrade the processor on a laptop im thinking of getting before i get it. it is a gateway mx6121 notebook with a celeron m 370 1.5 ghz processor. i would like to put in a faster processor.is it possible?
  • 857 Answers
Intel Celeron M processor will be the best compatible processor for this mother board.
To go in the details go the below link:
http://ark.intel.com/chipset.aspx?familyID=7419
an don the left side select compatible products you will get all the details.
Posted on Aug 19, 2010
  • Jayant Jha Aug 19, 2010
    Upgrading a processor on a laptop in most of the cases is not possible becuase all the hardware is dependend on that and it is not at all recomended as it would be very expensive it is better to buy a new laptop.
    Genius:
  • 1,478 Answers
I will suggest any of this processor,
Gateway - Intel Pentium M CPU 735
Gateway - Intel Pentium M CPU 750
Take care.
Correct Graphics Driver for Windows 7
try a downloadble programme like driver easy or similar.
Apr 24, 2013 | Computers & Internet
What is the processors that can be compatible for Intel motherboard
Confirm your motherboard's compatibility with the Intel CPU you want to install. Motherboards typically only support one type of CPU slot, so purchase an Intel processor that is compatible with that slot.
Ensuring your processor and motherboard are compatible is vital when choosing parts to build your own computer system. If they are both the same socket type, they will most likely work together.
Brands
There are a plethora of motherboard manufacturers, but only two main processor manufacturers: AMD and Intel.
Every motherboard, regardless of manufacturer, has a socket that will accept a processor.
Intel
Common Intel socket types include LGA775, LGA1156 and LGA1366. Older models include PGA370, PGA423 and Socket 479.
Your motherboard and processor will be generally compatible if their socket types match. ...
Intel Core 2 Quad Q9650 Processor Compatible Motherboards
Hope this will help you and please don't forget to rate me. Thanks for using FixYa
Aug 02, 2011 | Intel Motherboard
What if the fan is running and the air way is clean, lots of hot air blows out and my comp. and it shuts down every 5 or 10 mts. Could it be the cpu? or is there other device known to cause this...
The most probable cause is your Processor gets Overheated and causes restart to your system. Try having a suitable CPU Fan or go for a compatibility checking issue for your Motherboard and Processor.
Feb 01, 2011 | Gateway M305CRV Notebook
Replaced Gateway 105552 Foxconn C51GU01 Motherboard with another
Are you sure it is a good MB? If so double check all connections and try again. If you still have problems post back and let me know if you are getting any beeps at startup.
Jul 07, 2010 | Gateway GT5058 Desktop PC
BAD MOTHERBOARD ECS MCP61P-AM Motherboard
You can. Just make sure it's compatible with the same processor, RAM etc...or it may cost you more in the long run.
You can bring that spec into the local computer store, ask them to just either replace or upgrade...make sure you tell them you'd like to use the same processor, RAM etc.
I hope that helps.
Jul 09, 2009 | Computers & Internet
Motherboard for Gateway gt4022 fried. Replacement?
if you want to reuse the processor and Ram from the broken board you'll need to buy a board that they'll be compatable with ....I would suggest going to your local independant PC shop and getting some quotes....also bear in mind that some motherboards come with different ports on the back eg parallel printer port....so make sure the board has what you need
Jan 11, 2009 | Gateway GT4022 PC Desktop
Re aspire 7104 being upgraded to duo core processor
No it cant be updated
Your acer aspire is based on the 910GML chipset
The Mobile Intel® 910GML Express chipset is optimized for the Intel® Celeron® M processor.
Here you can compare the 910gml chipset and 945 which is used by the core 2 duo.
http://compare.intel.com/pcc/showchart.aspx?mmID=22210,7419&familyID=7&culture=en-US
As you can see on the page there are key difrences between the chipsets other runs on ddr2, yours on ddr. the FSB support is 400 on yours and 533 / 667 on the 945.
also you can see the supported processor familys right there.
you can look for a
Intel® Celeron® M processor,
Intel® Celeron® M processor Ultra Low Voltage (ULV)
Upgrade cpu with maximum FSB of 400MHz
Apr 28, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Power supply
fan o. k
get the eq wit a bootable win. disc and run into the bios for a new set in xp
Oct 15, 2007 | Gateway (4000484) Motherboard
Upgrading a Gateway M1200 to a M1300...
You can replace any motherboard, so long as your processor and memory are compatable and it fits into your case.
Mar 02, 2007 | Gateway M1200-3004265 Tablet PC
Upgrade from 600 MHz to 1 GhZ
According to this review, you can upgrade as far as a 2 GHz P4-M at least; http://www.pcmag.com/article2/0,1895,669029,00.asp Other than that, i have been unable to find the details of your motherboard - if you can post the make and model (should be printed on it somewhere) then I would hope to find a more complete list of compatible and incompatible processors. Gateway themselves no longer offer online info or support for this model, but the motherboard details should enable me to find out what you need to know. Waiting for your post :)
Nov 04, 2006 | Gateway Pentium III , 600 MHz (1515824)...
Intel Motherboard Logo
132 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
