Question about Lanzar HRB212 Car Subwoofer
In the Lanzar HRB212 bandpass enclosure.. are the 2 subwoofers wired/connected in parallel or two independent connections? What is the individual rating/specs of each subwoofers?
    Genius:
  • 1,340 Answers
I looked at a couple of sites and one site said two 4 ohm subwoofers.That means they have to be parallel.It didn't say about the connections.Here is a link that better describes them.They are loud.I SAID HERE IS A LINK THAT BETTER DESCRIBES THEM.LOL Good luck and rock on! Greg
http://www.onlinecarstereo.com/CarAudio/p_16424_Lanzar_HRB212.aspx
Posted on Aug 19, 2010
How do I wire a lanzar vw10d
Subwoofer had dual 4 ohm coils.
3 solutions:
Parallel: (recommended) Wire each + and - together, then to the amp will give a 2 ohm load.
Independent: Wire each + and - to an independent channel on a 2 channel amplifier, this will be a 4 ohm load on each channel.
Series (not recommended): Wire + from one side of the woofer to - of the other side of woofer. Wire the other + and - to the amplifier to give an 8 ohm load
Apr 08, 2014 | Car Audio & Video
There are 4 connectors on each side of the speaker, how do i wire it so i can put the sub in the box so i can connect it to my amp?
There are 4 connectors on each side of the Problem with the Lanzar 15'' 2000 Watt Dual Voice Coil Subwoofer Driver for Small Enclosures Car Speaker. how do i wire it so i can put the sub in the box so i can connect it to my amp?
Dec 24, 2010 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
How do you bridge a dual voice coil
use a decent wire (same gauge as you would use to connect it to your amp) and connect it between the "+" pole of one coil and the "-" pole of the other coil. use the 2 other poles to connect the speaker to the amp. Have a nice day!
Dec 14, 2010 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
I have a lanzar max pro 15'' subwoofer and i need to know how to wire it. It has four wire inputs on each side teo positive and two negative, is this just to change it from 4 to 8 ohm or something?
In part yes it is a flexibility for wiring your speakers to match the impedance of your amp. For example if your subs are 2 ohm dvc by wiring them in parallel you can drop the impedance down to 1 ohm per speaker and if you connect two 1 ohm then you get 1/2 an ohm load. Or you can put them in series and increase the impedance to 8 ohms which I wouldn't suggest you do. Here is a link to wiring speakers:
http://www.crutchfield.com/S-cgSECUmngLm/learn/learningcenter/car/subwoofers_wiring.html
Sep 19, 2010 | Lanzar (Pair) MAXP104D Max Pro Series...
How do wire my 15'' to 1ohm
If each voice coil is rated at 2-ohm, then wire it in "parallel". This will make a 1-ohm total load.
amp pos. out to coil 1 pos. to coil 2 pos.
amp neg. out to coil 1 neg. to coil 2 neg.
If the they are dual 4-ohm, the rating would be 2-ohm in parallel.
Mar 16, 2010 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
Want to find out the best type of enclosure for 2 lanzar max pro 124d subwoofers
you best type of enclosure will be a sealed enclosure or you can build it with a partition in the middle seperating the 2 subs and port each side.
heres a link that will give you the specs for your sub
http://www.lanzar.com/manuals/MAXP104D-124D-154D.pdf
Sep 07, 2009 | Lanzar (Pair) MAXP104D Max Pro Series...
How do you wire up a dual voice coil lanzar 15 for 4 ohm?
Hello dexterchapma,
The only way to wire a single 4ohm DVC sub to present a 4ohm load is to just connect one voice coil. If you wire the coils in parallel, you get a 2ohm load. If you wire them in series, you get an 8ohm load. But it will work great with just one voice coil. Or if you really want to use both voice coils, and your amp isn't stable at 2ohms, wire the voice coils in series and present an 8ohm load to the amp. It'll work fine, it just won't deliver quite as much power.
Hope this helps.
Jun 27, 2009 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
Need amp
Hi and welcome to FixYa,
It would be safe to use an amplifier slightly lower than the maximum rating of the speaker. In this particular case, 350 watts or lower would be just about right for each. If you are wiring the 2 subs in parallel and powering them with a single channel amp, then a 700 watt bridged would also work.
Good luck and thank you for using FixYa.
Apr 09, 2009 | Hitron 2 12in Subwoofers loaded in...
2 12" Hitron 600w subs in a BandPass box
Remember that driving a load with an underpowered amp will probably cause more problems than having a more powerful amp that is not running flat out. 200-300W amp would be ok, but I would suggest going for the biggest you can afford. If you crank up the volume on the smaller amp you will probably get a fair amount of distortion, which may actually damage the speakers. A larger amp will not give as much distortion for the same loudness/volume and give better control of the speakers for a tighter bass..
Oct 31, 2007 | Hitron 2 12in Subwoofers loaded in...
Lanzar HRB212 Car Subwoofer Logo
55 people viewed this question
Top Lanzar Car Audio & Video Experts
Radames Pagan
Radames Pagan
Joe Alexander
Joe Alexander
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
