My pc is not booting well every part of this pc is working properly, it gives flash but it is un able to boot
  • 4,281 Answers
Make sure harddrive is recognized in bios. You can check it in bios setup for that when you power up the computer press F1 or F2 or del aLT+F2 key to enter in bios then you can see bios setup load optimal defaults settings Check your harddisk is recognized in main bios page. Open cpu cabinet then reconnect RAM memory and both connection to harddrive . Then check. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Aug 19, 2010
Boot by USB drive
The most likely problem is that some of the information is missing. is the Bios file on the Stick and is it un-compressed? you also need to ensure that the Bios flashing software is on the stick. But, for better info, go to the website where you downloaded the BIOS file and read the instructions there. They always give instructions for BIOS flashing. (well I haven't found one that doesn't yet)
Jan 28, 2012 | Asrock GE PRO-M2 Motherboard
I can't boot from the Internal, or via an External USB connected \r\noptical drive? Any suggestions? Is a boot via a Flash drive possible on the PCG-K45? Many thanks for any input...
hello, have you tried changing device boot orderfrom BIOS?
you should change device boot order or press the appropriate button (commonly F10) during POST (when laptop starts to initialy work, it writes which button the first 5seconds that it starts to work) and then you will see a box that shows all the availiable devices to try to boot from. All computers and laptops can boot from any internal or usb if these devices work properly and have a proper image to boot from.
Sep 18, 2011 | Sony VAIO K45 Notebook
Hi, I have downloaded from DELL website the Dell Dimension 5150 BIOS to upgrade the BIOS. I followed all the steps successfully and restarted the system but it just showed incompatible BIOS on start-up....
first to get a properly bios you need to get the whole description and download it to an floppy disk if it does if not try to boot from a cd...theres a hirens boot cd tools to fix since you already flashed wrong i assume you have some experience use the key tag of yor dell to get properly drivers...
May 27, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
RES. SIR, CAN WE PROPERLY BOOT WINDOWS XP/7 TO PC USING USB PORT(PEN DRIVE/MEMORY CARD)? IF YES THEN PLEASE TELL WHICH BACK UP WE HAVE TO KEEP IN PEN DRIVE (XP IMAGE OR COPY OF DATA),PROVIDE THE VALIDE...
To create a Bootable USB flash drive or pen drive you can try the steps on this website: http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/
Note: This only works for windows 7 and windows vista.
For BIOS settings you need to set the first boot on USB Device. If you can give me the brand and model of your computer or BIOS version I might be able to give you the step by step information on how to set your first boot on USB Device.
Apr 23, 2011 | Computers & Internet
My desktop compaq presario s4300nx starts up , i can accses set up with f1 but cant start recovery with F10 however the F10 button works in setup, no good to me, ...i have recovery disks the pc just...
you will need a Windows boot disk / Windows install disk / WinXP disk to reboot the PC and install / or repair your OS
rescue disk will not boot your PC
to enable that you need to enter the BIOS, press F1, F2 or Del to enter BIOS , then you need to look for the BOOT seq in BIOS, change that to CD DVD drive as the 1st boot device, Save and Exit and insert the boot CD and restart
this should give you the solution
Dec 16, 2010 | HP Compaq Presario S4300NX (DF216A#ABA) PC...
Problem installing graphic card radeon hd5670. After installing the card in the PCI slot the pc cannot boot up properly but if i remove the card it can boot up smmothly without any problem... Help me with...
Disable the original driver,put It in a flash drive or floopy ,back up your registry and install your new driver from a place you can find It ..i.e
floopy works best if the new driver has a un-install choice
Mar 26, 2010 | Computers & Internet
My gateway e6100 cant boot from a flash drive it flashes at the balck screen with the cursor in the top letf corner then goes to normal boot sequence
u need to change the preferences for booting technique....when u start your PC try to enter into BIOS settings.....change the boot give first preference to USB....and save it may try to boot from USB
Mar 04, 2010 | Gateway E-6100-C PC Desktop
Not booting up, flashing screen
some time our optical drive can not boot cd. so we use new drive to check it.2/ sometime ram can work in computer but not boot so we change ram to check boot error. 3/ your bootable cd is not working properly.change it to check. if you do three treack you can solve your problem thanks(nepal)
Jul 07, 2009 | ASUS Eee 4G Notebook
Ram upgrade issue msi 845 pro motherboard
you should check bios for the ram settings, voltage and speed, they will be printed on the package the ram came in.
also, you don't want to mix ram up, they will run at the slowest ones speed.
also, most ram is used in pairs (2 at a time) using the 3, depending on the motherboard will give you errors.
try entering the bios on boot, and set the ram setting properly. you should see something that flashes on boot, like press f8 or del for bios. change your ram settings, save and exit. type back with your motherboard and ram model numbers if this solution did not work.
Jun 25, 2009 | MSI 845 PRO Motherboard
I get a black screen saying windows cannot load
Are you able to boot in safe mode?
Are you able to boot from cd?
you may have to reinstall windows.
May 10, 2009 | Acer Aspire One PC Notebook
Computers & Internet Logo
David Payne
David Payne
