Question about GE Nautilus 24" Built-in Dishwasher
My dishwasher is not cleaning. It is a GE built in and the serial # is MS721122B, and the model is PDWT400P00BB. It leave a greasy feeling on the dishes and the inside of the dishwasher is dirty and sticky. I use Cascade and hot water. Help!
  • GE Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
sart3
Posted on Sep 29, 2010
Must the water supply be hot water or can one connect cold water
most dishwashers use hot water to obtain a clean finish for the utensils
You could use cold water but I think that any grease would not be dissolved properly from off the plates leaving plates and glasses with streaks and a greasy feeling
Aug 05, 2015 | LG LDF7932ST fulintegrated steam...
PDWT300R10WW
Check the pump and filter for blockages as the dirty water may be not draining properly. A mix of detergents is ok. Run a prewash with the unit empty and see if the water is still greasy
May 09, 2012 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwasher overflowed, garbage disposal still works. Ran the dishwasher and noticed food and debris shooting back into sink thru garbage disposal. Water was on floor. Upon completion of full cycle, water...
Before loading into the machine you have to remove food particles. Washer will wash the greasy surface. If particles are left in the dishes, the same will find entry to the drain system. Check the drain filter in your machine. Clean them. Mostly problem will be solved!
Apr 08, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Is this GE Profile dishwasher recalled?
No recalls on any GE Profile model dishwashers. (there may have been service bulletins, but no recalls) Also, you missed the first two letters of the serial number.
You can go to this web site http://www.geappliances.com/products/recall/ to find info on any GE recall.
May 07, 2009 | GE 25 in. PDW7380JSS Stainless Steel...
LG dishwasher wont clean top rack dishes
Recommend you remove the approximately 10 screws to pull the entire filter and manually clean. Remove all debris you find and thoroughly rinse out the filter if you can separate the top from the bottom. If the sump area is greasy, use a de-greasing spray to cut through it. Resemble, checking that there are no blockages in the holes on the spray arms.
Fill a bowl or cup with white vinegar and place it on the lower rack of the empty dishwasher. Do not add detergent. Run the quick cycle. The inside of the dishwasher should now be clean and not greasy. If still greasy, use the de-greasing spray (avaiable at all stores in the cleaning section.)
For 30 days, use only Electrosol or Cascade powder. Do NOT use gel or tablets, ever. Please report back your results. Good Luck!
ianc435 , please ask your question in as a new problem and I will help you out. I understand your problem.
Jan 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
White film on glasswear.
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Nov 08, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher spraying greasy spots all over pots & stuff after cleaning
Feb 25, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Water not hot
Dishwashers are suppose to be hooked up to hot water. If you had hotter water it would clean just fine. 120 deg or more!
Nov 01, 2007 | Zanussi 24 in. IZZI ALU Built-In...
Doesn't drain
You have a bad drain pump or something clogged in it. Will have to pull dishwasher out to fix.
Mar 18, 2007 | GE 24 in. Profile PDW9200J Built-in...
GE Nautilus 24" Built-in Dishwasher Logo
117 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
