Question about Dometic Rooftop RV Air Conditioner
We have a 2006 Puma. The a/c workd great earlier this year. Now it won't even blow. We discovered it wouldn't work when it was in the 90's. What do I need to check/do?
Turned off a/c and generator before bed, went to turn it on today and nothing, not even the fan will come on. Don't see fuses, but breakers. This is in/on a 1987 Toyota SunLand Express RV. In the past, when we've over loaded we'd hear a click in the area of the breaker box the unit would quit but there wouldn't be any breakers flipped, then a half hour or so later we would try again and it would work. This is the first time we tried to use it and it just did not work.
Posted on Aug 20, 2010
    President:
  • 3,773 Answers
Check breaker box for blown breaker and check voltage.
Try tapping on cold control with back of screwdriver (the knob that
turns it on.) It might have set up and stuck over time.
I have started many this way.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 19, 2010
My 90 model 454 chev 3500 was runnin great.. Then a few months ago.. when it was raining it started spitting and sputtering, but only when it was raining.. When it was dry it ran fine... The other day I...
i would think it may be a distributor cap or wires as they are the only things that when wet are a problem like you mention or the coil may have carbon tracking try looking at coil and cap at night when dark and see if you see any arcing if you do there is your problem
Aug 17, 2013 | Cars & Trucks
My LG GC900f's camera suddenly won't work. I last used the camera three days ago and it was great, but when I tried it earlier, it just won't open. Even the apps that need the camera, won&
Don't take it to any normal technician. Go to Authorized service of LG and get it done. It is not any software issue, i think it is hardware problem.
Performance Chip
Aug 21, 2012 | LG GC900F Cell Phone
Why 2006 Chevy Trailblazer air conditioner blower does not blow
Theres a module inside the blower housing that seems to be a problem on these vehicles. Mine wouldn't blow on 5. Took it apart and discovered it to be a bad connection where this module plugs into the harness or something in the module itself shorted as one of the pins looked as if it had been hot and the plastic around it was melted. Theres 2 different parts available, one is about $60 and the other is $25. Get the higher one because its the newer designed part that wont fail.
Sep 01, 2011 | 2006 Chevrolet Trailblazer
I have a 2006 Pontiac GT G6 Coup. When we first bought it back in Nov. 2010, it was fine. After a month or two, the clock would reset almost everytime the car was started, radio stations would NOT get...
sounds like a problem with the ignition barrel.the wiring is loose or the connectors are loose or the barrel is faulty,unless thse are all run from the onboard computer.
May 31, 2011 | 2006 Pontiac G6
I have a 798ci HD SI that has always workd great. I replaced the mounting bracket for the transducer not long ago. A few days after i discovered that the side imaging and GPS is no longer working. What...
Check the height of the transducer, it could be mounted too high. Most manufacturers will suggest mounting the transducer 1/8" below the bottom of a fiberglass boat and 3/8" below an aluminum boat. Check your manual for the manufacturers suggested mounting height.
May 22, 2011 | Boating
The mower started. then just quit like ran out of gas. we blew thru the gas line going into the tank. then cleaned out filter. it won't start. at first it wouldn't even drain any gas out but we...
If the gas won't even drain from the tank, try removing the gas cap. It has vent holes and if this is plugged, the vacuum won't let the gas drain. If that is the case, clear the holes.
Gary
May 19, 2011 | Cub Cadet Street Sign- tractor lawn riding...
06 silverado blower fan won`t shut off finally killed battery
The connection at the blower resistor on these model years had problems with poor connections.
The increased resistance on the terminals caused them to heat up and burn. Some would go open circuit and not work at all and some would short to ground and run all the time, like yours.
As you have already discovered, you will need to replace the pieces.
Nov 01, 2009 | 2006 Chevrolet Silverado 1500 2WD
PALM DESKTOP CRASHES in new installation.
Make sure you have the latest desktop version which was 414E When you try to reinstall the desktop software DO NOT select or allow update setting over internet. Some of the earlier versions had a problem with earlier xp versions. It is stable and works well with sp2 and sp3 versions of XP so update your windows as well.
May 05, 2009 | Palm LifeDrive Mobile Manager Handheld
Dometic Rooftop RV Air Conditioner Logo
71 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
