Question about Candy CDV262 Dryer
Press on/off switch tumble drier starts then turns off straight away. is it ok to switch the heat setting knob with the on off knob?
  • Candy Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Aug 20, 2010
My tumble drier door isn't shutting so it won't turn on?
Make sure the wall plug is hot and if it is ok then check the dryer door safety switch, if that switch fails to connect when the dryer door is closed then the dryer will not start.
Jun 30, 2017 | Dryers
Whirlpool AWZ 7686 Tumble Dryer heater works for only 10seconds
Might want to check for an obstruction in the outlet of the exhaust
Well if you had mention that in the first place I wouldn't be asking you. No wonder your trying to fix the problem by yourself because with that attitude you can't get a technician to come out for service.
Sep 12, 2015 | Whirlpool Dryers
I want to know that on my washing machine lg-80BKF21P model the time(min) 10 minutes was remaining and the washing process is done,it ends but after drying all is done but 10 minutes were remaining and...
tumble driers and combination washer driers have a 10 minute safety margin, where the heat fior drying is dispersed, to avoid people grabbing very hot clothing.. especially if it is not quite dry as this would make them, hotter to the touch.
Tumble driers usually continue to tumble, but blow cool air through the clothes to get rid of the heat, before stopping.
Oct 02, 2017 | LG Washing Machines
Timer knob not turning and its not heating up
If you are setting the knob to begin a cycle AND the drum turns when you start it AND the timer knob does not advance, the timer is likely defective.
Some dryers with truly automatic cycles (using moisture or temperature sensors) will not advance the timer if there is a no-heat condition due to a bad thermostat or heating element. This would show as the dryer tumbling a load forever and the clothes are cold and wet when checked.
If the dryer will not do anything at all AND the timer knob does not advance, check the power (circuit breaker/fuse), then the dryer door switch. When the door switch is defective or the door isn't fully closing, it stops everything, period. There is a thermal fuse on some machines that will also cause this problem.
Good luck from Detroit, MI.
Oct 19, 2011 | Dryers
Simpson sirocco clothes drier tumbles ok, but heater not working
Bad heating coils, or bad ignitor if gas.
Jun 21, 2010 | Dryers
My zannussi TD4113W tumble drier has stopped tumbling .It still is heating up ok .Can I fix it ?
it sounds like the belt has broken or the motor has burned out try starting there
good luck
May 15, 2010 | Zanussi TC7114W Electric Dryer
The tumble dryer tumbles but I have no heat and the filter light
Since the heating element is not heating up when powered up you must have a bad heating element.
Oct 06, 2009 | Candy CDC266 Dryer
TUMBLE DRIER-INDESIT IS70C
hi did u check the hoses from the pump and check the pump for any obstructions.
Feb 14, 2009 | AEG Washing Machines
Candy CDV262 Dryer Logo
96 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Eddie Dalton
Eddie Dalton
Are you a Candy Dryer Expert? Answer questions, earn points and help others
