Question about Linksys Wireless-G WRT54G Router
I can not get access to internet
I have wireless connection but jus locally, If I conect stright to my ABA moden I have internet connection. How I can fix this problem?
  • achaps Dec 21, 2008
    i have a wireless b befw11s4 router and its older but worked great at my old apt. Now I have it connected to a dsl modem and I connect to the network...but it always says local access only. called linksys and they dont speak english. Nor were they helpful ...at all. pleaaase help.
  • Bill Jones May 11, 2010
    I need a little more information to properly help you.
    First off, I need your set-up and ISP. How exactly do you have your modem and router set-up?
    Brands of your modem and router would also help.
What is the operating sys on your computer
if vista
and if you know what is the wireless encryption key
then
right click on the network icon ( on the bottom right hand side)
chose network and sharing center
then on the right hand side select manage wireless networks
click on add a network
choose to add a network that is in the range
from the list of the networks found click on your network
when prompted enter the n/w key and once connected click on finish. hope that helps
Posted on May 02, 2008
  • 197 Answers
Open a web browser and go to 192.168.1.1. make sure that you are hooked up useing a cat 5 cable directly in to the router when you reconfigure your router or else it wont work then once you have the router configured, then you can connect your moden up and the route will configure the ip address from the modem, if that does not work you will have to call linksys and they will help you
HI! in my workplace, the network has two routers, a US-Robotics in which it is connected the internet cable, and then a wireless D-Link G607T conected do the US-Robotics to deliver wireless network to the...
If you are trying to gain access to it from outside of the network the local IP will not work.
Also, if you are doing port forwarding are you entering the port at the end of the IP address? ( example: 74.151.45.215:88 )
Hope that helps!
Feb 28, 2011 | Computers & Internet
Wired connection don't work, but wireless do.
You can use your USB connection on your Cable moden for your Desktop PC and then bridge to another through that computer's Ethernet connection to another's Like your Laptop. you can go into your network center on your desktop and go to your connection's status, then go to the sharing tab and check "Allow other computers to access this connection to the internet" or such as.Thsi can work for you Xbox 360 as well, it worked for me
May 06, 2010 | D-Link 802.11g Wireless Router WBR-1310...
When I type in the IP Address for the DWL 2100AP, which is 192.168.0.50, nothing happens, it is not available??? What do I do?
go to my network places right click then properties internet protocol tcp ip
put this 192.168.0.66
255.255.255.0
ok
when the local area connection is conected go to your explorer then type 192,168,0,50
Oct 23, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
CONNECTED TO WIRELESS MODEN BUT LOCAL ONLY
This can happen for a couple of reasons. 1. The wireless card is not working correctly either because of driver issue or it is on it's way out. 2. The security key is not being accepted.
Try resetting the router by pushing the reset button in back of the router when it is powered up. Then try connecting without any security settings. Sometimes the security settings cause problems if you use any other settings besides the WEP 64.
Aug 01, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Lan internet
the easiest way to setup internet on the laptop, is to go to control panel, and launch the network setup wizard. this will enable you to setup a new network, and scan for a local area network connection. this will also give you access to the troubleshooter. to solve any connection problems or issues, should there be any. If your using a wireless method. Your PC must also be able to transmit/receive wireless Signals. If hardwired you,ll have to use the network setup wizard, as this will auto determine I.P And any other DNS settings et,c.
Hope this Helps Mike @ compurepair.
Jan 14, 2009 | Toshiba Satellite Pro L300 Notebook
Trouble connecting new laptop to the internet
when you put the mouse over the network icon in your taskbar, it will say access: Local & Internet or local only.
if Local & internet you have a connection to the internet, if local only then open internet explorer, tools, internet options, connections and check that there is no default connection, it should be never dial a conection thats ticked or greyed out.
Aug 31, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
D-link problem
connect to the routers configuration web page at http://192.168.0.1 from the working pc
at the wireless settings
ensure wireless is turned on, is probably off if not previously used
read the security WEP WPA settings and copy them to the settings page on the ipod
Jul 16, 2008 | D-Link DI 514 Wireless Router (DI-514)
Accessing the Internet
goto start
click run
type ncpa.cpl
click ok
network connections will come up
right click on wireless network conections
goto status and check whether sending and receiving packets are fine or not , it shud not be zero
goto support category on top of that window and check whether you are getting correct ip address or not
try to disable and enable the wireless network conections
Feb 18, 2008 | Computers & Internet
Agere systems ac'97 modem and wireless internet
you can not connect to ur modem wirelesly unless ur modem has wirless plugins in it..
Well the firmware upgrade wont help u unless u have wirless plugin hardware in ur modem
In that case u would require to contact ur ISP(internet service provider) to get wireless modem
srini
Feb 09, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
67 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
