Question about NexxTech NSFTMD1
Modem is making loud connection sound itself
When dialing, sound muted, the modem itself is making loud connection sound. Is there any way to disable since it is coming from the card itself?
  • 593 Answers
Unsolder the speaker, its the black can with the hole in it. No other method unless it attaches to the sound card via a cable.
Posted on May 19, 2008
Thanks for the suggestion but I fixed it already. I had to do it twice but it finally worked. In the control panel, modem under properties, modem, speaker off. I then had to go thru system hardware, device manager, modem. Don't know why it didn't work 1st time but itfinally did.
Unmute dial pad
The sound of the dial pad can only be adjusted with the silent/mute button on the top left of the phone. If it is switched to silent then the dial pad will make not make sounds, if it is on loud then it will make sounds. There is no other way to adjust the sounds of the dial pad.
Feb 08, 2013 | Apple iPhone 4S
Hi, to every one. I need to disable a dial tone from my laptop modem to make a data call to plac from omron. When i call from local because the sound is one tone, it dial but when i call from standard...
Nov 19, 2009 | Agere All 56K Modems: 56K V.92 Lucent/...
My modem doesnot dial out with winfax pro
can you disable your firewall and tried to connect with
internet and if possible disable the winfax pro and try to make a connection
Oct 16, 2009 | Symantec WinFax Pro for PC
I have a Toshiba Satellite A305-s6916,modem is not connecting
Get a external modem and try that, But first try and connect network.Start- Control panel , delete current Network and make new one. If its Vista it will repair itself. just follow the bouncing prompt
Jul 30, 2009 | Toshiba Satellite X205-SLI1 Notebook
I did not get a windows disk-I am trying to install total fax vs
If you are not using your modem to connect to internet or something else you can get by... Follow the steps...
Right click on "my Computer" click on "properties" click on "Hardware" tab click on "device manager" Find your modem in the list and click on it once. On the menu bar at the top click on "action" and select "disable" That should stop your computer looking for drivers for your modem.
If it doesn't work, it may be your web browser. Check your internet connection settings and make sure you browser is not trying to use dial up connection. Go to your internet explorer properties click on connection tab and check "never dial" option for dial up connection. Good Luck :)
Feb 21, 2009 | Intelliquis Total Fax (779406) for PC
Trying to launch internet gives me error 680.
680 - There is no dial tone.
All versions of Windows are affected by this error.
No dial tone: There are many possible causes of a No Dial Tone Error.
First, try testing the modem's ability to detect dial tone and to dial by using HyperTerminal with the direct to COM port connect method - see Using HyperTerminal. If you give your modem an AT&FX1 command, and then a dial command, dial-tone detection will be disabled; if you still do not get dial tone, the modem may not be installed correctly (especially if it is a PCI or soft-modem); or the cable from the modem to the phone-line jack may be bad or installed in the wrong connector on the modem - try another line cord, and make sure you are plugged in to the LINE - not phone - jack on the modem. Plug a regular phone into the phone jack on the modem and make sure it has dial tone. The modem may also be defective. Many new modems come with an electronic circuit instead of the traditional electro-mechanical relay used to take the modem off-hook. Some of these designs are proving less reliable; often, they will be 'stuck' in the off-hook position, so unplugging, the plugging in the phone cord may give dial-tone. If this is the case, the modem needs repair or replacement.
If the modem will blind dial (x1), but not detect dial-tone otherwise, the problem is likely to be in the proper selection of the Country in Windows->ControlPanel->Telephony or in improper installation of the modem or lack of support for your country in the driver you are using. Check to see if there are updated drivers for your modem.
If the modem dials properly with detection (x3) in HyperTerminal, but does not detect dial tone when using DUNs, the problem may be DUNs (check for upgrade or re-install) or the proper setup and modem selection for the DUNs connectoid.
For Embarq telephone service customers, this error can indicate that you have a message waiting in your voicemail. Embarq changes the dial-tone sound to a "fast" busy signal when a new message is present in your voicemail box. This "fast" busy signal can confuse the modem into thinking there is no-dial tone present on the line.
Jul 02, 2008 | Microsoft Windows XP Home Edition
Thanks, I'll call my old ISP!
Your ISP's proprietary software should detect whether your modem is getting dial tone or not, so that's how I would check the modem. Another way to test the modems connectivity would be to connect an active phone line to the in port and a landline phone to the out port and see if the phone gets dial tone?
I don't think you need to worry about disabling your network connections as there should be no conflict especially since you have no network cable attached (your ethernet/networking card will sense a connection or not).
Keep me posted.
Apr 04, 2008 | Computers & Internet
Error code 680 when I try to connect to my server
The error 680 means There is no dial tone. The modem is not detecting a dial tone There are many possible causes of a No Dial Tone Error. 1.Check cable is correctly inserted into back of modem and phone socket 2.Check properties of connection, make sure correct modem is being used 3.Disable "wait for dialtone before dialing" in My Computer > Dial Up Networking > Properties of Connectoid > Configure > Connection > remove checkmark under call preferences 4.Try removing fax machines or other devices connected to the line 5.Make sure no one is using the telephone when trying to connect
Jul 07, 2007 | Actiontec (GT701) Modem
NexxTech NSFTMD1 Logo
128 people viewed this question
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Joe Goldman
Joe Goldman
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
