Question about Canon P23-DHV Calculator
Can not figure out how to load paper - Canon P23-DHV Calculator
    President:
  • 1,194 Answers
Visit this link and see page-3 (Procedure for paper loading)
Good Luck and have a nice day
Rating the solution is highly appreciated.
Posted on Aug 19, 2010
HP OfficeJet Pro 8600 tray can't be inserted all the way. Stops with 3 inches of tray sticking out.
  1. Grasp the handle on the front of the input tray, and then pull the tray towards you to open it.
    Figure 1: Pull out the input tray
  2. Slide the paper width guides out as far as possible.
  3. Remove all paper from the paper tray.
  4. Inspect and remove any foam or tape packaging materials in the paper tray.
  5. Insert a stack of unused, plain white paper (with the print-side down) in the center of the tray.
    Figure 2: Load paper into the tray
    CAUTION: Do not load any paper above the solid red lines on the sides of the tray. Do not use torn, wrinkled, perforated, wet, or folded paper. Make sure to remove all paper clips and staples before loading the paper. Figure 3: Stack label height
  6. Slide the paper guides in so that they rest against the edges of the paper, and then insert the tray into the product and push it forward until it clicks into place.
    Figure 4: Slide the paper guides in and reinsert the tray into the product
  7. Pull out the tray extender on the output tray.
    Figure 5: Pull out the tray extender on the output tray
Step two: Load paper in optional Tray 2
Tray 2 is an optional accessory. Follow these steps to load paper in Tray 2.
NOTE: Tray 2 supports only plain letter or A4 paper.
  1. Grasp the underside of the tray, and then pull out the tray from the bottom of the printer.
    Figure 6: Pull out the tray from the bottom of the printer
  3. Load a stack of unused, plain white paper (print-side down) in the center of the tray. Make sure that the stack of paper aligns with the engraved lines in the tray.
    NOTE: Load Tray 2 with only U.S. Letter or A4 plain white paper.
  4. Slide the paper guides in so that they rest against the edges of the paper.
  5. Carefully reinsert the tray into the printer, and then push the tray forward to close it.
    Figure 7: Reinsert the tray into the printer
  6. Pull out the tray extender on the output tray.
    Figure 8: Pull out the tray extender
Load specialty paper Follow these steps to load specialty paper such as card stock, envelopes, photo paper, or labels.
Before you proceed, verify that your printer supports the specialty paper on which you are attempting to print by viewing the product specifications . If the size, type, or weight of the paper is not available, the printer does not support printing it. Also note the tray loading capacity for the type of paper on which you are attempting to print.
Sep 27, 2013 | HP Officejet Pro 8600
How to load photo paper in paper tray canon mg5220
For front or front tray loading printers, shiny side down... for rear/back loading printers.., shiny side up. Pictures should be visible coming out of the exit slot. Using pre-cut photo paper requires some technique, if the paper holder does not have an adjustable paper width feature. Feed paper in one sheet at a time to prevent jambs.
Aug 27, 2012 | Canon Pixma MG5220 InkJet Printer
Light flashes next to "check printer cartridge"
For an illustrated version of the text below go to: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00095617&cc=us&lc=en&dlc=en&product=306895&tmp_track_link=ot_search
Check Paper Light Blinking
Figure 1: Check Paper light blinking At the start or in the middle of a print job, the Check Paper light begins to blink. The unit will not print. If the unit is connected to a computer and the HP software has been installed, one of the following messages is displayed:
  • There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume, or Okay button on the hp psc.
  • The unit is out of paper. Load more paper and press the Enter, Resume, or OK button on the hp psc.
If both the Check Paper and the Check Print Cartridge lights are blinking simultaneously, or if the computer message is The print cartridge carriage is stalled , click here for troubleshooting information . Step 1: If the unit is out of paper, load more paper
  1. Move the paper guide out, load the paper, then adjust the paper guide. Make sure the paper is flat in the tray. Figure 2: Load paper
  2. Press the On/Resume button. Figure 3: On/Resume button
If the unit is loaded with paper and the light is still blinking, go on to the next step. Step 2: Remove jammed paper from the rear of the unit
  1. Unplug the product.
  2. Press the tab on the left side of the rear access door and remove it. Figure 4: Unlatching the rear access door by pressing the tab on the left
  3. Remove all the jammed paper and foreign material. Pull the paper slowly and gently to avoid tearing it or damaging the print mechanism. Avoid touching the internal components.
  4. Replace the rear access door. Put the pins on the right end of the door into the holes on the right side of the rear access area. Then snap the door shut. Figure 5: Door pins in product holes
Step 3: Check the front of the unit for jammed paper
  1. Open the cartridge access door in the front of the unit. Figure 6: Open the cartridge access door
  2. Pull out any jammed paper or other foreign material you were not able to remove from the rear. Pull the paper slowly and carefully to avoid tearing it or damaging the print mechanism.
  3. Close the cartridge access door and plug the product back in.
How to avoid paper jams
  • Only insert paper into the paper tray until it meets resistance - do not push it farther in.
  • Make sure the paper is flat in the paper tray and the guide is adjusted to the width of the paper.
  • Do not add paper while the unit is printing.
  • Remove printed pages frequently.
  • Do not use paper that is too thin, too slick, or that stretches.
  • Do not use torn or creased paper. Paper that has been printed previously may cause jams.
  • Make sure the rear access door is securely fastened.
  • If you follow all these guidelines and still have frequent paper jams, you may need to clean the paper rollers.
Cleaning paper rollers
  1. Turn off the unit, then unplug the power cord.
  2. Remove the rear access door. See the picture above.
  3. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around. Figure 7: Paper rollers
  4. Allow the rollers to dry completely, then replace the rear access door. Put the pins on the right end of the door into the holes on the right side of the rear access area, then snap the door shut.
  5. Plug the unit back in and turn it on.
Please vote if this is helpful. :)
Dec 11, 2010 | HP PSC 1350v All-In-One InkJet Printer
My cartridges on my canon pixma mp190 do not move to the center when i open it. it is also blinking an error of E2 and the alarm button is blinking
Is it brand new? The print head rail may have a protective plastic piece covering it. Pull that out and it should work better.
The code "E2" on your Pixma MP190 indicates that the paper is loaded incorrectly.
After correcting the problem that caused the error, press the or button.
  1. Remove paper from the rear tray.
  2. Open the paper output tray and extension. (See and in Figure 1 below.)
  3. Set the paper thickness lever according to the media being used. (See in Figure 1 below.)
    Note: For paper thickness lever settings, use the following setings for the media type being used: Right side: Envelopes / T-Shirt transfers. Left side: All other media types.
    * Figure 1
  4. Divide the stack of paper into two or three piles.
  5. Fan out the sheets of paper so that they do not stick together.
  6. Load paper in the rear tray with the paper's print side facing up. (See in Figure 2 below.)
  7. Align paper to the right edge of the rear tray. (See in Figure 2 below.)
  8. Pinch and slide the paper guide to the paper's left side. (See in Figure 2 below.)
    * Figure 2
  9. Press or button to clear the error.
Dec 02, 2010 | Canon PIXMA MX310 All-In-One Printer
Can't print DL envelopes on a Pixma iP4600
Hi ...
If you like to print DL envolopes, check the below 3 points and I am sure you will be able to print from your printer.
Prepare the printer:
  1. Open the Rear Tray and pull out the Paper Support. Put your finger in the rounded indent of the Paper Support and pull it out until it stops. (See <1> in Figure 1 below.)
  2. Open the Paper Output Tray. Put your finger in the rounded indent beside the Paper Output Tray and open it gently. (See <2> in Figure 1 below.)
  3. Open the Output Tray Extension. Open up and set the Output Tray Extension completely by pressing down the hollow on its front side. (See <3> in Figure 1 below.)
  4. Adjust the position of the Paper Thickness Lever. Set it to the right when printing on envelopes or T-shirt transfers, and left when printing on any other type of paper. (See <4> in Figure 1 below.)
    * Figure 1
  5. Load the envelope.
    1. Load the envelope against the right side of the Rear Tray. (See <1> in Figure 3 below.)
    2. Load the envelope with the address side facing UP and the rear flaps DOWN on the left. (See Figure 2 below or, <b> in Figure 3 below.)
      * Figure 2
    3. Pinch the Paper Guide and slide it against the left side of the envelope. (See <2> in Figure 3 below.)
      * Figure 3
      Note: Reset the Paper Thickness Lever to the left when you finish printing. (See <3> in Figure 3 below.)
Preparing Envelopes to Load:
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
Paper Type
Precaution
Envelope*
DL / #10
Set paper with the flap closed.
Unsuitable Envelopes:
  • Envelopes with an embossed or treated surface
  • Envelopes with a double flap or pressure seals
Printer Driver Settings:
  1. Select Envelope in Media Type.
  2. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
    * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Note:
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
Don't forget to vote if this helps ... Cheers :)
Jul 27, 2009 | Canon PIXMA MX310 All-In-One Printer
Mp460 feeds more than one pages
Hi ...
There is no hardware fault in this perticular situation. This happens because of paper loaded. There are 2 possible resolution to this problem:
I) Fan paper prior to inserting it into the MP460
  1. Remove paper from the ASF.
  2. Open the paper output tray. (See <2> in Figure 1 below.)
  3. Set the paper thickness lever according to the media being used. (See <3> in Figure 1 below.)
    * Figure 1
    The illustration shows the PIXMA MP460
  4. Fan out the sheets of paper so that they do not stick together.
  5. Load paper in the auto sheet feeder with the paper's print side facing up. (See <1> in Figure 2 below.)
  6. Align paper to the right edge of the auto sheet feeder. (See <2> in Figure 2 below.)
  7. Pinch and slide the paper guide to the paper's left side. (See <3> in Figure 2 below.)
    * Figure 2
II) Load fewer sheets into the MP460
Jul 17, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Loading paper
Follow the illustrated instructions on the first page of this manual.
Jul 18, 2008 | Sharp EL-1197PIII Calculator
Paper Out message
Make sure that you are loading it in the back and not the front, I didn't figure this out until I looked at the manual. If you're used to HPs then you want to load in the front, but actually if you look behind the scan door, there is a black panel that you can open, and that's where you feed the paper. That thing in the front is actually where the paper comes out of. Go figure.
May 18, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon P23-DHV Calculator Logo
52 people viewed this question
old marine
old marine
