Question about Logitech Extreme 3D Pro Joystick
1 mo. old,getting to much slack in joystick
Is there a way to adjust the slack out of the joystick,Iv taken the bottom plate off and looked around but didn't find anything that looked like an adjustment. Not what I was expecting anyhow.
  • 29 Answers
Captfred, When you had the bottom off, did you drop the larg sping out?It's placed between the base and the hand controler, thats what gives the tension to it, unless your talking about your rudder control(twist left/right). jls
Posted on Oct 21, 2008
  • jeff-smart Oct 21, 2008
    Sorry Tiriaa, I know its hard if your not into computers thoroughly, but if you have some time, could you tell us a little more about your computer: operating system/ cpu/ motherboard/memory.. as well as what game your playing and about the joystick? might be able to help but need more info. Good luck JLS
Sorry not really great on computer's and just puchased this stick so my young nephew didn't stuff the key board. downloaded all the driver's and still it woulded work I don't know what do do?
Posted on Oct 11, 2008
Why are front three selections vending two cans?
There is an adjustment for the length of the cans. The columns that are not working properly have too much slack. Open it up and look behind the cans. There is a metal plate with spring loaded clips, top and bottom. Squeeze them together and move the plate forward to take out the slack. Do it top and bottom. When properly adjusted the cans will move a little (1/4 to 1/2 inch).
Apr 01, 2016 | Selectivend CB300 Satellite Ice Water Cold...
Process for changing 2001 Chevrolet Suburban surpentine belt
See diagram posted on radiator housing or download picture from internet site.
Use wrench, or hand, to pull/push slack adjuster away from old belt.
Place new belt around all pulleys except the slack adjuster
Pull slack adjuster to slack position and place belt onto it.
Mine is so easy to move that I can move it w/o any tools just with my hand.
May 12, 2014 | 2001 Chevrolet Suburban
On 2002 ford explorer,4.6-v-8, when i was changing timing chain guides and adjusters the chains jumped teeth on the crankshaft. The manual says the left camshaft timing mark should be approx. @ 11:oo & the...
Look for some Youtube videos on this repair. If I remember correctly the links on this chain have different color metal for the spots that the cam tooth goes against. When each side is in the proper tooth the right and left colored links will be on the cam mark and the crank mark should be on the timing TDC mark. Sounds like the slack you describe is wrong and a tooth is off because the tensioner is allowing slack.. You need to slip a tooth one way or the other until the tensioner has room to be in a neutral position.
Mar 10, 2017 | 2002 Ford Explorer
How do i get the old transmission out of my car and put the new one in.iv taken all the bolts off but it seems 2 b stuck what do i do
do you have the bolts out that connect the flex plate to the tirque converter? There is usually a bolt that goes through from the engine side between the trans and the engine(firewall side) that gets missed.
Jan 13, 2011 | 1997 Chevrolet Monte Carlo
Drive chain slack?
Typical chain slack should be about two inches from bottom edge of the chain to the top. Grabbing the chain in the middle (halfway from sprocket to sprocket) and moving it up and down. After adjusting , you should raise the rear wheel off the ground and spin the back wheel checking every 6 inches or so that the slack does not get tighter or looser. If the chain gets tighter as it goes around the sprocket it is an indication that the chain is stretched at that point and needs to be replaced.
Nov 17, 2010 | 2004 Yamaha YZ 450 F
How do i time the harmonic balencer on a 1992 suzuki dr650
The balancer chains has a series of marks and a chromed pin plate. Align shiny plate pin (#1) with notch on crankshaft sprocket. Align pin #26 with letter R on rear balancer and pin #50 should line up with letter F on front balacer. All slack is taken up by tensioner at the bottom. Cheers.
Nov 20, 2009 | 1992 Suzuki DR 650 RS-E
PSP joystick problem.
These are some of the steps you can do
1. Use the screwdriver to detach the face plate from the bottom of your PSP. You'll need to remove the battery pack. There are additional screws underneath the battery pack that need to come out to take off the face plate.
2. Look on the bottom side of your face plate. You will find four small bronze-colored rectangles lined up together. Take your damp cloth and wipe over this section. Wait 30 seconds, then wipe it off with a dry cloth. It is important that your cloth is just damp and no water is leaking from it.
3. Remove the plastic piece that covers the small bronze squares on the right side of the analog stick. Clean these with a damp cloth.
4. Put your PSP back together the same way you took it apart. Don't forget to screw the battery pack screws into place, or you will experience other problems down the road.
Regards
Aug 10, 2009 | Sony PlayStation Portable (PSP) Console
Locked up emergency brake
there is a oval plug on the top or bottom of the backing plate, this is access to the adjuster. it may take two screwdrivers to back off the starwheel inside, one for the wheel and one to hold the auto adjuster lever out of the way. They make a brake adjuster tool too, it looks like a two headed bent screwdriver, would make it easier but you can probably do it without
Mar 26, 2009 | 1990 Ford Bronco II
I have a juki mo-3614 serger and I can't seem to get the blades lined up right for cutting. It just seems to want to roll the fabric instead of cut it. How do I line up the blades the right way.
first, pull out the bvlades and make surte they are sharp. It could simply be that they are dull. Next, line tyhe bottom blade up level to the surface of the needle plate. The top blade should be adjusted to where it slices against the botom blade. You may have to experiment with the height adjustment on the top blade, assuming you have a suitable cutting edge.
Nov 29, 2008 | Juki MO-644D Mechanical Sewing Machine
NIKON SCAN IV ED
connect after PC start up
May 29, 2008 | Nikon Coolscan IV ED Film Scanner
Logitech Extreme 3D Pro Joystick Logo
134 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Lyle Siemens
Lyle Siemens
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
