Question about Hudson Reed Home
We have a Hudson Reed Infinity Shower Pole A389. The flow / diverter is leaking. I want to see if there is something which I can tighten. How do I remove the knob without damaging it?
  • 659 Answers
SOURCE: My Hudson Reed lift and turn mono block tap leak
There should be a retaining ring right under the handle when removed. The stem of the ball runs up through the middle. Tighten this retaining ring and it should stop the leak.
Posted on Mar 21, 2009
  • 62 Answers
SOURCE: Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Posted on Jun 12, 2009
  • 297 Answers
SOURCE: kohler shower diverter leaks (behind the wall)
if you have a closet behind the shower or a wall you may be able to get to the diverter without damage to the tile ,are you sure you can't just change the cartridge? most times this is all that is needed to fix a problem like yours.
Posted on Jul 24, 2009
  • 297 Answers
SOURCE: Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Posted on Jul 26, 2009
  • 35 Answers
SOURCE: shower diverter push handle is squirting water out
If you are handy, the best solution is to call delta and have them send you a new diverter. They will need the model of your faucet. The new diverter will come with instructions on the install process. As far as fixing it without the new diverter, I don't believe you will be able to.
Posted on Nov 18, 2009
The water coming out the shower jets is not powerful, help?
follow this steps and fix it. God bless you
If a faucet leaks, replace seals and gaskets .
If a shower head leaks, create a better seal or replace seals .
If a sillcock wears out, replace the washers .
If a compression faucet drips from the spout, replace the washer and/or the seat .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type .
If a ball or cartridge faucet leaks from the collar, replace worn O-rings .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals .
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes .
If the aerator leaks around the edge, replace the washer in the aerator .
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head .
Nov 25, 2013 | Home
I have a hudson reed Twin Concealed Thermostatic Shower Valve. It was working fine for a couple of years. My brother used the shower and adjusted the water temperature valve but since then the water has...
Sounds to me the diffusor is stuck or broken in the position to allow only hot water through it.Looks to me tou have a mixer valve on it. Might have to replace it.
May 31, 2011 | Hudson Reed Home
Hi Have a hudson reed kia twin valve shower - fab! But recently taking forever for the hot water to come through. Don't think it's the boier as the hot water comes through quickly everywhere else...
with out a water circulator every thing takes time ----------- sounds like the thermostats going bad you do have a 10 year warranty on this faucet type in your browser hudson reed kia faucet
Jan 18, 2011 | Home
Water flow interruption in shower diverter
The washer on the diverter is loose. needs to be tightened or replaced
Sep 12, 2009 | Home
Mar 21, 2009 | Hudson Reed Traditional 6 piece bathroom...
Home Logo
112 people viewed this question
Top Hudson Reed Home Experts
ray gallant
Jay Plesset
Donni Steen
Are you a Hudson Reed Home Expert? Answer questions, earn points and help others
