Question about Kenwood DMC-G7R Personal MiniDisc Player
Kenwood 3090 minidisc recorder displays TOC W ERROR
3 Suggested Answers
otacon
  • 1944 Answers
SOURCE: sharp minidisc MD-MT20 H - TOC ERROR a
I am sorry to say but your unit needs to be sent for repair. The TOC error shows up when the unit can't read the Table Of Contents of the disc (and simply shuts down after trying)....and in your case, you said it can't read any disc. This indicates that the lens unit has malfunctioned and needs to be repaired or replaced.
Posted on Mar 17, 2008
  • 43020 Answers
SOURCE: HOW DO I SET UP A KENWOOD MINIDISC RECORDER PLAYER
usually reading the instructions helps with any setup .
Posted on Mar 04, 2016
Testimonial: "I DON,T HSVE THE INSTRUCTION BOOKLET ?"
What does utoc error mean on a Kenwood mini disc player
Well, what it means is
TOC errors often mean the recording head/optical block is cooked. A cleaner might work, but often it's the end of the MDR.
Are you sure the battery is correctly (fully) charged? Try removing the battery and running on (only) the charger.
try cleaning the lens with a minidisc lens cleaner.
open the unit and check the laser position - it should be all the way to the left. that's where it should start to read the disk.
Read these:
https://groups.google.com/forum/#!topic/alt.audio.minidisc/63uCBegyG8A
http://www.minidisc.org/repair_q2.html
http://forums.sonyinsider.com/topic/21439-fun-with-the-sharp-702-utoc-error-fixed/
http://www.mazdas247.com/forum/showthread.php?98358-TOC-Error-on-brand-new-disc!
http://www.borus.de/minidisc/303.htm
Jul 07, 2014 | Sharp MD-MS702 Personal MiniDisc Player
SONY MDS JE 530. (C14) Toc error.
You may well be right. Try a different brand of disc.
Apr 01, 2013 | Sony MDS-JE330 Mini Disc Player
Your owners manual (you DID read your owners manual, right?) says the machine cannot read the TOC on the disc.
It might be a disc problem and it might be a deck problem?
Have you tried a different minidisc?
Have you changed any of the SET-UP settings? Take a look at them, too.
Apr 01, 2013 | Audio Players & Recorders
I've been sent a recently recorded 80 minute Sony Minidisc - but when I attempt to play it, a 'TOC Error' message is displayed. I suspect the disc was ejected from the machine immediately after...
Your diagnosis is likely correct and yes, you can save the data by a process known as TOC cloning.
Depending upon the make and model of your MD recorder(s) you may have to obtain a TOC-cloning friendly model, but every single piece of MD equipment I own has come for free via FreeCycle or Gumtree so you shouldn't have any problems in that respect. If you need one in a hurry then they're usually dirt-cheap on ebay.
I don't wish to plagiarise, nor is there any point in re-inventing the wheel, so if you click here you'll see detailed instructions.
Good luck. Sorry for the long delay in posting an answer,I have only returned to FixYa last week after a long absence and this section isn't often monitored by others as questions are rare now that it's obsolete technology.
May 13, 2011 | Audio Players & Recorders
My MD-MS702 gave me very good service. Unfortunately it was not used for five to six years and now when i switch it on after full battery charging I get TOC error on all of my recorded discs. SOS, as I am...
According to you You don't have use your disk play for a huge time, so that it may damaged or lens became dirty.
You can clear the lens with lens cleaner (clear the optical head).
check the battery was properly charged or working.
Check the disk moved properly.
To prevent the disk erase or damage slide the accidental erase prevention tab.
You can show it to the Technician.
Jan 06, 2011 | Audio Players & Recorders
Sale c13 read error
C13 read error means that the player is unable to read the TOC (Table Of Contents) on the minidisc. it has to read this first so that it knows where everything is stored on the minidisc.
TOC errors can be caused by faulty minidiscs, those which have been incorrectly finalised or by a faulty head assembly on the machine.
If possible, try to see if you get the same problem with different brands of minidisc, and also whether minidiscs recorded on other machines work on your player and whether minidiscs recorded on yours work in other players. Report back with what you find as it helps determine whether the player itself is at fault.
In reality though, it's a 9 year old unit and like all optical disc devices, minidisc heads do not last forever. If the head has failed then your only fix is to replace the player as spare parts are no longer in production and existing stocks are almost as rare as fresh dodo doo-doos.
Mar 16, 2010 | Sony MDS-JE470 Mini Disc Player
Kenwood MD plays ok but recordings fail to play; U TOC error?
Without a decent Table Of Contents, your MiniDisc will NOT work, as you've found out. Does it matter what brand of MD you use? I would record it at "1X" and NOT 4x speed too. Try erasing a blank minidisc first and then shut off the unit and then turn it back on and see if the TOC works. Try adding a title, then turn it off and back on. Then try the CD to MD.
Jan 16, 2010 | Audio Players & Recorders
When i inserted my mini disc it said TOC Reading then said Toc Error and C14. What is the problem?
Sounds like you lost power when you were finishing recording a disc. On a home unit it got unplugged before you had the TOC written, or on a battery unit the battery died when it was writing the TOC (table of contents) for the disk.
Jan 01, 2010 | Audio Players & Recorders
TOC ERRORa
When you FINISH recording, the Minidisc recorder Writes the TOC (Table of Contents) - so you see it flashing TOC or Update when you finish recording - you need to Leave POWER ON and have the unit on for about 30 seconds for it to finish this. IF you don't, the unit doesn't know where to find the files since there is no TOC. Try a Sony home unit - you might get one more shot at it working with that.
Aug 19, 2009 | Sharp MD-MS702 Personal MiniDisc Player
Toc error problem
HEY,
t is not the topic, but I'm for al long time searching for the sharp md-mt20h and I see that you buy a new md player? Were can I buy him?? thanx
Sep 20, 2007 | Sharp MD-MT20 Personal MiniDisc Player
299 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
